SUVAT motion question - Ball thrown vertically
  • Thread starter Thread starter TheGreenMarin
    Ball Motion Suvat
The discussion focuses on solving a physics problem involving SUVAT equations for a cricket ball thrown vertically upwards, which returns in 4.2 seconds. The initial velocity was calculated using the equation v = u + at, resulting in an initial velocity of 20.601 m/s. The maximum height can be derived using the equation s = ut + 1/2at^2, leading to a displacement of 86.5242 m. The participants emphasized the importance of correctly applying signs for acceleration due to gravity in these calculations.
  • Understanding of SUVAT equations in kinematics
  • Knowledge of gravitational acceleration (g = 9.81 m/s²)
  • Ability to manipulate algebraic equations
  • Familiarity with basic physics concepts related to motion
  • Learn how to derive maximum height using SUVAT equations
  • Explore the implications of negative acceleration in vertical motion
  • Study real-world applications of kinematic equations in sports
  • Practice solving similar problems involving projectile motion
Students studying physics, educators teaching kinematics, and anyone interested in understanding the principles of motion and acceleration in vertical trajectories.
TheGreenMarin
A cricket ball is thrown vertically upwards and returns in 4.2s. Find (a)The initial velocity of the ball
(b)The maximum height reached
v=u+at
v^2=u^2+2as
s=(u+v)/2 multiplied by t
s=ut+1/2at^2
s=?
u=?
v=?
a=9.81ms^-2 (negative traveling upwards)
t=4.2s
I could not start the question because to use SUVAT equations at least 3 of the 5 letters must have values to be put into a equation.
Start with
v = v_0 + at
Where v = end velocity, v_0 initial velocity, a = g = gravity and t = time
If you consider v to be the velocity at the top of the throw then v = 0.
Thus 0 = v_0 + at
v_0 = -at, You know the acceleration and t = half the total time. So there you get the initial velocity and rest becomes simplier.
There are two equations you can use.
First fill in these:
s = ?
v = ?
(You have enough information to fill in these values.)
THINK!
What is the velocity at the max height?
s = ?
v = ?
s= I'm really not sure how to found out the displacement
v=0 [ as it has stopped at its maximum point in the air?]
grzz said:
THINK!
0 velocity?
Uniquebum said:
Start with
v = v_0 + at
Thus 0 = v_0 + at
0 = v_0 + 9.81x4.2 ? I am not sure I have done this correctly
so v_0 = -41.202 <---- I've definitely gone wrong here, the initial speed surely cannot be negative
so v_0 = -41.202
It looks like you are trying to use this equation: s=ut+1/2at^2
But you left out a few things. Try again. (But yes, s = 0 for the round trip.)
Ah, thankyou s now makes sense
0=u x 4.2 + 0.5 x 9.81 x 4.2^2
gives me 0 = u x 90.7242
so u = 0
I'm really struggling with this question, what error have I made this time?
OK, except that you have the wrong sign for the acceleration. Fix that first.
No it doesn't. Try again.
-9.81 as its against gravity, rookie error
I now got -82.3242 as my answer but I'm not sure how this can be right as it is negative
Good.
Show how you got that, step by step.
0=u x 4.2 + 0.5 x -9.81 x 4.2^2
so 0 = u x -82.3242
OK.
so 0 = u x -82.3242
Not OK.
Try this:
which I'll rewrite as:
0 = 4.2u -(0.5)(9.81)(4.2^2)
4.2u = (0.5)(9.81)(4.2^2)
And so on...
Doc Al said:
OK.
Not OK.
Try this:
And so on...
Just confused on where the - sign has come from in the line: 0 = 4.2u -(0.5)(9.81)(4.2^2)
Starting with:
0 = 4.2u +(0.5)(-9.81)(4.2^2)
You can move that minus sign from in front of the 9.81 and place it here:
(1)(2)(-3) is the same as -(1)(2)(3).
4.2u = 86.5242
/4.2 = 20.601 ms^-1 Final answer for (a) I think?
Doc Al said:
Starting with:
Right OK, I see how you have done that. Is my answer of 20.601 correct?
Yes. (I'd round it off to no more than 3 sig figures.)
Thank you very much for your help I really appreciate it. I am so glad I found this website, you have helped me greatly. I will definitely stick around here and maybe one day even help people out with their problems (Once I understand the basics).
This site is so helpful that I will tell my friends to come here if in need of any physics help.
Once again thank you Sir, you have really helped me out in understanding of SUVAT equations and of basic re-arranging.
Thank you
You are most welcome!
  • · Replies 38 ·
