Synchronized dual lid lifter using 18" and 9" aluminum bars
  • Thread starter Thread starter cybertron
    Mechanical
128 replies · 22K views
cybertron
Hi All
I'm new to the site. And please no negative comments. Its just a waste of being helped!
What I want too construct is a Square tubular aluminum bar 18'' long 1'' square dia with a 9'' long tubular aluminum bar place on top and hinged on each side of the 18'' bar what the two smaller bars would do is lift the two lids at the same time and at any angle from O-dgrees to 100-dgs.Like Push and pull
How can i make one of the 9'' bars lift as the other 9'' bar is being lifted by a motor. and without any pullies or cables on the oposite 9'' bar. I seen this mechanism somewhere but can't remember where.
Dose anyone know of or see a mechanism that make one bar lifts as the other bar pulls.
This mechanism would be extrude in the square tubular bar.
Welcome to PF, Cybertron.
You won't get any negative comments here, at least of a derogatory nature. I must admit, though, that your objective eludes me. More description would be helpful.
If the bit that I can gather is accurate, then I'm thinking of having both bars brazed or bolted to a common axle.
Danger thanks for responding
My objective eludes me too! Thats why I'm having a problem figuring out how too construct this as simple as it sounds but its not impossible I would need some sought of push pull mechanism that I could make from common hardware materials.
I'll try too get a simple sketch out to make it much clear what i need.
What about something like this? Not to scale.
EDIT: Oops. As drawn, the doors will be locked in place when they close (due to the over-center feature of the right-hand door). Sorry.
NVN
looks close too what i need, but not exactly. The hinges could be used for rotation and angle position.
The rod you included will not work in that position. And the bottom part can't be used.
But it is close.
What about this? (credit to nvn)
tyroman.
Close. Still bottom part will not work and that top piece can't be there do too the two bar must closed at 0dg.
NVN.
Much closer the bottom still wouldn't work in my application.
I been trying too come up with a sketch I will try to post it some time today this afternoon.
Everyones help is appreciated.
Here's a simple drawn up sketch too explain as best as I could in what I'm trying too construct.
The lifter will be made from aluminum or wood.
In the image I provide is the Lifter not the two lids, This lifter will be attach too two leaf style lids.
As you can see in the sketch two small sq tubular bars will lift the two lids from Odgs-100dgs.
How this should work is when any side is lifted the smaller bars either the right or left bar the opposite side will lift at the same time.
So basically what I need is some knid of mechanism to pull and too push open two lids at the same time as seen in the sketch.
one side will have a motor to lift one of the bars so that's the pulling, now the same mechanism needs too push up the opposite side for the other lid too open that's the pushing. I hope this makes any since on how this lifter is suppose to function.
I hope the sketch uploaded to this thead the image might be small do to the bit size image limit.
cybertron,
In your reply to my previous post, you said;
"tyroman.
Close. Still bottom part will not work and that top piece can't be there do too the two bar must closed at 0dg."
Is the "bottom part" the motor? the linkage? the extension of the left-hand door?
And is the "top piece" the cam device which would be affixed to the left door and bear upon the under-side of the right door?
In your original post you say;
"This mechanism would be extrude in the square tubular bar."
and, in your sketch you appear to depict a motor inside of a 1" diameter tube...
Why? There must be a better place to locate the motor, and requiring the drive mechanism to be "inside" the tube becomes quite complex.
In various places you refer to 90 or 100 degrees - where are you measuring this angle?
Finally, and with full credit to nvn for his last post, I offer an alternative mechanism... see attached.
ps; if you save your sketch as a .jpg file or .png it will be about 20 KB.
tyroman
Yes I did say your image was close. But what i should have said is the mechanism that you're inply in your image will not work in my application.
As stated this lifter will open and closed from Odgs in the closed position and 90dgs or 100dgs in the open position.
Also in your image that piece that's attach too the left top side of the lid bearing on the right side of the lid wouldn't work for me.
In my original post yes I did say extrude I ment the mechanism will go through the sq tubing.I didn't dpict any motor going into the 1''tubular bar that would be impossible even for any type of motor. I stated a motor will lift the smaller tubular bar.
I also stated I'm looking for a mechanical mechanism that could be placed in the 1'' inch long tubular bar I did not state a drive motor mechanism at all inside the tubular bar.You stated that. Even in my sketch there is no drive motor mechanism inside the tube I stated some type of mechaninal mechanism. I also stated in my sketch that a motor will be attached to the smaller tubular bar too lift it from the closed position Odgs to the open position to 90dgs or 100dgs.
I thing you're misunderstanding what i need. Its knid of hard too explain too anyone without explaining it in person.
Yes i did mention in places 90 Or 100 degee angles these angles come from the smaller liftiing bar that lifts the two lids that smaller bar will be attach to the long bar that i drawn in my sketch the angle of lift, gos form 0dgs to 100dgs.
As for the sketch it was drawn in MS PAINT can you save an image in PAINT as a .jpg file
or a png file I through MS PAINT stores the file only as a Bitmap.
If you just look at my sketch as you see there is a long tubular bar and there's two smaller bars equal too the length of the long tubular bar,as you lift anyone of the smaller tubular bars the opposite side will lift at the same time and at any angle i want up too either 90dgs or 100dgs this is how the (Mechaninal) mechanism should work.
Any motor that I use will only assist to lift the lid that will be attach either one side of the smaller tubular bars on the lifter. In my sketch this image is the lifter, its not the lids.The lids will be attach only too the two smaller tubular bars.
This is why I'm trying too build a mechanial mechanism so I can lift the small tubular bars.
This mechanism is call a push and pull mechanism I seen one before but I don't remember where. what it dose is if you lift anyone of the smaller bars they pull and push at one another too lift on side as the other side is being pull on to lift the opposite side.
and there no motor driven mechanism too in the lifting of the bars its all mechanial.
I will include a motor that will only assist with the weight of one side of the lid.But i wouldn't need the motor just too lift the lids. The motor is there to assist with the weight of one of the lids.
Also. I don't have or use a CAD software what program do you use for sketching.
I use Adobe Illustrator. Depending upon which of my computers I'm using, that ranges from version 4 to 10. I have CS as well, but my ex-wife accidentally dumped a beer into that computer so I can't use it.
In MS Paint, select File > Save As > png, not jpg; .jpg is for photographs, .png is for graphics. What about something like this? Not to scale.
nvn.
Please explain too me how this will work, what are those sq shapes in your image.
Remember now in my sketch this is only the lifter. The mechanial lifter mechanism must work too lift (without being attach to the lid) so if I was too pull up on one of the smaller bars in my sketch the other bar on the opposite side will lift up too and at the same time. This is how the lifter must work. Pull and Push.
cybertron: I now added some labels to the attached file in post 14; see the revised file. The blocks at points E and F are generic supports for linkage rod BC. No specific detail or attachment method for these two supports at points E and F is implied in my diagram. (These support blocks are called "bushing or bearing" in the diagram by tyroman in post 11.) In my post 14 diagram, linkage bars AB and CD are connected to the square tubes at points A and D by inserting a horizontal pin or bolt through the square tube (not shown). You grind off the bottom face of the square tube at point D to allow the right-hand door to rotate to 100 deg. Linkage bar AB passes through slots in the left-hand tube and long tube.
nvn ,
What sort of linkage part are you using to attach together bar A to B AND C to D for the two rods or bars in your image too move. And will I beable to lift either side of the small bars so the opposite side lift on its own.
I will enclose another sketch so you can see or uuderstand better about what i need.maybe that bar attachment my work in mt new image of my lifter.
nvn
I made a new sketch in MS PAINT. But when I (save as) .file in png as you suggested some of the image is losted the the words are disstored and blury. what is happing to the image and is this normal in saving the file in .png.
The images which have been posted by nvn (and me) can be copied from your browser (right-click>save as) to your desktop and opened from there with MSPaint. You can then edit them as needed. When done, select File>Save As , give the image a new name (leave the extension as .png) and save it to your desktop. From there, you can attach the new edited image to your post with a description of your edits.
If, while you have one of our images open in MSPaint, you click on Image>Attributes , you will see that Resolution: is 120x120 dpi and dimensions are 5.42" Wide by 4.38" High.
If you want to create a new image (with the same Attributes as ours), just open one of ours in MSPaint, select Edit>Select All then right-click on the image and click Clear Selection. This will give you a blank sheet with the same Attributes as ours for you to create your new image on. Remember; when done, select File>Save As , give the image a new name and save it to your desktop (or the original image will be lost).
I have attached a generic image of your basic design, rendered in 3D... No opening mechanism is shown. It is hoped that 3D will allow greater clarity in our communication of what will (and will not) work for you. Please edit the attached as needed and use it as a basis for further definition and communication of your needs.
nvn.
Here another sketch hpoefully to make clearer what i need.
The sketch is only the tubular square bar lifter.
What I need is a Mechanical Mechanism too attach too the small tubular bars on the lifter So when I Pull up on either side of any of the smaller bar the opposite lifts on its own at the same time. this sketch should make it more understandable too what i need.
Remember If I pull up on anyone of the smaller Tubular Bars the opposite side MUST lift on its own.
The attached is my edit of the generic image. I have changed the short "tubes" to square tubes. The Articulation Limits are shown as ~100 degrees rather than 90 degrees. A Structural Limits ("no-go") volume has been added.
Unless we can find a way to communicate better using an image like this, I feel my contribution must end here.
tyroman
I just drew my generic image on this thread too give a general understanding to what I need, my last sketch too this post dictates that. I didn't thing I needed to sketch a 3D image for anyone too understand what I need.AND my most resent generic image is ONLY! the tubular lifter.
In your 3d image you have the two smaller tubular bars and they are attached too the longer tubular bar. The 100dg angle you have with no articulation limts. OK. the Hinges you have will be Bracket hinges so as the smaller tubes swings it clears the top of the longer bar for rotation so it swings from 0-100dgs. If you took that pink PART out in your image then you have a 3D image of my tubular bar LIFTER generic image.
REMEMBER MY MOST RESENT GENERIC IMAGE IS (ONLY) THE LIFTER NOTHING MORE.
tyroman.
If your 3d image without the pink part (thats makes it confussing too me), represents my simple generic sketch then you have exactly the tubular lifter as in my sketched image.
But you have to understand NOW I NEED A MECHANICAL MECHANISM TOO LIFT-UP THE SMALLER TUBULAR BARS AS STATED IN MY MOST RESENT IMAGE AND POST.
Do you understand what I need now.
I came Here to this forum too get help on the (Mechanical Mechanism) for lifting the smaller tubular bars as stated in this thread AND in my sketches.
I already have the tubular bar lifter as a prototype I included A SIMPLE SKETCH OF the lifter in my first post to show what i needed and that IS A MECHANICAL MECHANISM WHICH ATTACHES TOO MY LIFTER. iF I DIDN'T INCLUDE THIS LIFTER ON THIS FORUM YOU WOULDN'T NO WHAT I NEEDED IT FOR.
IS THIS ANY CLEARER.
How about a tie-rod and bell-crank system?
And can you please stop adding the extra 'o' in 'to'? 'Too' means 'excessive', which your 'o's are. :biggrin:
cybertron said:
What I need is a mechanical mechanism to attach to the small tubular bars on the lifter, so when I pull up on either side of any of the smaller bars, the opposite side lifts on its own at the same time.
Yes, this is the sketch I attached in post 14. The mechanism shown in my post 14 sketch is such that when you lift one small bar, the opposite small bar rises.
cybertron said:
Will I be able to lift either side of the small bars, so the opposite side lifts on its own?
Yes. You can lift either side, and the other side will rise.
cybertron said:
What sort of linkage part are you using to attach together bar AB to BC, and BC to CD?
There are probably different methods for connecting linkage bar AB (and CD) to linkage bar BC. I envisioned that linkage bar AB (or CD) will be just a plain, flat bar, with a hole in each end.
And the linkage bars could perhaps be connected together with a clevis pin or shoulder bolt. Or, you could perhaps cut a slot into each end of linkage bar BC, thus making a clevis.
Sorry about that. I sometimes type fast and don't go back an edit it. Its a Habit.
What is a tie-rod and Bell-crank system? Please explain!
tyroman said:
cybertron
are you shouting? CAPS imply shouting.
No I'm not shouting? I type fast and i leave the CAPS on. I will try to close it off.
tyroman.
Thanks for the advise on copying your image for edits.
I just edited the image as I think it should be.It is basically the same as my generic image but
in 3d.
Now on to the Mechanical Mechanism.
Nvn. Mechanical Mechanism in sketch #14 seems like it may work, and i need it to be simple to make and his looks simple to construct, But it looks like its just rods linked together there's no indication of any force unpond the rods to pull one side up as it pushes against each other to pull the opposite side to rise it up.I just don't see that.He indicated it will, But i don't see how it will with no equal force on the rods.Example: Its like a swing when you push it momendum = force will pull that swing back in the opposite direction by pushing like a pendulum. I don't see this in the rods.
Whats your input and opinion on how this is going to work.
Here the your image that i edit it didn't upload in my last post.O' i press the wrong button.
cybertron said:
There's no indication of any force upon the rods to pull the opposite side up.
When you pull door A upward, it pulls linkage bar AB, which pulls linkage bar BC to the left, which pulls linkage bar CD. Therefore, linkage bar CD applies a pulling force to door D, causing door D to rise. If you now push door A downward, the reverse process occurs, causing door D to close.
Alternately, if you push or pull door D (instead of door A), the reverse process occurs, causing door A to rotate.
