Synchronizing clocks at different locations to measure speed of light
The discussion revolves around the challenges of synchronizing clocks at different locations to measure the speed of light, exploring theoretical implications, assumptions in physics, and the nature of time and light in the context of relativity. Participants delve into both conceptual and technical aspects of the synchronization problem, including potential experimental approaches and philosophical considerations.
  • One participant suggests that the brain's processing speed limits the synchronization of events, raising questions about the nature of consciousness and causality in relation to clock synchronization.
  • Another participant asserts that synchronization of distant clocks is impossible without assuming a one-way speed of light, which is a fundamental aspect of relativity.
  • Some participants discuss the implications of using different synchronization conventions, such as the Einstein synchronization convention, and how these choices affect the perceived speed of light.
  • There is mention of the potential for quantum system states to cover multiple localities, suggesting that this could provide insights into synchronization challenges.
  • Participants explore the idea that gravitational effects on spacetime might allow for a theoretical path of light that could aid in synchronization efforts.
  • One participant questions whether the inability to synchronize clocks is a definitive conclusion in physics or merely a current limitation of our methods.
  • There is a discussion about the implications of assuming isotropic versus non-isotropic speeds of light and how this affects the mathematical framework used in physics.
  • Some participants express uncertainty about the existence of a "true" one-way speed of light, emphasizing that it is defined by the chosen synchronization convention.
Participants generally disagree on the possibility of synchronizing clocks at distant locations, with some asserting it is impossible without assumptions, while others explore the implications of different synchronization conventions. The discussion remains unresolved regarding the nature of the one-way speed of light and its measurement.
The discussion highlights limitations related to assumptions in synchronization methods, the dependence on chosen conventions, and the unresolved nature of certain mathematical implications in the context of relativity.
ESponge2000
TL;DR
I’m aware this is a challenge in physics with catch22, to measure c in one direction we need 2 clocks in sync, which we can’t do without assuming knowledge of the one-directional speeds of light, the whole point of why we need to sync in the first place …
just have some questions & ideas here and want to gather information on
When I tap my left hand and my right hand against the floor 3 feet apart, at the same time, I know that I’m not “really stretching 3 feet” at the same time, my brain is reading the nerves of each hand at a speed actually even slower than c but no matter how my circuits were designed it would be not faster than c.
The start point would be my brain sending the signal for me to touch equally on each side , and the result of what I touched would come also from my brain (a 2-way flow not a one-way flow)
I even tried to examine rare phenomenon in Siamese twins where there’s 2 conjoined brains but in rare cases some signaling is shared by one brain and not the other. The significance is if ANY conscious existence of 2 places on one clock could be ascertained there could be the physical infrastructure to synch 2 locations 2 brains 1 conscience but no , all cognition would flow from one brain to the other there’s no loophole around causality
But then another thought occurred to me. One brain, even a computer detector, is going to be larger than an infintessimal dot. That means the computer laptop brain spans a range of locations one clock…. Or does it span one clock … and for better precision is off by the assumption of containing only one clock ? And the lack of an infintessimal dot for a brain is a limitation on the meaning of any clock altogether to decipher one-way time discrepancies?
Thinking this through I THINK I see 2 possible areas of hope for testing this
1) Finding objects that occupy one state across more than an infintesimal volume and then examining variations in the workability when the object is rotated at set angles …. Would be due to directional effects Zzz The main thing that comes to mind are Quantum system states … possibly one system simultaneously covering a range of localities and comprised of a system-wide state
Or
2) Something that can be done with gravitational curving of spacetime : curvature of space time can maybe allow theoretically one direction path of light that starts and ends at the same
Location , and then a separate patch work to correct for gravitational time dilation interfering in the calculation ?
or for a final question is it determined in physics that we cannot synchronize 2 clocks at 2 distant locations ? Or is it something that we just haven’t been able to achieve at present?
Only by making an assumption that is equivalent to assuming that we already have two synchronized clocks. So no.
When you see these states in a QM text… You’re reading a text on non-relativistic QM, the only kind you’ll see in undergrad physics classes. Non-relativistic physics just assumes that there is one true time and all properly constructed clocks are synchronized to that time.
You cannot do it without assuming a one-way speed of light in a universe governed by relativity.
People do search for failures of Lorentz covariance (a broader collection of phenomena which would include an assumption-free synchronization convention), but nothing has been found.
That’s what my understanding has been. It does get weird to think that we are able use an assumption of choice, simplest being that c is the same in all directions for each IRF, for relativity of simutaneity and using those Lorentz transformations, getting all the same answers for explaining observations we are able to test. We can maybe guess the Einstein convention holds merit when we stipulate it is a fixed truth that all 2-way transmissions obey the same velocity constant …. Assuming then any path deviated from the constant it would have to be offset with paths deviating the other way going in reverse, And when we get how any angles one can travel a straight line path it becomes difficult to imagine such a lack of symmetry in directional speeds of light, or to where is that point in the universe where light beams move the fastest towards ?
It also I suppose can get very confusing when our galaxy or cluster of galaxies may be rotating just like earth rotates on its axis, and we wouldn’t know if our angles in space shift over time even when we use the constellations as our compass for space compass , what’s to say the entire observable universe isn’t in some type of axis rotation
Ultimately, it's just a choice of whether the imaginary coordinate grid you draw over spacetime is made of imaginary orthogonal lines (isotropic one-way speed) or imaginary non-orthogonal ones (non-isotropic one-way speed). As long as you keep track of which set of lines you're using and the mathematical consequences of using a non-orthogonal grid, you're fine. Physics can't care about your personal choices.
I think then the answer is it doesn’t matter. The observations come out the same regardless right?
If the assumptions is the south direction has speed of light infinity because the north direction it’s half of c, Then the same effect both north and south , for both directions an infinite energy results in crossing everything in 0 time , to the south because you would be approaching a truly infinite speed, And to the north because when traveling at near c/2, Which would appear to earth the instant light emitting back south ( it would appear as c) , the north c/2 traveler would be time dilated to experience the same exact effect as infinite speed limit the other way ….. and since light observing is a 2-way we would observe the same c value
Your comments seem to suggest that there's a "true" one way speed of light that we just can't measure. That's not the way it works in relativity. Rather, the one way speed of light is defined by the synchronization convention chosen. Hence it is in a sense arbitrary (although if you want your coordinates to define an inertial reference frame you'll have to ensure that the two way speed of light comes out to c).
It is convenient to use the Einstein synchronization convention for many reasons, including that it makes the speed of light the same in all directions. So that's the convention physicists choose in practice.
Yes, but "the one way speed of light" is not an observation. It's a convention.
If I’m understanding this right, we don’t even know if there is a “true” one-way speed of light, we have that observation affirms the fundamental constant c time delay for each and every IRF using each single clock against itself. That means then that we may not even know how light moves altogether beyond what it needs to do to preserve that relationship, which is to present the observations we validate by what we observe directly. Science doesn’t care about what I think.
But thought exercises can be fun. Alpha proxima is said to be the light from 4.2 light years away because a round trip is 8.4 light years away. We just know a round trip is 8.4 years. Our knowledge of the distance is that the relative motion of the star apart from the motion due to the rotation of the earth, orbit around the sun, and the motion of the solar system, reflects distance from earth, other knowledge affirming its distance is what kind of star it is with a telescope vs its brightness in the sky , through science comparing stars we have numerous scientific methods to assert the distance
Based on objects closer and larger like the sun and an eclipse on Jupiter we have ability to know what the light source should be seeing and then how long it takes till we see what we should see , and determine the delay is the speed of causality
What we see to what happens far away + what happens far away traveling back to our eyes is a round trip
If we somehow could one day make the trip to alpha proxima and see the earth from what we won’t know is 0-8.4 years ago which by convention we call a distance of 4.2ly away, actually 4.2 (averaged light years) , we STILL wouldn’t know the answer as when we move from one location to another , even in the same IRF, We don’t know how it impacts our own clock
So let’s temporarily assume that alpha proxima light instantly travels to earth and earth’s light takes the whole 8.4 years to reach the star. And we get hung up by saying we aren’t really looking at 4.2 years ago after all! What does that mean? What does that change communication-wise, it still takes 8.4 years either way to communicate with the Star. By goin to the star then would we be living in a different time than we thought, the same as earth’s ?
This is confusing to think about but if this were the convention we use instead , we would infer yes and no…. The voyage to the star took us , relative to earth , ignoring our own clock synchronizations, 4.2 years deeper into the future for earth than we expected it would …:. But that doesn’t matter because we might be 4.2 years into the future but we have to wait 8.4 years to see the earth’s light so it’s as if we were not 4.2 years forward in time and saw the light of an earth 4.2 years into the past
Or maybe I am missing the whole point , MAYBE the Question of “what time is it on alpha proxima at the time exactly they they see it’s 2025 on planet earth” is a question that is not answerable at all… simply altogether ,
simultaneity is just a convenient way for us to make sense of pairing times of different locations which honestly don’t sync and don’t have to sync period.
Then for earth it’s “omg we can see what this star is doing almost in simultaneity with us , we can tell the star to let us know any info they see we will get an immediate alert ! But …. That info of excitement takes 8.4 years to reach them … communication is a 2-way process . Or maybe that’s the lesson here …. Moreover it wouldn’t even matter if the directions where light travels at c/2 vs instant shifts around in such a way that the 2-way pathways remain average c … even if Proxima Centauri is continuously moving or the directions are shifting because if this isn’t altering the 2-way speed of light then the synchronization of all clocks will be such that preserves the fundamental 2-way constant to the extent the one-way differences change, if the one-way speeds are different.
One-way communication renders time lapse irrelevant, is that a true statement?
ESponge2000 said:
we don’t even know
We do know, it's a convention, and you've been told this numerous times in all of your threads.
I think I’m finally getting it. Relativity of Simultaneity for different locations, regardless of IRF being assumed to be the same or not, has no confirmed absolutes. We make assumptions only for practicality to make it easier to work with the observations which are that observed distances in an IRF obey the 2-way signal fundamental maximum speed limit, nothing more nothing less. Outside that, there is no relevance to any absolute time at any location B that holds any absolute meaning to a time at location A, other than obeying the causality 2-way limit
What that means is if we see there is a clock right now with a telescope on alpha proxima that indicates its the year 2021, we can affirm that any relevant time paired to us now, if any, in any convention, will sensibly be one that’s at least on or after 2021 if it’s in the same IRF
But even This criteria assumes “light has a ‘true’ one-way velocity ! Which is not affirmed either !!! In other words the answer to what time is it “right now” on alpha proxima can be a question with no
Answer at all that doesn’t state the use of 2 conventions
Convention 1: light has a true one-way velocity
If convention 1 is assumed,
then
Convention 2 applies,
else
there’s just us people making up a framework of simultaneities for practicality purposes
Convention 2: the true one-way velocities for same IRF must average A and B in opposite directions for any certain distance X in a single IRF where (X/A + X/B ) = 2X / c (units of time).
And standard convention A=B=c
Almost like … you are given a same flight flies back and forth between New York and Paris and only takes 60 minutes between arriving and redeparture.. at each. Assume Paris changed its time to a secret other timezone … we just know the time lapse between each time this plane arrives in New York. Paris keeps a separate log of time lapse between each time the same plane arrives in Paris.
Do we have enough info to calculate the jet stream ? Nope
There is an important difference between this aircraft example and one-way light speed measurments: The aircraft is following a timelike worldline along which proper time is defined. Thus we can put a clock on the plane to directly measure the proper time (along that worldline) between takeoff and landing events, and calculate the jet stream from that.
Correct but that’s why I said the only info in the flight problem hypothetical is the time, interval times between the round-trip, and the Timelapse at Paris without the Paris clock making sense …. I did that on purpose .
In reality obviously we say airplane speeds are too low for SR to be taken seriously so it’s Newtonian style where one time is defined as The Clock
No, we know there isn't any such thing as a "true" one-way speed of light. The one-way speed of light is a convention, not a physical quantity.
In other words, the two-way speed of light is a physical quantity--although even there care is needed in how it's specified and measured.
I don't know what you mean by this.
Only if you properly constrain them using consistent premises and math. You're not doing that. You need to.
We know there isn’t a true one-way speed of light ? Or we don’t know the answer to whether there is or isn’t one?
ESponge2000 said:
We know there isn’t a true speed of light ? Or we don’t know the answer to whether there is or isn’t one?
Go read the first sentence of my post #14 again. It doesn't say either of these things. Read carefully, paying attention to all the words.
A uniquely defined one-way speed of light is incompatible with the theory of relativity. We do not know of any theory that is compatible with a uniquely defined one-way speed and also with observations of reality.
I’m overthinking it, I think you mean we don’t attempt to deal with if there is or isn’t a true speed of light in one direction because we know it’s irrelevant to how SR interacts with us … we know we can apply a convention and the math will work as it’s supposed to
It better said, it really doesn’t matter what convention you apply, among any number of valid ones, as far as calculating the results that we are able to scientifically test
No, @PeterDonis is saying the same thing I did, that a unique definition of the one-way speed of light (or indeed, anything) is incompatible with relativity. We almost always assume isotropic speed because the maths is much simpler and easier to interpret, but we are free to assume otherwise and we do not become more right or wrong if we do so.
Isn’t that the same thing i said ? You said Incompatible I said extraneous because incompatible implies something more than extraneous.
A cable TV remote is incompatible with an iPhone, it has no use in anything to do with an iPhone .
What paint you use for a Honda Civic would be extraneous to how well it drives but it’s not incompatible because it can go on the car it just doesn’t matter if it’s green or orange
I would think the latter is more the case for the speed of light convention
ESponge2000 said:
I’m overthinking it
You're thinking instead of just reading what I actually said. What I actually said is quite specific and clear. Read it.
Yes. That's why I said incompatible. If there is a uniquely defined one way speed of light, then relativity is wrong.
Well relativity under a hypothetical universal construct where speed of light is made to be “absolutely isotropic” and c , preserves relativity of simutaneity between different IRFs but with an absolute simultaneity for objects at rest with each other
Relativity under a hypothetical universal construct with “uniquely defined one way speeds of light”
Also preserves relativity of simutaneity for different IRFs and also for objects at rest in some directions but possibly not others …. For some directions merely perpendicular to where the one-way speed of light velocities are in contrast would be neutral lines of motion closer to isotopic … you can also have speed of light in one direction isn’t a constant velocity but shaped identically in the reverse direction to preserve the 2-way speed of light concern… these I think Ibix and Peter are saying are beliefs that have no support for how relativity works … this is all anyone’s guess.
The framework of relativity in its entirety … what makes it relativiry, follows that simply … clocks at different locations do not have “absolute” simultaneities, when objects in motion or signals convene on a same location, only then is there an absolute simultaneity
You are suggesting that there could be one true absolute frame with absolute simultaneity and a bunch of false frames with relative simultaneity.
Yes, but if the theory of relativity is correct then no experiment can identify the one true frame. Any inertial frame will do. You've failed the uniqueness requirement.
Simultaneity is a property of pairs of events not objects even in classical physics where there is no relativity of simultaneity.
Ahhh I see now!!! The part of relativity that we have to look globally and say which IRF is The simultaneity of absolute and the theory of relativity is firm on there is not an absolute resting frame. With that theory there is no assertion of unique absolute one-way directional speed of light because that would violate the core principle that “there is no master resting frame over another!” Each Simultaneity in physics only exists independently for each one single point in space,
Other than that we just have a range of time values across locations, the range being such that time at other locations must satisfy that light to and from travels at the cosmic speed limit. Like we would say with certainty it’s not the year 1500 on the other side of my backyard because light to and from it being merely instantaneous, the time range is less than milliseconds of uncertainty…
So
Each object is an independent clock… always at rest with oneself, non-reconciliable to all remaining objects’ other clocks, and where time reconciling is done only among things that are convened in a common location.
I have a friend named Andy and a friend named Jonah. They meet for lunch without me. Then Andy calls to tell me he met with Jonah for lunch. With “absolute time precision” there is no reconciliation of what time they met for lunch, at the nanosecond level, to my clock. Because light round trip
Is merely instantaneous and atomic clocks are not precise to a nanosecond level, the range of discrepancy due to SR is so miniscule we can ignore the discrepancy and forge an absolute clock
But if we want to go to absolute precision we have none.
I also don’t know to the nanosecond level if the time on Andy’s clock when he called me is what it would have been if some synch was attempted earlier between my location and where he called me from . And all I do have simultaneity for is my clock …(im always at rest) , And the electromagnetic signal of Andy’s voice which reached my location at c from traveling through a cable from the entry point of either a router or a 5g tower … is absolute time comparable.
Later, I meet Andy in person , at only that moment , Andy’s clock and mine have an absolute reconciliation, if Andy and me had earlier met each other and synched our clocks and assuming our clocks have perfect atomic flawless precision, According to relativity , our reconvening tells us with absolute precision which one of us underwent more changes in inertia, the one who did will have a clock a few nanoseconds if that … slower
ESponge2000 said:
unless there’s a place in theory of relativity that events at other locations are not real with regard to ANY time reconciling our local clock … and ONLY become real when the photons reach our point location, and then it is that which is formulated on distance and the speed of light constant…
Unless you can define it, the word "real" is just philosophical mumbo jumbo. Stick to experimental predictions instead.
If events make the transition from "unreal" to "real" as our past light cone sweeps past them, that fact has no experimental consequences.
ESponge2000 said:
and that when we change locations we never change locations , we only change inertial frames but with respect to ourselves we are always at rest
This does not make much sense. An inertial frame is basically a coordinate system. You can use a coordinate system without being at rest in that coordinate system. You are not obliged to use a (non-inertial) coordinate system that is anchored to your feet.
No, there is no such thing in relativity.
Is a convention, not a physical thing. The urge to keep thinking of it as a physical thing, as something "real" instead of just a convention, is something that needs to be unlearned if you are going to really understand relativity. You need to really internalize the fact that there is no such thing as "what time it is now" for you on a clock that is spatially separated from you. There just isn't. You can adopt a convention for such things for describing events and doing calculations, but such a convention has no physical meaning. Please think about that carefully. You have been going round and round in this thread trying to give a physical meaning to something that has none.
I am getting that it’s a convention, you’re right, but I think I meant rather “the signal received by me at my location of a time showing on Andy’s clock when i answered Andy’s call”, would not be a convention. But also what would not be a convention is the time for Andy at Andy’s location when Andy called me … because it’s the same clock.
The convention is reconciling the time the signal was transmitted to the time it was received, For either location you have one and not the other…. For my location I can, however, choose a convention. The most common one being c velocity all directions. Then we take for me :
The time on my clock I receive the signal of a time on Andy’s clock after a tone we both hear over the phone the same signal, i then adjust to my time the value of (1-v/c)*time where time set equal to the light-timeunit which is actually a distance, and where if we are not in relative motion then v=0… what I mean is a distance of 1 foot would be referred to as 1 light-nanosecond …. For a signal 1 foot distance away by convention we adjust by a nanosecond to my clock to assume a simultaneity that doesn’t REALLY exist.
If we are about 5000 feet away (1.6km
Away) and light travels about 1 foot per nanosecond and we are measuring my clock in nanoseconds and we are at v=0 then this means by convention my clock time adjust 5000= By convention “the time at my location corresponding to the now shown on Andy’s clock at Andy’s location when Andy sent signal
because at that time I receive the signal we calculate that the signal is broadcasting a past event on my timeline that occurred by convention, 5000 nanoseconds ago…
But ALL of this is convention ….. as stated by Peter, there is NO WAY to reconcile what time it is NOW in 2 different locations
something to think about … if something is 4 light-years away from us …. It is a defined absolute distance relative to our perception of length …. We people created this terminology … we say a light-second means roughly 300,000km
But this terminology already uses a convention because we are implying light IS traveling this distance in this time in each direction . That assumes that convention or else it can’t be taken literally. In other words how many seconds does it take light in a vacuum to travel 1 light-second (aka 186,000 miles) is actually a trick question. The answer is not 1 second unless the question states to apply a convention. But that’s human terminology
a true literal light-second meaning a true speed of light in one second times t would imply a distance we can’t calculate
But that also means our world works by perception is reality. Next time I get pulled over for speeding on the highway and try telling the cop that he can’t be certain on the time stamp because he can’t identify the correct nanosecond I was speeding, the judge will not take my defense because it is an “unreasonable defense”.
Reasonable transparency : based on the way everyday communication works, it is clear regardless of relativity differences our clocks at a level of all times material to our daily actions forge with a Newtonian model of absolute time , for the level of precision that is reasonable, the proof being for instance a good driver doesn’t get into accidents because of special relativity. And perfectly reasonable for an officer to use language “the car was over here when the other car was over here, a witness on another car agrees they saw this happen at the same time as me”
In fact the prosecutor if they brought in a physicist as an expert witness , The physicist would testify to the court that the units of time that affect SR are below the threshold of altering the perception of an absolute time, over a distance threshold significantly farther than the ones concerning highway traffic. So would it be an accurate statement that SR is not a reasonable defense? Correct your honor.
Yes, it would, because "the time showing on Andy's clock when I answered Andy's call" is a convention.
What would not be a convention would be "the time showing on Andy's clock when he emitted the light signal that I receive at a certain time on my clock". But that is not the same thing as "the time showing on Andy's clock when I answered Andy's call". Think carefully.
That's true, this is not a convention, because it's a time at Andy's location of an event at Andy's location. But it's not the same thing as "the time showing on Andy's clock when I answered Andy's call"--the latter is a convention, because it's assigning a time on Andy's clock to an event that is at a different location. Any such time is a convention.
No, it's not an "absolute distance". There is no such thing in relativity.
Not as far as physics goes, no. The physics of how the cop's radar detector works is the same whether the judge accepts your argument or not.
  • · Replies 26 ·
  • · Replies 67 ·
  • · Replies 59 ·
  • · Replies 25 ·
  • · Replies 25 ·
  • · Replies 34 ·
  • · Replies 35 ·
