System not booting with ati 9800 pro
  • Thread starter Thread starter Tom McCurdy
    System
The discussion centers on compatibility issues between the ATI Radeon 9800 Pro 256 MB graphics card and the Asus K8V SE Deluxe motherboard paired with an AMD 3700 64-bit processor. Users report that the system fails to boot with the 9800 Pro installed, despite the card functioning correctly in a different motherboard. Suggestions include checking BIOS settings for IRQ conflicts and ensuring the graphics card is properly connected. The consensus indicates a likely compatibility issue between the ATI card and the Asus motherboard.
  • Understanding of BIOS settings and configurations
  • Knowledge of IRQ (Interrupt Request) management
  • Familiarity with AGP (Accelerated Graphics Port) technology
  • Experience with troubleshooting hardware compatibility issues
  • Research how to configure BIOS settings for AGP graphics cards
  • Learn about IRQ conflict resolution in Windows operating systems
  • Investigate custom driver solutions for ATI Radeon 9800 Pro compatibility
  • Explore power supply requirements for older graphics cards
This discussion is beneficial for hardware enthusiasts, PC builders, and technicians troubleshooting graphics card compatibility issues, particularly with older Asus motherboards and ATI graphics cards.
Tom McCurdy
I have a Asus k8v se deluxe motherboard with a amd 3700 64 bit 754 socket processor. When putting in ati radeon 9800 pro 256 mb card, the screen stays blanks and nothing boots. I have 2 separate k8v motherboards and this happens with both, but when I use the card in my older soyo motherboard it works just fine, so I know its not a problem with the card being broke. All other video cards I have work in this motherboard with no problem. I have read somewhere that the 9800 pro has problems with some power supplys, so i tried a couple different and the same thing happens with all of them when trying to boot it with the k8v motherboard. All power supplys I tested work with the card in my older soyo motherboard, and nothing seems to work with my asus. That is why I am starting to suspect its a compatibility issue with this certain motherboard. Just wondering is there is anything i can do or any reason why this card will not work with this motherboard. Thank you for your time.
Computer science news on Phys.org
Is there a jumper or bios setting to switch from onboard or PCI graphics to AGP? Have you tried updating the motherboard bios?
I have upgraded the Bios and i assume that it is already set for agp since that is the only type card i have used in the board since I've gotten it.
Go into your bios and make sure that your graphics card is not holding a conflicting IRQ number. If it is on the same IRQ channal as say your hardrive...etc.. it could cause your system to misperform and possibly not boot.
Using the same IRQ shouldn't matter if APM is turned on, which usually is the case with Windows.
Yes, it is most likely you're motherboard. I have had issues with my older ASUS and its compatibility with GeForce. As I am sure there are many people with the same hardware configuration as yours, your best bet is to Google for an answer. Usually, when such a problem arises, people create custom drivers to compensate and rectify any issues that ASUS are not promptly willing to do.
is the speaker conected to the motherboard ? (not to the audio card)
Sometimes if the video card isn't conected you should hear somenthing like
beeeeep bep bep bep...
  • · Replies 25 ·
14K
  • · Replies 21 ·
