System of differential equations with exponential terms
9 replies · 2K views
MaxManus
Find the general solution of
[tex]\dot{x}[/tex] = x + e^{2t}p [/tex]
[tex]\dot{p} = 2e^{-2t}x - p[/tex]
I know how to solve systems with constant coefficients using eigenvalues and eigenvectors, but what should I do in this case?
Hello Max. Here's a challenging way: try it with power series. I did for the IVP:
[tex]x'=x+e^{2t}p,\quad x(0)=1[/tex]
[tex]p'=2e^{-2t}x-p,\quad p(0)=1[/tex]
and obtained the plot below which agrees nicely with the numerical results cus' I actually plotted them both and they're right on top of one another. Also,I'm no expert so may be an easier way to solve this. :)
Thanks, but we have not learned power series, I looked up the method, but I can't solve the system. Did you find the solution?
The book says
[tex]x = Ae^{(1+\sqrt{2})t} + Be^{(1-\sqrt{2})t}[/tex]
[tex]p = A\sqrt(2)e^{(\sqrt{2}-1)t} -B\sqrt{2}e^{(-\sqrt{2}-1)t}[/tex]
The book says
Well not that solution but a purist would say the power series is the solution although not in closed form like the above. I don't know how to arrive at your solution.
Find the eigenvalues and eigenvectors of [[1,exp(2t)],[2*exp(-2t),-1]]. The eigenvectors will be functions of t, but that shouldn't stop you from treating this the same way you would if the matrix were numerical.
Ok. I see now. Thank you. I assume Max got it too. Personally I think Max should work out all the details in nice pretty latex and post it but I don't want to bug him about it. :)
Eigenvalues
[tex](1-\lambda)(-1-\lambda) - e^{2t}2e^{-2t} = 0[/tex]
[tex]\lambda = \pm- \sqrt{3}[/tex]
for [tex]\lambda = \sqrt(3)[/tex]
[tex](1-\sqrt{3})x + e^{2t}y = 0[/tex]
[tex]v_1 = \begin{array}{c} 1\\ (\sqrt{3}-1})e^{-2t}\\[/tex]
for [tex]\lambda = -\sqrt{3}[/tex]
[tex](1+ \sqrt{3})x + e^{2t}y = 0[/tex]
[tex]v_2 = \begin{array}{c} 1\\ (-\sqrt{3}-1})e^{-2t}\\[/tex]
[tex]x = Ae^{\sqrt{3t}} + Be^{-\sqrt{3t}[/tex]
[tex]p = A(\sqrt{3}-1)e^{(-2+\sqrt{3})t} - B(\sqrt{3}+1)e^{(-2-\sqrt{3})t}[/tex]
Not sure what I did wrong, but tried calculating the eigenvalue several times, but that is not important. Thanks again to both of you for all the help.
A somewhat more primitive way: differentiate the first equation again to get
[tex]x''= x'+ 2e^{2t}p+ e^{2t}p'[/tex]
From the second equation,
[tex]p'= 2e^{-2t}x- p[/tex]
Putting that in,
[tex]x''= x'+ 2e^{2t}p+ 2x- e^{2t}p= x' + 2x[/tex]
Solve
[tex]x''- x' - 2x= 0[/tex]
for x(t).
Again, from the first equation,
[tex]e^{2t}p= x'- x[/tex]
so that
[tex]p= e^{-2t}(x'- x)[/tex].
Your solution is correct, the book is wrong. Try to plug in back into the original equations
Putting that in,
A term e2tp is missing.
ehild
