System of Linear Differential equations
Xyius
(I do not know how to make matricies with LateX, so where the semi-colon is denotes a new row!)
t \vec{x'}=[-4,2;2,-1]\vec{x}
The part that throws me off with this problem is the x' vector being multiplied by t! I know if the t wasn't there, all I would need to solve is det(A-(lamda)I)=0
consider what you would try in the single variable case and how you could generalise it to the system
also here's how to do a matrix
t \vec{x}'=\begin{pmatrix} -4 & 2 \\ 2& -1 \end{pmatrix}\vec{x}
Thanks for showing me how to do a matrix :)
I still do not understand! I tried to plug in the assumption that the solution is..
\vec(x)=\vec(u)e^{\lambda t}
And I get..
(A-\lambda t I)=\vec(0)
Don't know where to go. :\
Thats' because the solution isn't an exponential. That's only for "constant coefficient" d.e. What you have here is a Cauchy-Euler equation but you can still reduce it just as you have constant coefficient equations.
This matrix can be diagonalized. (Every symmetric matrix can.) First find the eigenvalues \lambda_1 and \lambda_2. Find corresponding eigenvectors and use them as columns to form the (invertible) matrix P. Then, using A as this matrix, P^{-1}AP= D where
D= \begin{pmatrix}\lambda_1 & 0 \\ 0 & \lambda_2\end{pmatrix}
If you multiply both sides of the differential equation, tx'= Ax, by the matrix P^{-1}, you get P^{-1}tx&#039;= tP^{-1}x&#039;= P^{-1}Ax= P^{-1}A(PP^{-1})x[/tex]= (P^{-1}AP)P^{-1}x= DP^{-1}x<br /> <br /> Now Let y= P^{-1}x and the differential equation becomes <br /> ty&amp;#039;= Dywhich can be written as the two uncoupled equations <br /> ty_1&amp;#039;= \lambda_1y_1<br /> and<br /> ty_2&amp;#039;= \lambda_2y_2<br /> <br /> Those will be easy to solve and then x= Py.
Thank you very much. I will need to crack open the old linear Algebra book as a refresher on diagonalization. :)
I got this as a solution..
x_1=c_1-2c_2t^{-5}
x_2=2c_1+c_2t^{-5}
I plugged them back into the original equation and it is indeed correct. Thanks again :D
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
