System of Two Dimensional First Order ODE
The discussion centers around finding all solutions to a system of two-dimensional first-order ordinary differential equations (ODEs) represented in matrix form. The original poster explores the eigenvalue characteristic equation and the implications of repeated eigenvalues on the general solution.
  • The original poster attempts to derive the general solution using eigenvalues and eigenvectors, questioning whether they have found all solutions and the nature of infinitely many solutions. Some participants clarify the relationship between eigenvalues, eigenvectors, and the dimensionality of the solution space.
Participants have provided guidance on the general solution and the concept of infinite solutions due to arbitrary constants. There is an ongoing exploration of the completeness of the solution and the necessity of detailing the work presented, with some participants addressing concerns about the theoretical understanding of the methods used.
The original poster expresses uncertainty about the theoretical justification for certain steps in their solution process, particularly regarding the creation of a new vector to avoid duplication and the implications of multiplying by \( t \). There is an emphasis on the importance of showing all work as per the professor's expectations.
karencorson
Find all solutions to [dx/dt; dy/dt] = [1, 2; 0, 1]*[x; y]
the eigenvalue characteristic equation: det(A-λ*I)=0
This results in real, repeated eigen values: λ1,2 = 1
for λ1 = 1, (1-1)k1 + 2k2 = 0
choose k1 = 1 then k2 = 0 gives us the eigenvector K1 = [1, 0]
this gives part of the general solution X1 = [1, 0]*e^t
to get a second solution we create a new vector P to avoid duplication
with K1 = [1,0] and P = [p1; p2] we solve (A-λ2*I)*P=K
(1-1)*p1 + 2*p2 = 1
choose p1 = 0 then p2 = 1/2
this gives us the solution X2 = [1;0]*t*e^t + [0;1/2]*e^t
putting it together X = X1 + X2
[x; y] = c1*[1, 0]*e^t + c2*([1;0]*t*e^t + [0;1/2]*e^t)
or
x = c1*e^t + c2*t*e^t
y = (1/2)*c2*e^t
Have I found all the solutions to this system? I think this is the general solution, is this all they are asking for?
If we multiply an eigenvalue by some multiple to get a new eigenvalue, is it really possible to find all the solutions? It seems like there would be infinitely many..
You have the general solution. You have two arbitrary constants which is what you would expect. There are always infinitely many solutions because in a homogeneous system a constant times a solution is still a solution.
The "fundamental theorem" here is that the set of all solutions to an n order linear differential equation or system of differential equations forms a vector space of dimension n. That is, there exist n independent solutions such that the general solution is a linear combination of those n solutions.
Here, you have two first order differential equations which is equivalent to a second order equation. Any solution can be written as a linear combination of two independent solutions. Since you have two distinct eigenvalues, solutions corresponding to those eigenvalues are independent and the general solution is a linear combination of them.
By the way, you are NOT "multiplying an eigenvalue by some multiple to get a new eigenvalue", you are multiplying an eigenvector. The set of all eigenvectors, corresponding to a given eigenvalue, forms a vector space- yes, you can get all eigenvectors by multiplying.
"It seems like there would be infinitely many". Yes, and you have an infinite number of constants, c1 and c2, to multiply by.
OK that makes sense.
So does this seem like a complete solution? My prof stresses showing all of our work, do you think I can go in more detail? I am afraid that the more detail I provide the more ammunition I am giving the grader to take points away since the theory behind the procedure isn't 100% clear to me..
For instance we create a new vector P to avoid duplication, I know we do this because it works but I don't understand why it works. I would think that multiplying by t would change the solution.. It must have something to do with setting: (A-λ2*I)*P=K
  • · Replies 16 ·
