Undergrad Take a limit in this 2 equation system of 1st order ODEs
The discussion centers on solving a system of first-order ordinary differential equations (ODEs) represented by equations (1.14) and (1.15), with a limit condition for κ1 << κ2. The user seeks assistance in understanding how to eliminate the variable c2 from these equations to derive the solution presented in (1.16). The conversation highlights the need for decoupling the system of equations and making specific assumptions to simplify the problem, as the original author's explanation lacks clarity.
  • Understanding of first-order ordinary differential equations (ODEs)
  • Familiarity with the concepts of decoupling systems of equations
  • Knowledge of limit conditions in mathematical analysis
  • Ability to interpret mathematical notation and equations
  • Study methods for decoupling systems of first-order ODEs
  • Learn about limit analysis in differential equations
  • Explore techniques for solving systems of equations with multiple variables
  • Review examples of similar ODE systems to understand solution strategies
Mathematicians, students studying differential equations, and researchers working on systems of ODEs will benefit from this discussion.
xxxyyy
Hello,
I'm having a problem with this system. Ignore the physics.
I have the feeling it should be tremendously easy... but I can't figure it out.
I don't know how to extract it from the pdf so I'll post just the these 2 pages.
https://ufile.io/39ovq
The equations are (1.14) and (1.15), the definition of Δ is in (1.13) (don't bother with the integral) for α and β go from 1 to 2.
The limit is for κ1 << κ2. n1 and n2 are just integer numbers.
The solution is in (1.16).
Thanks for the help.
I cannot figure out how to display your pages. Can you try a different site like imgur, with just jpeg of the problem you are having trouble with. Can you also post your attempt at the solution, as well?
I was able to open the file, but the author's description of what he did isn't very enlightening. He mentions eliminating ##c_2## from equations 1.14 and 1.15, but doesn't give any insight into how he did this. The only thing I can think of is decoupling the system of differential equations to get the solution of the system (which is pretty involved), and then making additional assumptions to get the approximations he shows.
Here are just simple images.
https://ibb.co/vsqnJW3
https://ibb.co/yNMNgK3
vsqnJW3
yNMNgK3
and here the exact solution (if I didn't do any mistakes...) of the system for c1, (1.18), don't bother with the other junk.
https://ibb.co/pRDxKhc
pRDxKhc
14K
13K
10K
