Taylor Series - Range of values
The discussion centers on determining the range of x values for the Taylor expansion of exp(x). The first four non-zero coefficients of the expansion are straightforward to calculate, but the convergence of the series is the main concern. The ratio test is highlighted as a method to assess the convergence of the Taylor series in terms of x. It is noted that the Taylor series for exp(x) converges for all real numbers, meaning it is valid everywhere. Understanding convergence is essential for identifying the appropriate range of x values for the expansion.
wombat4000
im being asked for the first 4 non zero values for the taylor expansion of exp(x) which is simple, but then it asks for the range of x values that are valid for the expansion.
i have never come across ths before - any idea?
From the first four coefficients of the taylor expansion you can guess what the nth coefficient is going to be. Is there then some test you can use to find out when a sum (don't worry about it being a taylor series!) converges?
ratio test? integral test?
but how will working out if the sum convereges help with obtaining the valid x values?
The ratio test is useful for calculating when taylor series converge. Each of the terms of your sum is in terms of 'x' so the ratio test tells you when the sum converges in terms of x.
the question doesn't mention sum or convergence?
The taylor series expansion is going to be valid where the sum converges, or alternatively you can just write that the taylor series expansion for exp is valid everywhere if you've been told this fact.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
10K
