Taylors Series/Remainder for ln(x) about x = 1
  • Thread starter Thread starter jegues
The discussion focuses on the convergence of the Taylor Series for ln(x) around x=1, specifically for the interval [1/2, 2]. The Taylor Series is expressed as ln(x) = (x-1) - (1/2)(x-1)² + (1/3)(x-1)³ - ... + R_n(1,x), where R_n(1,x) represents the remainder term. The analysis reveals that for x=1, the series converges to 0, while for 1/2 ≤ x < 1, the remainder term approaches 0 as n approaches infinity, confirming convergence. The discussion also explores the behavior of the remainder term R_n(1,x) in different cases, emphasizing the importance of bounding the term (x-1)/z_n.
  • Understanding of Taylor Series expansion
  • Familiarity with limits and convergence concepts
  • Knowledge of the natural logarithm function ln(x)
  • Basic calculus, including differentiation and remainder terms
  • Study the properties of Taylor Series and their convergence criteria
  • Learn about the Squeeze Theorem and its applications in calculus
  • Explore the concept of remainder terms in Taylor Series, specifically Lagrange's form
  • Investigate the behavior of ln(x) and its derivatives over the interval [1/2, 2]
Students studying calculus, particularly those focusing on Taylor Series and convergence, as well as educators seeking to clarify concepts related to logarithmic functions and series expansions.
jegues
Determine whether the Taylors Series for ln(x) converges to ln(x) around x=1, for x [1/2, 2].
f(x) = ln(x)
f^{1}(x) = \frac{1}{x}
f^{2}(x) = \frac{-1}{x^{2}}
f^{3}(x) = \frac{2}{x^{3}}
f^{4}(x) = \frac{-6}{x^{4}}
\vdots
f^{n}(x) = \frac{(-1)^{n-1}(n-1)!}{x^{n}}
So,
ln(x) = (x-1) - \frac{1}{2}(x-1)^{2} + \frac{1}{3}(x-1)^{3} - \cdots + \frac{(-1)^{n-1}}{n}(x-1)^{n} + R_{n}(1,x)
Where,
R_{n}(1,x) = \frac{(-1)^{n}}{(n+1)} \cdot \left( \frac{(x-1)}{z_{n}} \right)^{n+1}
We can see that the second term (The one with z_{n} in it) is the one that causes problems. It is trivial to show that the limit as n goes to infinity of the first term is 0. (We proved it in class)
So there are 3 cases that we should consider:
Case 1: x=1, everything will converge to 0.
Case 2: \frac{1}{2} \leq x &lt; 1
It follows then that,
\frac{1}{2} \leq x &lt; z_{n} &lt;1
We can use, \frac{1}{2} \leq x &lt; 1 to try to gain for information about the term that is causing problems with our remainder.
\frac{1}{2} \leq x &lt; 1 \Rightarrow \frac{1}{2} - 1 \leq x-1 &lt; 1-1 \Rightarrow \frac{-1}{2} \leq x-1 &lt; 0 \Rightarrow \frac{-1}{2z_{n}} \leq \frac{x-1}{z_{n}} &lt; 0
Looking back at,
we can see that,
z_{n} \geq \frac{1}{2} or 2z_{n} \geq 1
Working with this some more we can see that,
\frac{1}{2z_{n}} \leq 1 \Rightarrow \frac{-1}{2z_{n}} \geq -1
Therefore we can say that,
-1 \leq \frac{-1}{2z_{n}} &lt; \frac{x-1}{z_{n}} &lt; 0
i.e. -1 &lt; \frac{x-1}{z_{n}} &lt; 0 \Rightarrow |\frac{x-1}{z_{n}}| &lt; 1
This is what our professor wrote down in order to prove the following,
|R_{n}(1,x)| = \left| \frac{(-1)^{n}}{n+1} \cdot \frac{(x-1)^{n+1}}{z_{n}} \right| &lt; \frac{1}{n+1} \cdot (1)
Therefore,
lim_{n \rightarrow \infty} |R_{n}(1,x)| = 0 \Rightarrow lim_{n \rightarrow \infty} R_{n}(1,x) = 0.
I'm confused about how he got rid of that unwanted term,
\left(\frac{(x-1)}{z_{n}}\right)^{n+1}
by using the inequalities stated above. He seems to jump around a lot and it's hard to follow.
EDIT: Looking at it again, he first shows that,
Now if he can prove that this is also larger than -1 it will be a small negative number inbetween (0, -1) and no matter what power we raise it to, let's say n+1, it will still be really close to 0.
Is this his attack?
Can someone try to explain his reasoning another way or offer me some insight? If I tried to do this problem without looking at my notes I don't think I'd be able to reasonably conclude that,
For Case 2: \frac{1}{2} \leq x &lt; 1
Any advice/tips/ideas/insight would be greatly appreciated! (After I will attempt case 3)
Thanks again!
Case 3: 1 &lt; x \leq 2 seems to make some more sense so I'll attempt it in this post.
It follows that,
1 &lt; z_{n} &lt; x \leq 2
Again, we can use, 1 &lt; x \leq 2 to gain more information about our problematic term in R_{n}(1,x).
One can see that,
0 &lt; x-1 \leq 1
0 &lt; \frac{x-1}{z_{n}} \leq \frac{1}{z_{n}}
From here we can see that,
\frac{1}{z_{n}} &lt; 1
So here's where I'm at,
0 \leq |R_{n}(1,x)| &lt; ?
We need to figure out an upper bound so we can apply squeeze theorem.
We know that,
\frac{x-1}{z_{n}} is less than 1 but larger than 0.
Hmm...
I'm not sure how I can find that upper bound I've been looking for. If I think of anything I'll simply edit this post.
Feel free to make any suggestions if you have any!
