Tchebysheff's Theorem questions (statistics)
  • Thread starter Thread starter TeenieBopper
    Statistics Theorem
The discussion revolves around two problems involving Tchebysheff's Theorem in statistics. In the first problem, the average diameter of dimes is 0.5 inches with a standard deviation of 0.01, leading to a lower bound of 75% for the number of coins expected to fall between 0.48 and 0.52 inches in a lot of 400 coins, calculated as 400 multiplied by 0.75. The second problem requires calculating the expected value and variance of a random variable Y, where the probability distribution is given, resulting in E(Y) = 0 and V(Y) = 1/9. The discussion emphasizes using Tchebysheff's inequality to compare the calculated probability with its theoretical upper bound, demonstrating that the bound is attained when k = 3. Overall, the thread provides insights into applying Tchebysheff's Theorem to practical statistical problems.
TeenieBopper
I have two different problems involving Tchebysheff's Theorem. Hopefully there isn't a rule about asking two different questions in one post.
Number 1
The US mint produces dimes with an average diameter of .5 inch and a standard deviation of .01. Using Tchebysheff's theorem, find a lower bound for the number of coins in a lot of 400 coins that are expected to have a diameter between .48 and .52.
μ=.5
σ=.01
k= number of standard deviations from the mean= 2
Tchebysheff's theorem:
P(|Y-μ|<kσ)>= 1- \frac{1}{k^{2}}
Plugging everything in, I get P(|Y-μ|<(2)(.01))>= 1-\frac{1}{2^{2}}
Simplifying, it becomes P(|Y-μ|<.02)>= .75
The lower bound of the probability of a coin being under two standard deviations from the mean is .75. What's throwing me is the lot of 400 coins. I don't know how to take the result of Tchebysheff's theorem and apply it to the sample. Or am I just overthinking it and I just need to multiply 400*.75?
Question 2
Let Y be a random variable such that
p(-1)= \frac{1}{18}
p(0)= \frac{16}{18}
p(1)= \frac{1}{18}
a) show that E(Y)=0 and V(Y)=\frac{1}{9}
b) Use the probability distribution of Y to calculate P(|Y-μ|>=3σ). Compare this exact probability with the upper bound provided by Tchebysheff's theorem to see that the bound provided by Tchebysheff's theorem is actually attained when k = 3.
P(|Y-μ|<kσ)>=1-\frac{1}{k^{2}} or P{|Y-μ|>=kσ)<=\frac{1}{k^{2}}
I thought I could just plug numbers into find E(Y) and V(Y). However, in order to get E(Y)= 0, I'd need k=0, which gives me an undefined fraction. Instead, using p(0)=\frac{16}{18}, I found k= \frac{3\sqrt{2}}{4}. But I don't know if this number is even useful.
Thanks in advance for any help I get.
The first problem asks you to determine the lower bound of the expected number of coins with diameters between .48 and .52, out of 400 coins. Note that such number is random.
You can think of this number as the number of trials of getting coins with such specification from 400 trials.
Under the assumption that each coin is produced independently from one another (or, each trial is independent from one another), this number is a binomial random variable with parameters:
n:=number of independent trials=400
p:=success probability=probability of getting a coin with diameter between .48 and .52. (the one you obtain by using Tchebysheff's Theorem is the lower bound of p, say, p')
The expected value of this variable is n*p>=n*p'. Since the problem asks you to determine the lower bound of the expected value of such number, then you have n*p'=400*0.75 as the answer.
For the second problem, do not get confused by 2b). Find the expectation and variance using usual formula for 2a).
For 2b), plug these values into Tchebysheff's inequality. Then, compare the lower bound of the probability with the actual value of the probability that you can get using the cumulated probability mass function (or by any logical way if it's too complicated; it's easy).
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 18 ·
