How does diffraction affect telescope magnification?
  • Thread starter Thread starter Emilyjoint
    Stars Telescope
The discussion centers on the relationship between diffraction and telescope magnification, specifically addressing why telescopes allow observers to see more stars than the naked eye. Participants clarify that while diffraction does enlarge images, it does not enhance visibility; instead, the key factor is the telescope's aperture size, which allows more light to enter and improves the ability to resolve fainter stars. The conversation emphasizes that understanding the physics of telescopes, particularly the role of aperture and resolution, is crucial for grasping how telescopes function compared to human vision.
  • Understanding of telescope optics and design
  • Knowledge of diffraction and its effects on image quality
  • Familiarity with the concept of aperture in telescopes
  • Basic principles of light and resolution in astronomy
  • Research the significance of telescope aperture size in light gathering and resolution
  • Explore the effects of diffraction on image clarity in telescopes
  • Learn about different types of telescopes and their optical designs
  • Investigate how light pollution affects astronomical observations
Astronomy students, amateur astronomers, and anyone interested in understanding telescope functionality and the physics behind observing celestial objects.
Emilyjoint
Vague class discussion. Stars are points and a telescope does not magnify them.
How then can more stars be seen with a telescope?
I know magnification for a telescope is fo/fe but that is not much help
Is it because diffraction makes bigger images?
Here's a hint. How does a telescope differ significantly from your naked eye?
The main thing about a telescope is that it magnifies.
That is what I think fo/ fe means
You are missing an important quality of telescopes.
I know that they cause diffraction which makes point sources larger. Is that what you mean.
Ps... I have looked on wiki for telescope magnification and could not find an explanation
Nope. You're over-thinking this. Go to the "telescope" thread and see if you can figure it out. I can't give you the answer (forum roles), but I can show you the way to good resources.
https://www.physicsforums.com/showthread.php?t=391086
I have just spent half an hour or so looking through that reference. It gives lots of advice about which telescope to buy...I already own a telescope (Meade)...but there is nothing to help me explain how I can see more stars !
"I am missing an important quality of telescopes"..."I am over-thinking this"... I don't get it... is there a straight forward answer ?
Do you have any other references that might help.
Is my diffraction idea wrong?
What are the critical physical qualities of the telescopes in that thread?
Thank you for your help
I have a telescope and am not looking for advice about which telescope to buy.
I am no wiser about how it is that more stars can be seen through a telescope.
My first and only idea was that diffraction make bigger images and I will stick with that in our class discussion.
Don't do that emily, because it is wrong. Which telescopes will show you more stars than others and why?
I think I am correct when I say that diffraction makes stars look bigger. We have done calculations to show what is meant by 'resolution' which is to do with separating images.
I also know the equation for calculating angular width to find the size of a point source.
I do not know how it is wrong that this explains how stars can be seen !
If they look bigger because of diffraction it sounds right to me.
Again, what qualities would you want in a telescope to show you more and more (fainter and fainter) stars?
they should have bigger diffraction patterns... I don't know... that is why I came here... for help.
That's not the answer. I'm trying to throw resources at you, but I can't simply give you the answer. Forum rules, sorry.
But am I correct in saying that the diffraction pattern will be larger ?
If so I can use that in my discussion, something will come of it
I do not understand your 'rules'
Do you think huge professional telescopes have large diffraction patterns, and that's why they can show more stars?
you tell me ! It sounds reasonable to me !...if it works
Emily, you already know that the telescope doesn't make the star larger. What else does a telescope do. Something that's different from what your eyes do.
We don't give out answers here. We will guide you, but you have to do the work.
I am lost ! I think that the telescope does make the image of the star larger...isn't that what the diffraction pattern is.
That is the only thing that I can think of that makes it possible to see more stars.
I know that I have to do the work...I realize that no one here is going to give me an answer... I do not need to be told that ! is this a physics forum ?
no one has been able to give a better explanation than mine... am I wrong?
Why is it better to have large telescopes??
Emily, is there a book to go with your class? If so, does it have a discussion on how a telescope works? It does not make stars appear larger. At least let that soak in.
The textbooks I refer to are by Muncaster(my favourite) Nelkon (a bible) and Duncan.
All explain optics and telescopes in great detail.
I have no difficulty with that theory. I am beginning to feel a little stupid...am I missing something so obvious.
How is it that more stars can be seen through a telescope?
Again: why might I prefer a larger telescope to a smaller one?
It might help to consider that a telescope and an eye work in ways that are similar. What are some of the differences though? What happens to your eyes when you go from a bright room to a dark one?
My original question was "how/why can more stars be seen with a telescope", not why should I have a larger or smaller telescope !
I am still in the position that I can see more stars because diffraction makes the images larger, this is undoubtedly correct and I will use this argument in my presentation and see what reaction I get.
Thankyou foryour help
The thing is that your eyes ARE basically a very small telescope. A usual telescope is usually much larger than the human eye. Why is that you think??
  • · Replies 125 ·
