How does insulating glass use vacuum or gas to reduce heat transfer?
  • Context: High School
  • Thread starter Thread starter zuz
    Vacuum
Insulating glass, commonly referred to as double glazing or triple glazing, utilizes a vacuum or gas-filled space between glass panes to significantly reduce heat transfer in buildings. While a true vacuum cannot maintain temperature, the design of insulating glass units (IGUs) effectively minimizes heat conduction. Typical IGUs consist of two or three glass panes, with thicknesses ranging from 3 to 10 mm, and may incorporate laminated or tempered glass for enhanced performance. This technology is already widely implemented in modern window designs to improve energy efficiency.
  • Understanding of thermodynamics, specifically the concept of heat transfer.
  • Familiarity with insulating glass unit (IGU) construction and materials.
  • Knowledge of window glazing techniques, including double and triple glazing.
  • Basic principles of atmospheric pressure and its effects on materials.
  • Research the manufacturing processes of insulating glass units (IGUs).
  • Explore the thermal performance metrics of double versus triple glazing.
  • Learn about the use of laminated and tempered glass in energy-efficient window designs.
  • Investigate advancements in gas fills (e.g., argon, krypton) used in IGUs for improved insulation.
Architects, builders, energy efficiency consultants, and homeowners interested in optimizing building insulation and reducing energy costs.
zuz
What is the temperature of a vacuum? Could this be used as an insulator in windows/homes?
Science news on Phys.org
Thermodynamically, temperature for a vacuum does not exist (there is nothing that can have a temperature).
In windows/homes it isn't practical to maintain a vacuum just for its insulating properties: withstanding the forces from the atmospherical presssure would require a massive construction.
Real vacuum flasks aren't really vacuum, they just lower the pressure between the bottles
Depending on context, a space with only black body radiation is often interpreted as a vacuum with a certain temperature T.
It already is. Some window double glazing (2 sheets of glass vacuum or air between) methods already do this
Air is a poor conductor of heat
from wiki
Insulating glass (IG), more commonly known as double glazing (or double-pane, and increasingly triple glazing[1]/pane), consists of two or three glass window panes separated by a vacuum or gas filled space to reduce heat transfer across a part of the building envelope.
Insulating glass units (IGUs) are manufactured with glass in range of thickness from 3 to 10 mm (1/8" to 3/8") or more in special applications. Laminated or tempered glass may also be used as part of the construction. Most units are produced with the same thickness of glass used on both panes[citation needed] but special applications such as acoustic attenuation or security may require wide ranges of thicknesses to be incorporated in the same unit.
Dave
  • · Replies 30 ·
  • · Replies 24 ·
  • · Replies 33 ·
