Comp Sci Template for STL in .h File: Error Fix
  • Thread starter Thread starter anonim
    C++
The discussion focuses on a template class definition in a header file, specifically addressing an error related to the declaration of a member variable. The error message indicates that 'T' is not recognized as a template, suggesting that the template parameter 'T' is incorrectly used in the line declaring 'Board'. Participants highlight the need to ensure that 'T' is properly defined as a template type before its usage. The conversation emphasizes the importance of correct template syntax and initialization within the class. Clarifying the template declaration should resolve the encountered error.
anonim
BAdapter: This class takes a template parameter and behaves like an adaptor class just like the stack or queue class of the STL. The parameter classes can be any STL class with a random access iterator.
in .h file I write like this:
C++:
namespace board{
    template <class T>
    class BAdapter : public AbstractB{
        public:
            BAdapter();
            BAdapter(int x){
                x=6;
                setSize(x);
            virtual void setSize(int receivedSize){
                int i,j;
                Board.clear();
                size=receivedSize;
                Board.resize(getSize());
                for(i=0; getSize()>i; i++){
                    Board[i].resize(getSize());
                reset();
            virtual bool loadGame(string fileName,char player,int game_mode){
                fstream file;
                int size2;
                int i,j;
                string line;
                bool flag=false;
                char state;
                file.open(fileName);
                if(file.is_open()){
                    file>>size2;
                    file>>player;
                    Board.clear();
                    Board.setSize(size2);
                    for(i=0; size2>i; i++){
                        file>>line;
                        for(j=0; size2>j; j++){
                            if(line[j]=='.'){
                                state='.';
                            else if(line[j]=='x'){
                                state='x';
                            else if(line[j]=='o'){
                                state='o';
                            Board[i][j].setRow(i);
                            Board[i][j].setColumn(j);
                            Board[i][j].set_cellState(state);
                    flag=true;
                    size=size2;
                    file.close();
                 return flag;
        protected:
            T<T<char>>Board;
Actually, I did not understand exactly what I was expected to do, but I get an error.
Error is:
‘T’ is not a template
T<T<char>>Board;
Maybe declare T somewhere?
  • · Replies 23 ·
9K
  • · Replies 16 ·
