sahashmi
- 96
- 18
- TL;DR
- A recent paper was published by Tim Maudlin discussing a rift between QM and relativity
The abstract is a pretty good tl;dr:DaveC426913 said:Maybe we could have a summary? Some aspect you want to talk about?
Well he does explicitly say “There is not merely a tension but an incompatibility between the predictions of quantum theory and Relativity”, so it does seem as if he is saying relativity is incompatible with QM.Nugatory said:The abstract is a pretty good tl;dr:
It is commonly remarked that contemporary physics faces a challenge in reconciling quantum theory with Relativity, specifically General Relativity as a theory of gravity. But "challenge" is too mild a descriptor. Once one understands both what John Bell proved and what Einstein himself demanded of Relativity it becomes clear that the predictions of quantum theory, predictions that have been verified in the lab, are flatly incompatible with what Einstein wanted and built into General Relativity. There is not merely a tension but an incompatibility between the predictions of quantum theory and Relativity, and what has to give way is the Relativistic account of space-time structure and dynamics.However, I’d recommend reading the whole thing now that you know where Mauldin is going with his argument.
Do note that the incompatibility that Mauldin identifies is with “what Einstein himself demanded of Relativity”. That’s not quite the same thing as “Relativity”.
What about your thoughts?! Isn't this a bad way to start a topic for discussion. "Here is a paper, go."sahashmi said:TL;DR Summary: A recent paper was published by Tim Maudlin discussing a rift between QM and relativity
Link to paper: https://arxiv.org/abs/2503.20067
Thoughts?
My thoughts echo the paper but I’ll summarize the pretty clear logical argument.martinbn said:What about your thoughts?! Isn't this a bad way to start a topic for discussion. "Here is a paper, go."
My thoughts from reading itsahashmi said:TL;DR Summary: A recent paper was published by Tim Maudlin discussing a rift between QM and relativity
Thoughts?
My first thought is "isn't QFT a theory that weakly reconciles GR and QM?" It is incorrect to say that GR and QM are not reconcilable, we could say that perhaps they are not completely reconcilable.sahashmi said:TL;DR Summary: A recent paper was published by Tim Maudlin discussing a rift between QM and relativity
Thoughts?
Not really. It's a theory that weakly reconciles special relativity and QM, by describing quantum phenomena in a way that's consistent with Lorentz invariance.javisot said:My first thought is "isn't QFT a theory that weakly reconciles GR and QM?"
Have you read the paper? The paper deals with GR, not SR.sahashmi said:Note that the paper argues that QM is incompatible with special and general relativity, not just GR
When one takes for granted all assumptions of realism or classicality, all classical theories that allow for violations of the Bell inequality must be non-local.javisot said:.... The last thing I thought is that the author's logic is built assuming that there is no theory without non-local influence capable of explaining all QM experimental data ....
OK, I'm only responding to these comments as they relate to EPR/Bell/Entanglement Experiments.WernerQH said:1. Polarization can be viewed as a property of the detector as much as that of a photon. It is usually inferred, attributed to a photon with hindsight, knowing the experimental setup (the "beam preparation"). What Bell's theorem shows is the impossibility of ascribing definite polarizations to photons in general.
2. My conclusion is that photons do not exist, at least not in the usual sense of quantum "objects" moving through space. In the Aspect et al. experiments excited calcium atoms lose a certain amount of energy, and a few nanoseconds later that energy is absorbed by atoms in the detectors. Quantum electrodynamics is silent about the whereabouts of that energy, other than that it is somewhere "in the field".
Why would we want to do that?javisot said:Let's deny the existence of QFT.
Obviously there is QFT, and ST and QG. I ask this for those who, like the author of the paper, claim that GR and QM are not compatible because one theory is local and the other is non-local, so are we stuck?PeterDonis said:Why would we want to do that?
They must only be classically nonlocal. Note that Bell's theorem is not a theorem about quantum mechanics, but about classical local hidden variable theories. Thus the viaolation of the Bell inequalities only demonstrates that quantum mechanics is not a classical local hidden variable theory.Lord Jestocost said:When one takes for granted all assumptions of realism or classicality, all classical theories that allow for violations of the Bell inequality must be non-local.
No. He argues that any theory that has locality built into it and relativistic space time cannot explain the results. Thus, this includes special relativity. The paper is very clear on this.javisot said:Have you read the paper? The paper deals with GR, not SR.
The author's words can cause confusion since he repeatedly uses "relativity" and "general relativity" to refer to the same thing.
weirdoguy said:Note that QFTs exist and are one of the most successfull theories to date, so arguing that QM may not be compatible with SR is, well, just crackpottery.
EDIT: Of course I'm not saying that non-relativistic QM is compatible with SR, since, well, that's obvious it's not, but there is also nothing to complain about, because it's non-relativistic![]()
This distinction between “realistic” and “non realistic” is a misnomer. Science is about explaining what we observe. What we observe is “real”. No one who believes in “non realism” has ever managed to explain what that even meansLord Jestocost said:When one takes for granted all assumptions of realism or classicality, all classical theories that allow for violations of the Bell inequality must be non-local.
