Tension Force Parallel to the Ground (Perpendicular to Gravity)
Redfire66
A block on a ramp is held by a tension force parallel to the horizontal (not the ramp). If originally the tension force was parallel to the ramp, is the tension force when it was parallel greater, equal, or less than when it is horizontal?
Trigonometric Functions
I would say with the work I have that it is less than, as is the answer, but it's how I get the answer that differs
I have drawn a free body diagram, where FgCostheta = Fn (I've been wonder would FnCostheta also equate to Fg? It makes sense when you draw it but honestly it does not make sense when making the equation)
I know FgCostheta = Fn or FnCostheta = Fg if I draw the triangles differently
I also tried many different methods for equating for Ft (since there are multiple methods for drawing that triangle. Like the perpendicular side points up, or is along Ft, etc)
The diagram doesn't have all of it, since I broke it off to a few more stuff and it just got too crowded so I just uploaded the file that I've been told is wrong. Doesn't look wrong to me so I was hoping if I could get some correction
I should've gotten Ft = mg/Costheta however I get different equations such as Ft = mg/Cottheta
  • Free-body diagram of a block on an incline, with the block drawn in a box on a ramp rising to the right, a gray vertical line and a gray diagonal line from the block, arrows labelled Fn and Fg, and two angle symbols marked near the top.
Presumably the block is meant to be on the plane not pivoting on a corner?
Draw the two free body diagrams (one for the parallel case and one for the horizontal) and show us your two equations for Ft.
