Tension in a single rope holding a block, no motion.
The discussion revolves around a physics problem involving tension in a single rope holding a block that is not in motion. The scenario includes a 2 kg block suspended from a rope at an angle of 37 degrees from the vertical, with a horizontal force acting on it. Participants are exploring the concepts of tension and force balance in this context.
  • Participants discuss the need to balance forces acting on the block, particularly the gravitational force and the horizontal force. There is uncertainty about the source of the horizontal force and how it affects the tension in the rope. Some participants question the appropriate equations to use given the angle involved.
The discussion is ongoing, with participants providing insights into balancing forces and considering simpler scenarios to clarify the concept of tension. There is no explicit consensus yet, but some guidance has been offered regarding the relationship between gravitational force and tension in a static situation.
Participants are navigating the complexities of the problem, including the implications of the angle and the horizontal force. There is a mention of a lack of clarity regarding the source of the horizontal force and its role in the overall force balance.
MissJewels
So this is a very basic question on tension, i assume, however every example provided in my book shows the tension within two cords. I can't seem to grasp the correct way to do this...
A 2 kg block is suspended from a single rope. A horizontal force keeps the cord at 37o from the vertical. Find the module
a) of the force
b) the tension of the string
Fg = 2*9,8 = 19,6 N
uhmmm... stuck!
I haven'y started the question because i need a boost, can anyone provide help?
Well, I'd start out by trying to balance the forces - if the block isn't moving, the forces you're interested in must be balanced by the gravitational force downwards, namely, the relevant equation above.
(This is the first time I've tried to give homework help, if it's too much or too little information, do let me know!)
So, seeing as the string is being pulled by a horizontal force, there's an angle at play. I imagine i should calculate the tension or force but I don't know what equations to use
To be honest, I'm a little bit confused about the source of this horizontal force, and wondering what's balancing it.
Nevertheless -
In a simpler situation, consider a block suspended from a rope, without moving, hanging straight down. Do you know how to calculate the tension in that situation?
i figure the tension would be the same as the gravitational force, which is 19,6N, right?
Yep!
So now, instead of just balancing the downwards force of gravity, you need to also balance the sideways force. What force would you need to keep the block at that angle?
Sorry. I'm trying not to give it totally away.
  • · Replies 25 ·
11K
