Tension in legs of an insect dangling upside down
  • Thread starter Thread starter coffeebird
    Insect Tension
The discussion focuses on the tension in the legs of an insect hanging from a horizontal rod at an angle of θ = 40°. The analysis reveals that the ratio of the tension in each tibia to the insect's weight is approximately 0.259, derived from the equation T = mg/(6 sinθ). When the insect straightens its legs, the angle θ increases, leading to a decrease in tension in the tibias due to the increasing value of sinθ. This relationship is crucial for understanding the mechanics of insect locomotion in such scenarios.
  • Understanding of Newton's second law (F=ma)
  • Knowledge of free-body diagrams
  • Familiarity with trigonometric functions, particularly sine
  • Basic concepts of tension in physics
  • Study the application of Newton's laws in static equilibrium problems
  • Learn how to construct and analyze free-body diagrams for complex systems
  • Explore the effects of angle changes on tension in physical systems
  • Investigate the biomechanics of insect locomotion and how it relates to physics principles
Students in physics, particularly those studying mechanics, as well as entomologists and anyone interested in the biomechanics of insect movement.
coffeebird
Some insects can walk below a thin rod (such as a twig) by hanging from it. Suppose that such an insect has mass m and hangs from a horizontal rod as shown in Fig. 5-35, with angle θ = 40°. Its six legs are all under the same tension, and the leg sections nearest the body are horizontal. (a) What is the ratio of the tension in each tibia (forepart of a leg) to the insect's weight? (b) If the insect straightens out its legs somewhat, does the tension in each tibia increase, decrease, or stay the same?
F=ma
weight = 9.8 m = tension on one leg = 9.8/6 m
tension in all tibias = (9.8mcos40)^2 + (9.8sin40)^2
tension in all femurs= 9.8cos40=7.51m
in answer to (b), the tension in the tibias would decrease because the tension in the femurs would increase
Hello, coffeebird.
Did you really want to claim that the weight of the bug equals the tension in one leg? Or, are you claiming that the tension in one leg equals 1/6 the weight of the bug? Either way, you would need to justify that.
It might help to relate this problem to the more standard problem of finding the tension in two cords that support a hanging sign, as shown in the attached figure. The key to working problems like this is to draw a good free-body diagram of the sign. Likewise, for the bug, draw a free-body diagram of the bug treating the tibias as "cords" supporting the bug.
(a) There are six legs, and the vertical component of the tension force in each leg is
T sinθ where θ = 40° . For vertical equilibrium (zero acceleration in the y direction) then by
Newton’s second law
6T sinθ= mg
∴ T = mg/6 sinθ
∴ the ratio becomes T/mg ≈ 0.259
(b) The angle θ is measured from horizontal, so as the insect “straightens out the legs” θ
will increase (getting closer to 90° ), which causes sinθ to increase (getting closer to 1)
and consequently (since sinθ is in the denominator) causes T to decrease.
thank you, i get it now
14K
