Calculating the Constant k in a Spring Pendulum System
  • Thread starter Thread starter brandon26
    Spring Tension
The discussion centers on calculating the spring constant k in a spring pendulum system, specifically for a mass of 2 kg extending a spring by 0.4 m. The relationship governing the system is defined by the restoring force F = -kx, leading to the formula k = mg/l, where m is the mass, g is the acceleration due to gravity, and l is the extension of the spring. The assumptions made include that the horizontal displacement is small enough to neglect vertical motion, and the original length of the spring is negligible. Clarifications on the assumptions are necessary for accurate calculations.
  • Understanding of Hooke's Law and spring constants
  • Basic knowledge of oscillatory motion and pendulum dynamics
  • Familiarity with Newton's laws of motion
  • Concept of restoring forces in mechanical systems
  • Study the derivation of Hooke's Law and its applications in oscillatory systems
  • Learn about the principles of simple harmonic motion (SHM) and its equations
  • Explore the relationship between mass, gravity, and spring extension in mechanical systems
  • Investigate the effects of damping and external forces on pendulum motion
Students preparing for physics exams, particularly those focusing on mechanics and oscillatory systems, as well as educators teaching concepts related to spring dynamics and pendulum motion.
brandon26
I think this question is complicated, and I don't even know how to start it off, please help?
A mass of 2 kg is hung from the lower end of a spiral spring and extends it by 0.4m. When the mass is displaced a further short distance x and released, it oscillates with acceleration a towards the rest position. If a = -kx and if the tension in the spring is always directly proportinal to its extension, what is the value of the constant k?
Please help, this urgent, I am revising for a physics exam that is coming up next week.
First off, the restoring force F = -kx, not a = -kx.
Secondly, I assume x is horizontal? So this is a pendulum motion?
Thirdly, I assume that the original length of the spring is, if unknown, negligible.
Fourthly, the horizontal displacement is small enough to neglect the vertical motion of the pendulum.
The restoring force is then:
F = -kx = -mgx/l.
This gives you k = mg/l, all of which are given. This depends on how I've interpreted your question, so let me know if any of the above four assumptions conflict with any extra info you've been given.
Fifth assumption - S207? In the same boat, if so.
  • · Replies 31 ·
