Tension of rope by hanging mass
The discussion focuses on calculating the tension in a rope when an 11 kg mass is released from a quarter-circle position. Key forces acting on the mass include gravitational force and tension, with the mass accelerating downward due to gravity. At the bottom of its path, the tension in the rope must counteract both the weight of the mass and provide the necessary centripetal force for its circular motion. Utilizing force diagrams and energy equations is emphasized as essential for understanding the mechanics involved. The final tension can be calculated using these principles, highlighting the importance of applying physics concepts effectively.
yankeekd25
A mass of 11 kg is hung on a rope of L = 2.7 meters. It is raised by 90 degrees (a quarter circle) held at rest, then released and it falls due to gravity alone. What is the tension in the rope at the bottom of its path in Newtons?
What do you think?
Hint: What forces act on the mass? What is its acceleration?
force diagrams yay! i remember those helped me understand what's was going on.
Force Diagrams saves lives everyday. Don't forget to use energy equations for Mechanics they are also good for your health :)
  • · Replies 25 ·
  • · Replies 22 ·
