Tension Problem, with slope and 2 masses
  • Thread starter Thread starter thoradicus
    Slope Tension
thoradicus
http://www.xtremepapers.com/papers/CIE/Cambridge%20International%20A%20and%20AS%20Level/Mathematics%20%289709%29/9709_w10_qp_43.pdf number 3
T=mg (no acceleration as equilibirum)
sin rule?
Not sure where to start..the marking scheme shows that sin/cos rules are used but I don't understand why they are used.
At first i wrote that m1g=T, and m2gsin30=T. Therefore, resultant force on pulley is mqg+mwgsin30, but, this is a dead end
Set up an equation for the net force that the strings exert on the pulley. You'll need to add vectors, so that's where those rules would apply.
ok, so the resultant force is 2Tcos30 along AQ and AP? how can we say for sure the two angles are the same?
How did you get that?
What two angles?
What two angles?
i assumed AP and AQ are hypotenuses to the line of direction of 3sqrt3. So, Tcos30 +Tcos30=3sqrt3?
Since the angle is 30 degrees, the other angle on top is 60 degrees. I assumed that the angle is divided equally into 2?
Ah, I see what you're doing. Yes, that's a fine way to add them up. You took advantage of symmetry, taking their components along the bisector of the 60° angle. Good!
I think you meant: Tcos30 + Tcos30 = T√3
(You can also use the law of cosines to add them up. Same answer, of course.)
