Undergrad How can I test for positive semi-definiteness in matrices?
To test if a matrix A is positive semi-definite (PSD), one can check if all eigenvalues are non-negative or use the definition where v^T Av ≥ 0 for all v in R^n. The discussion highlights challenges when dealing with matrices that have arbitrary parameters, such as the Hessian matrix of a function, which complicates the PSD verification process. Participants suggest that providing specific examples may lead to insights or demonstrate the application of the PSD definition more effectively. There is no universal method beyond the mentioned techniques, emphasizing the need for practical examples in understanding PSD testing. Engaging with specific problems can enhance clarity in applying these concepts.
Trollfaz
On a side note I'm posting on PF more frequently as I have exams coming and I need some help to understand some concepts. After my exams I will probably go inactive for a while.
So I'll get to the point. Suppose we have a matrix A and I wish to check if it is positive semi definite. So one easy way is to see if all it's eigenvalues are ##\ge 0##.
Another way is to test using the definition of PSD
$$v^T Av\ge 0\ v \in R^n$$
But sometimes things get really messy when I try to test a matrix with arbitrary parameters say I'm testing ##\triangledown ^2 f(x)## for PSD to check if f(x) is convex. Is there any other ways to prove for PSD in a matrix
Do you have a specific example of a problem you're stuck trying to solve? I don't think there's any general principle beyond what you listed but an example might spark some specific insight or just help demonstrate how to use the definition to check.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 33 ·
10K
  • · Replies 17 ·
19K
