[tex] f(x) = x^x [/tex]Given this function, defined, let's say for
  • Thread starter Thread starter Paul
    Function
Paul
f(x) = x^x
Given this function, defined, let's say for all real numbers, is there any way to tell when x is rational versus irrational for integer values of f(x)?
e.g.
x^x = 4
x = 2
x^x = 27
x = 3
x^x = 3
x = 1.825455054...
Thanks!
Mathematics news on Phys.org
You mean other that simply taking the xth root of x?
Do you mean the xth root of f(x)? Or am I misunderstanding? And yes, I meant other than simply looking at specific argument and function values.
Whoops, I sure do. :redface:
I'm not sure off the top of my head, but let me play with it.
3^3 doesn't equal, so x=3 is irrational. sorry to nitpick.
interesting problem though. i bet there isn't a way besides applying the interger set for x and assuming all others will be irrational. is there any value for f(x) that results in a non interger rational number? if so, that negates using the interger set to find the y.
Thanks, I corrected the typo. And I guess that would put us on the path to a solution. Essentially, given that x is not an element of Z (the integer set), is x^x \in Z possible?
Okay, suppose x=a/b, where a,b are integers. Assume that the fraction is reduced, ie. gcd(a,b)=1. Then x^x= (a/b)^(a/b)=(\frac{a^a}{b^a})^\frac{1}{b}
But gcd(a^a,b^a)=1, and therefore (\frac{a^a}{b^a})^\frac{1}{b} is irrational. It follows that if x^x is an integer, then either x is an integer or transcendental.
so there are also no solutions that are non intergers but rational, like 1/3 and 1/4?
i understand that x^x is an interger if x is an interger.
that tells us that the set of intergers for x gives us the solution set of y? there are no fractional xs for interger ys? sorry I am dumb. i want to learn though!
I was wondering the same thing about taking the logarithm or ln of a function.
I was interested in this quite some time ago. I finally found an article saying there is no known way of rearranging the equation:
y=x^x
In to some function of y in terms of x. But I did find an iterative formulae so you could approximate to as much accuracy as you wanted if you had y and wanted to know x. I'll see if I can find it again.
  • · Replies 28 ·
