The balancing point between two point charges
The discussion focuses on determining the point of zero electric potential between a negative charge of -0.03 C and a positive charge of 0.27 C, separated by 1 meter. Participants highlight the need to establish the distances from the point of interest to each charge, as the potential is influenced by their respective magnitudes and distances. The equation kq/d = kq/D is suggested to find the balance point, emphasizing that two different distances must be considered. The conversation also notes that textbooks may not explicitly cover this scenario, necessitating additional equations for a complete solution. Understanding the relationship between charge magnitudes and distances is crucial for solving this problem.
UnD3R0aTh
Where is the potential zero?
1. Where is the potential zero between a negative (-.03c) and a positive charge (.27) separated by 1 meter?
2. Point charges laws
3. My textbook doesn't mention where is potential zero between two charges, it's easy to solve if i know the point is in between or outside and which point charge is it closer to, kq/d=kq/d
hints;
\frac{k\cdot 0,27}{d}+\frac{k\cdot (-0,03)}{D}=0
two different d.
And you need another equation...
