The choice of sweep angle (low speed) and its impact on C_L, C_D, C_M
The discussion revolves around the design considerations for a powered model flying wing, focusing on the impact of wing sweep angle on aerodynamic coefficients such as lift coefficient (C_L), drag coefficient (C_D), and moment coefficient (C_M). Participants explore the implications of wing design on stability, motor placement, and overall performance, with an emphasis on achieving optimal flight duration.
  • Homework-related
  • Some participants suggest a wing sweep angle of about 20 degrees as a rule of thumb but express uncertainty about its optimality and seek more rigorous treatment of the topic.
  • There is a discussion about the lack of established formulas for estimating changes in C_L, C_D, and C_M with varying sweep angles.
  • One participant describes how stability can be achieved by flying slightly sideways, affecting the perceived wing length and chord, but questions how this relates to longitudinal stability without reflex airfoils.
  • Concerns are raised about the placement of motors and propellers, with suggestions to avoid disturbing airflow over the wing's upper surface and to consider the effects of motor mass on the center of mass (CoM).
  • Participants discuss the implications of mounting engines towards the rear and the need for counterweights to maintain aerodynamic balance.
  • There is a proposal to use two counter-rotating pusher propellers to potentially recover induced drag as thrust.
Participants express multiple competing views regarding the optimal wing design and motor placement, with no consensus reached on the best approach to achieve stability and performance in the model flying wing.
Participants note the importance of considering the type of engine (electric or liquid fuel) and the implications of battery placement on the overall stability and performance of the aircraft. The discussion also highlights the need for careful consideration of aerodynamic balance during different phases of flight.
Individuals interested in model aircraft design, aerodynamics, and stability considerations in powered flight may find this discussion relevant.
Leo Liu
My school's group project is to design a powered model flying wing that can fly for as long as possible. To make it stable in the longitudinal direction, we either have to use a swept wing design or an airfoil with reflex (like BR1). We are forced to use wing sweep because the airfoil with reflex cannot create enough lift.
A rule of thumb I found for the sweep angle is about ##20^\circ## for a model flying wing. I am not sure if it is optimal and am keen to know if there is a way to treat this topic more rigorously.
I did some research and was not able to find a rule-of-thumb formula for ##C_L##, ##C_D##, and ##C_M##. The closest thing I can find is this research.
I am wondering if such a formula exists, and if not, how we should estimate the changes in the three coefficients. Do we just apply a guessed margin and call it a day?
Another question I would like to ask is what are the factors and influences we need to consider when deciding the locations to mount the motors and propellers. Would it be more beneficial to put them at the leading edge or at the trailing edge?
The initial design of our flying wing:
Your input will be highly appreciated. Have a good one!
Leo Liu said:
I am wondering if such a formula exist, and if not, how we should estimate the changes in the three coefficients.
The stability comes from flying slightly sideways, when one wing appears to become longer with a shorter chord, while the other becomes shorter with a longer chord. The surface area of the wing remains constant, but the lift and drag stabilise the orientation of the wing to the direction of flight.
Avoid disturbing airflow over the upper surface of the wing, which is where most of the lift is found. That suggests mounting the propeller below and/or behind the wing. Make sure the orientation control surfaces (equivalent tail) are in the propeller-stream, so you will have directional control when on the ground, or when flying at just above stall speed.
The mass of the motors will determine CofM. The aircraft should be stable in glide, so mounting engines near the centre of the wing is preferred, but not ideal. A longer prop drive shaft is a possibility.
Thanks for the answers.
By stability I actually meant longitudinal stability rather than directional. From my understanding the wing sweep shifts the lift behind the CoM, but I don't quite understand how this works without reflex which creates a positive moment about the aerodynamic center. Simulation indicates stability for the design with NACA2412. (We also came up with a hybrid design involving both types of airfoils to get the advantages of both, but the lift performance is worse than NACA2412.)
Sorry by center do you mean the aerodynamic center or CoM? And why does mounting the engines near the center of the wing ensure that the plane glides well?
Following loss of power, you need to recover the craft by gliding. The aerodynamic balance at a stable low-speed glide should be optimised. Under power or in a fast glide, you will have energy to waste and a faster airflow over the control surfaces, so efficiency is not critical. (You are not designing this craft for long haul passenger transport).
If you mount the engines towards the rear, with pusher props, you must then add mass up front to counter the moment about the aerodynamic centre. That added mass is a waste of good lift if you can avoid ballast.
You have not identified the type of engine, electric or liquid fuel.
Stability is improved if longitudinal inertia is increased, if the mass can be distributed towards the ends of a longer body. Engines at the back with batteries up front might work, but since the mass of fuel is changing during the flight, fuel tanks must be in a neutral position in the wing. That explains why heavy engines are hung below the wing in many aircraft.
If the flights of our model plane are designed to be powered throughout, will it change the requirement here? We don't want to waste energy by making the plane climbing up.
The wingspan is a mere 600mm so we can only use two coreless DC motors to power the flying wing.
Hmmmm our plane will use a battery. I assume I can place it at the front as a counterweight?
Yes. A battery will make a good counterweight.
The two motors can be spaced apart, at the trailing edge. If they are far apart they will provide directional control, and some stabilising inertia.
Contemplate having two counter-rotating pusher propellers, one in each wing tip vortex. That way, you might recover some of the induced drag as thrust.
9K
  • · Replies 62 ·
12K
  • · Replies 27 ·
11K
