The Effect of Planets Rotation within its Galaxy?
The discussion revolves around the gravitational effects of a planet's rotation within its galaxy, particularly focusing on whether a planet gains gravitational force as it orbits the galactic center. Participants explore concepts related to kinetic energy, gravitational pull, and the implications of relative motion in a galactic context.
  • One participant questions whether a planet gains gravitational force due to its rotation around the galactic center, suggesting that the speed of this motion could amplify gravitational effects.
  • Another participant responds that while kinetic energy contributes to gravity, the overall gravitational force remains unchanged after a complete orbit of the galaxy, indicating that motion does not increase gravity in a significant way.
  • A follow-up inquiry considers whether the gravitational pull of stars on their orbiting planets is influenced by their orbital velocity around the galaxy, questioning if a stationary star would exert less gravitational pull compared to one in motion.
  • Another participant asserts that the gravitational force remains the same regardless of the object's position in the galaxy, emphasizing that relative velocity affects the perception of motion but does not alter gravitational strength.
  • There is a clarification regarding terminology, noting that "rotating" should refer to an object's own axis, while "orbiting" describes movement around another body.
Participants express differing views on the relationship between motion and gravitational force, with some suggesting that kinetic energy plays a role while others argue that overall gravitational strength does not change due to motion. The discussion remains unresolved regarding the implications of velocity on gravitational effects.
Participants highlight complexities related to non-inertial frames and the potential confusion arising from mixing different models of motion and gravity.
erickdt
Hello All,
A curious person here would like to know if a planet gains gravitational force as it rotates around the center of its galaxy. From what I understand this speed is quite impressive (the speed at which we travel around the center of our galaxy) so I'm wondering if the sheer mass of our planet (or sun), traveling at that velocity, would have the effect of amplifying Earth's (or the suns) gravitational force.
Thanks in advance for any explanation!
E
Astronomy news on Phys.org
Welcome to PF;
I'm guessing you are thinking that energy is mass so a high kinetic energy would result in a higher "mass" which means extra gravity compared to if it is still.
I think the short answer is "yes and no".
The generator of the gravitational field is the stress-energy-momentum tensor ##T^{\mu\nu}## whose components are energy ##T^{00}##, co-momentum ##T^{0,j}## and co-stress ##T^{ij}##.
Anything with a non-zero Tμν will feel gravity. In the non-relativistic limit co-momentum and co-stress vanish and energy reduces to mc2, which explains why masses appear in a non-relativistic description of gravity.
Kinetic energy contributes to gravity, mainly in the energy and co-momentum parts.
A quick calculation should show you how fast the Sun would have to be going to give it additional energy similar enough to it's mass-energy, and so show up as additional gravity that you'd notice. Even so - the Earth moves with the Sun, so the Sun is not going all that fast wrt us... and it is relative speeds that count here.
You also seem to be asking if overall gravity increases due to motion - I think the best answer here is "no", after a circuit of the galaxy, the Solar system has the same gravity that it started with.
Introduction to general relativity.
http://preposterousuniverse.com/grnotes/grtinypdf.pdf
Hello Simon,
Thanks for your response! It looks as though I have some more reading to do!
I guess what I'm wondering is whether or not the gravitational pull or stars on their respective orbiting planets is in some part due to the velocity at which they orbit the center of our galaxy.
Our sun for example orbits the center of the Milky way at about 139 MPS. Pretty darn fast! Let's say it wasn't orbiting anything at all, just standing "still" in space. Would its gravitational pull be less than it currently is moving at its impressive speed?
Along these same lines, would an object that rotates around the center of the Milky Way have less gravitational force than the same object rotating around the outer extents of the Milky Way (assuming their moving at the same RPM)? The object that is further out from the center would be going faster since it would have to be covering more space to maintain the same RPMs as the inner object.
Thanks again for your help! I really appreciate it!
E
No. But it is in some small part due to their velocity with respect to their planets.
The short answer is "no".
The gravitational force in question is the same both ways - the relative velocity contributes a component.
There is no absolute frame for velocity, so at each instant, the outer object is the fast one in the frame of the inner object and the inner object is the fast one in the frame of the outer one.
There are complications due to the large distances and the fact that rotating frames are non-inertial.
We are also dangerously close to mixing up the models too much.
BTW: properly, something that goes around another is said to be circling or orbiting - not rotating.
The term "rotating" is reserved for objects that turn about their own axis. So the Earth rotates (on it's axis) as it orbits the Sun: two different motions.
  • · Replies 22 ·
