The effects of electrical shock on the brain from non-localized contact area
The discussion centers on the effects of electrical shock on the brain, specifically regarding a case where a young man connected clamps to his nipples and plugged them into a wall socket. Participants debated whether the resulting brain damage was due to direct electrical impact or oxygen deprivation from cardiac arrest. The consensus indicates that the electrical current likely followed the path of least resistance, primarily affecting the heart and chest, with minimal voltage reaching the brain. The discussion highlights the importance of understanding bio-conductivity and the anatomical separation between the thorax and the head in electrical current flow.
  • Understanding of electrical conductivity and resistance
  • Basic knowledge of human anatomy, particularly the central nervous system
  • Familiarity with the concept of "path of least resistance" in electrical circuits
  • Awareness of the physiological effects of electrical shock on the body
  • Research the physiological effects of electrical shock on the heart and brain
  • Study the principles of bio-conductivity and its implications in medical scenarios
  • Examine case studies of electrical injuries and their outcomes
  • Learn about safety measures and first aid for electrical shock incidents
This discussion is beneficial for medical professionals, electrical safety educators, and individuals interested in the physiological impacts of electrical injuries. It provides insights for those studying human anatomy and electrical engineering principles.
BillDoor
In my attempt to obliterate my ignorance I'd like to discuss something related to the recent news story about a young man who attached two clamps to his nipples and then had a friend plug it into a wall socket. http://news.gather.com/viewArticle.action?articleId=281474978486647" <-- News Story
I got into a debate(from an admittedly relative point of ignorance) over whether or not the young man suffered direct brain damage from the shock or if it was entirely the oxygen deprivation from his heart stopping.
Basically, "their" argument was that it probably didn't hit his brain because it took the path of least resistance. My argument was that given the amount of fluid in the body and the nature of the central nervous system and its connection to the brain it would seem dubious that the brain would not incur direct electrical damage. Now, a second question: if the young man's brain was indeed directly damaged (rather than indirectly via oxygen deprivation), was the voltage enough to cause a significant amount of brain damage? And, I'm not even sure what constitutes "significant" brain damage.
Also, I was reading up on "path of least resistance" when I came upon this article: http://ecmweb.com/mag/electric_path_least_resistance/. So, unless I'm misunderstanding, the electrical current took every path available in his body in inverse proportion to the amount of resistance in each path? I guess what it comes down to is the bio-conductivity of the connections of the chest to the brain.
Well, I'd like to assert that while I'd enjoy being correct, my real goal is to understand. Thank you for your time!
Pretty much, so since the current has to go well out of it's way to get his brain it's only a slight percent. Otherwise tazers would constantly shut your heart down and fry your brains etc.
He would definitely have died of a heart attack.
EDIT: NM he didn't die, but you know what I mean. He suffered brain damage because his heart shut down. His heart shut down because the electricity took the direct path (through his heart/chest). Only a SUPER TINY amount of volage if any would be applied a the brain area.
Current flow generally spreads to fill all available paths, which is why the electrical resistance for a conductive flat surface is measured in ohms/square. The size of the square doesn't matter because as the distance the current must cross increases, the width of the area it can pass through also increases. A square inch and a square mile would have the same resistance.
However, because the head is separated from the thorax by the neck, the currently flow would probably be (mostly) choked off (no pun intended) without much current passing through the brain.
BillDoor: Are you a fan of Terry Pratchett? One of his characters used the name "Bill Door".
Thank you for both of your replies!
And yes, I am indeed a stalwart fan of Pratchett. DEATH's guise as Bill Door is one of my favorite parts of his books, but especially "The Reaper Man."
10K
  • · Replies 19 ·
12K
  • · Replies 49 ·
11K
10K
