DmitryS
- 31
- 5
- TL;DR
- apparent problem of Einstein clock
Hello, everyone, hope someone will resolve my doubts.
I have posted here some two years ago asking for an explanation of the Lorentz transforms derivation found in the Einstein 1905 paper. The answer I got seemed quite satisfactory. Two years after I revisit this derivation and this is what I see.
In the Einstein original paper, the Lorentz transforms derivation included as a premise that light is always propagated along the direction perpendicular to the line of motion when viewed from the stationary system with the velocity sqrt(c^2 − v^2). This expression can be considered the first mentioning of what was to become the model of the so-called light clock, where the light travelling vertically for one observer is moving at the angle arccos (v/c) for the other.
There is also a different derivation of the Lorentz transforms with the help of the spherical flash of light originating from the origins of the two inertial frames of reference when those coincide. The transforms are derived based on the assumption that the expression for the sphere of light must be identical for either observer.
I summarized my doubts as follows.
1. The derivation of the Lorentz transforms through the invariance of the light sphere suggests that postulating constancy of the speed of light should be equal to: ‘Any point of space where light originates is considered motionless relative to the inertial observer’. That is to say, if a spaceship generates a pulse spherical light wave at a certain point, the ship will continue moving staying at its centre, while the on-land observer will see the spaceship moving through this sphere of light while seeing the centre of the sphere static (whence relative simultaneity). Thus, the two spheres, one with the centre at O, the other at O’, are identical in every way. Those rays that go up will go up, and those that are in line with motion will be in line with motion. The flux of rays over the entire surface of the sphere will be the same for both observers.
2. On the other hand, the light clock model suggests an entirely different interpretation of the speed of light’s constancy, namely: ‘Any photon will have the absolute value of the speed equal to the speed of light relative to an inertial observer along the trajectory resulting from the composition of motions of that photon and of the observer moving relative to any other inertial observer’. In short, it suggests that the ray going straight up for Observer O’ and the ray going at the angle arccos(v/c) to the line of motion for Observer O are the same physical object.
3. And that means (if we marry this model to the one with the two spheres of light) that the flux of rays limited by the cone with the angle 2arccos(v/c) with the axis coinciding with the line of motion for Observer O must be the same as the flux of the hemisphere towards the same direction for Observer O’. The angle of 2arccos(v/c) will open up and become 2π in the O’ system. If we consider the flux to be constant over the sphere for Observer O, it won’t be constant for Observer O’: the hemisphere on the right will be not so dense with rays as the hemisphere on the left. That, of course, will mean that there’s an objective difference between the two observers and the relativity principle does not hold.
4. The least we can say is that these two models can’t go together. One of them should be false, and since the light clock model violates the relativity principle, the invariance of the two spheres must be correct.
This is it in a nutshell. I never saw this problem mentioned in literature. Possibly someone here has an answer.
