The force when the distance is reduced
  • Thread starter Thread starter aChordate
    Force
The discussion centers on calculating the force between two charges when the distance is reduced to one-ninth of its original value. The initial force is given as 1.5 N, and using Coulomb's Law, the new force is determined to be 121.5 N. The participants clarify that the force is inversely proportional to the square of the distance, leading to the conclusion that reducing the distance by a factor of 9 increases the force by a factor of 81. This is mathematically expressed as F2 = 81 * 1.5 N.
  • Coulomb's Law (F = k|q1||q2|/r^2)
  • Understanding of inverse square relationships
  • Basic algebra for manipulating equations
  • Knowledge of proportionality in physics
  • Study the implications of Coulomb's Law in electrostatics
  • Learn about the concept of force and distance in physics
  • Explore examples of inverse square laws in other physical phenomena
  • Practice solving problems involving force calculations with varying distances
Students studying physics, particularly those focusing on electrostatics, educators teaching force concepts, and anyone seeking to understand the mathematical relationships in physical laws.
aChordate
Two charges attract each other with a force of 1.5 N. What will be the force if the distance between them is reduced to one-ninth of its original value?
F=1.5 N
F=k|q1||q2|/r^2
1.5 N = k |q1||q2|/(1/9)r^2
I don't think I am setting this up right, but would I multiply 1.5N by 1/9 and by the constant k?
Thanks in advance!
Set it up so that 1.5 N is the force when the distance = R.
Then see what the force is when the distance = R/9.
(Set up a ratio.)
Another way to approach this is to just ask yourself what happens to the force if the distance doubles? If the distance is cut in half? That should point you in the right direction.
Try answering the questions I asked in post #3.
If the distance doubles, the force increases x4 (exponentially?). If the distance is halved, the force decreases.
Careful. The force is inversely proportional to the distance squared. So if the distance doubles, the force decreases by a factor of 4. (Multiplied by (1/2)2 = 1/4.)
No, the force would increase by a factor of 4.
F1 = (const)*(1/R)2
If you reduce the distance by 2, replace R with R/2:
F2 = (const)*(1/(R/2))2 = 4*(const)*(1/R)2 = 4*F1
(Now do the same thing for the distance being reduced by 1/9.)
F2 = (const)*(1/(R/9))2 = 81*(const)*(1/R)2 = 81*1.5 N = 121.5 N
Wow, I really need to work on more of these.
Thanks so much for your help!
Hi Doc Al,
I am trying to understand the answer that you posted above.
Could you explain why the squared sign is outside the last bracket. Should it not be inside the bracket as it is the distance squared.
F2 = (const)*(1/(R/2)2)
Also, how did you simplify it to be 4*(const), how did you calculate the 4?
Many thanks,
Cathal
Realize that ##(\frac{1}{R})^2 = \frac{1}{R^2}##
##(\frac{1}{R/2})^2 = (\frac{2}{R})^2 = 4(\frac{1}{R})^2##
