Heat question -- Ice cube in a cup of water....
The discussion centers on calculating the maximum estimated change in temperature when an ice cube is dropped into water. The initial calculations incorrectly suggested a final temperature of 25 degrees Celsius, which contradicts the laws of thermodynamics. The correct change in temperature is 8.7 K, leading to a final temperature of 6.3 degrees Celsius. Key errors included miscalculating heat loss and gain, and not properly accounting for the latent heat of fusion of ice.
  • Understanding of specific heat capacity (SHC) of water
  • Knowledge of latent heat of fusion of ice
  • Ability to apply the principle of conservation of energy in thermodynamics
  • Familiarity with temperature scales, particularly Kelvin and Celsius
  • Review the principles of heat transfer in thermodynamics
  • Study the calculations involving latent heat and specific heat capacity
  • Learn about the conservation of energy in closed systems
  • Explore common mistakes in thermal equilibrium problems
Students studying thermodynamics, physics educators, and anyone involved in solving heat transfer problems in physical science.
zanyzoya
An ice cube of mass 0.01.kg at a temperature of 0 degrees Celsius is dropped into a cup containing 0.10kg of water at a temperature of 15 degrees Celsius. What is the max estimated change in temperature of the contents of the cup?
SHC of water = 4200J per kg per kelvin
latent heat of fusion of ice = 340000 J per kg
and attempt at a solution[/B]
heat lost by water = heat gained by ice
mwaterC ΔTwater = mice C ΔTice + mΔL
0.1 x 4200 x ΔTwater = 0.01 x 4200 ΔTice + 0.01 x 340000
420(Tfinal-15) = 42 (Tfinal-0) + 3400
420T - 6300 = 42T + 3400
T= 25 degrees
so change in temperature = 15-25 = -10 degrees celsius
This is wrong as the actual answer is 8.7 K
zanyzoya said:
T= 25 degrees
So the final temperature is higher than all initial temperatures? Doesn't make sense, right?
First problem: the left-hand side here doesn't correspond to "heat loss by water."
Second problem: you have to use absolute temperatures here.
Thanks Dr Claude
Re your first point, my understanding is as follows:
As the water cools down it will loose heat equal to mc delta T, also heat will by lost to surroundings and to the cup. Some of this heat which is lost by the water is given to the ice to initially cause a change in state and finally raise its temperature. Am I on the wrong lines here?
I've converted the values to kelvin and I still get the same answer?!?
Your approach is correct, but you have to be careful about the signs. (This is a general comment: when you get a final temperature that is higher than the initial temperature, while it should be the other way around, the first thing to check are the signs.)
zanyzoya said:
... the actual answer is 8.7 K
That value looks a little high to me. Just melting the ice (ice@0C → water@0C) should take enough heat from the existing liquid water to drop its temperature below that value.
Not that the 8.7K that was asked, is the temperature change and not the final temperature, which is 6.3C.
Ah. My mistake. I should really pay closer attention to these small details. Thanks :smile:
zanyzoya said:
heat gained by ice
zanyzoya said:
42 (Tfinal-0)
So far so good: heat gained is proportional to the final temperature minus the initial temperature.
So for heat lost,
zanyzoya said:
heat lost by water
how should you calculate the temperature difference? Not like this:
zanyzoya said:
420(Tfinal-15)
  • · Replies 17 ·
