The limit of xye^-(x+y)^2 when x^2+y^2 approach infinity
The limit of the expression lim (x^2+y^2) -> infinity (xye^-(x+y)^2) is determined to be undefined. Utilizing polar coordinates, the limit can yield different results based on the angle, specifically when evaluating the expression lim r^2 -> infinity (r^2 cos(θ) sin(θ) / e^(r^2(1+sin(2θ)))). The limit does not converge to a single value due to the dependency on the angle θ, leading to scenarios where the limit can approach -∞ or 0. Thus, the limit is not well-defined across all paths as r approaches infinity.
  • Understanding of limits in multivariable calculus
  • Familiarity with polar coordinates and their application in limits
  • Knowledge of exponential functions and their behavior as variables approach infinity
  • Basic trigonometric identities and their implications in calculus
  • Study the behavior of limits in polar coordinates
  • Explore the concept of path dependence in multivariable limits
  • Investigate the implications of exponential decay in limits involving infinity
  • Learn about the conditions under which limits are defined or undefined
Students and professionals in mathematics, particularly those studying calculus and analysis, as well as educators seeking to clarify concepts related to limits and polar coordinates.
Mahathepp
I try to figure it out but I can't get the answer that I need and when I look upon the solution from the book I don't understand it at all. The answer is " no limit" and there is no explanation why. The question is
Determine the limit of
lim (x2+y2)- -> infinity (xye-(x+y)2
in this case I use polar coordinate which I get
lim r2 - -> infinity ( r2cos(x)sin(X) / er^2(1+sin(2x) )
My idea is since there is (er^2(1+sin(2x)) in denominator which is depening on angle (2x) but I am not sure if I understand correct. Can anyone here help me to figure it out? Thanks in advance.
Regard
If the limit existed, then the result would not depend on how r approaches infinity. As you can see, you will obtain different results depending on the polar coordinate (if you fix it) and therefore the limit is not well defined.
If x+y = 0, the limit is -∞. If x+y -> ∞, the limit = 0. Manipulation of x+y can lead to any limit.
##\lim\limits_{x^2+y^2\to\infty} x y e^{-(x+y)^2}##
##\lim\limits_{r^2\to\infty} r^2 \cos(\theta) \sin(\theta) e^{-r^2 (1+\sin(2\theta))}##
##\lim\limits_{r^2\to\infty} \frac {r^2 \cos(\theta) \sin(\theta)} {e^{r^2 (1+\sin(2\theta))}}##
The limit is undefined when the ##e^{r^2 (1+\sin (2\theta))}=e^{\infty \cdot 0}## or when ##1+\sin(2\theta)=0## and that happens for ##\theta = \frac{3\pi}{4}, \frac{7\pi}{4}##
##\arctan (\frac{y}{x})=\frac{3\pi}{4}## And that means ##\frac{y}{x}=-1## or along the line ##y=-x## which restricts the domain.
