The normal equivalent for a discrete random variable
25 replies · 4K views
Ad VanderVen
TL;DR
A discrete variable ##K## is distributed according to the formula used for the normal distribution. How can the sum for all values of ##k## still be equal to one?
De normal distribution has the following form:
$$\displaystyle f \left(x \right) \, = \,\frac{1}{2}~\frac{\sqrt{2}~e^{-\frac{1}{2}~\frac{\left(x -\nu \right)^{2}}{\tau ^{2}}}}{\tau ~\sqrt{\pi }}$$
and it's integral is equal to one:
$$\displaystyle \int_{-\infty }^{\infty }\!1/2\,{\frac { \sqrt{2}}{\tau\, \sqrt{\pi }}{{\rm e}^{-1/2\,{\frac { \left( x-\nu \right) ^{2}}{{\tau}^{2}}}}}}\,{\rm d}x \, = \, 1$$
However, I now take with ##k## as an integer:
$$\displaystyle P \left( K=k \right) \, = \,1/2\,{\frac { \sqrt{2}}{\tau \, \sqrt{\pi }}{{\rm e}^{-1/2\,{\frac { \left( k-\nu \right) ^{2}}{{\tau }^{2}}}}}}$$
For example, for ##\nu = 0## and ##\tau:=25.0## I get:
$$\displaystyle \sum _{k=-\infty }^{\infty } 0.01595769121\,{{\rm e}^{- 0.0008000000000\,{k}^{2}}}= 1.0$$
and one would expect a value lower than 1. How is that possible?
Ad VanderVen said:
Summary:: A discrete variable ##K## is distributed according to the formula used for the normal distribution. How can the sum for all values of ##k## still be equal to one?
It cannot. The normal distribution is a continuous distribution, not a discrete distribution. It doesn’t makes sense to say that a discrete random variable has a continuous distribution
It would never have occurred to me to try something like that. There seems no particular reason for it to equal one. Can you prove that it does? Or is this a numerical approximation?
If you have a "Large-Enough" number of data points, your distribution may approximate (i.e., converge in different senses ) to a Normal Distribution. Edit: Further, your formula is one of a density function, not a cdf (Cumulative Distribution), which does not make sense for a discrete variable.
Read:
Roy, Dilip (2007). The Discrete Normal Distribution. Communications in Statistics - Theory and Methods. 32, 10, pp. 1871-1883. Published online: 15 Feb 2007.
nuuskur said:
For sure an approximation and the real value is ##<1##. But it maybe a very good way to approximate.
Aha. I'd like to see what the real value is. It seems to me that it wouldn't be that close. If it is that close, then I'm surprised and impressed that the errors cancel out so well.
Also, it isn't obvious that the sum of that series is less than one. It is less than it should be in the convex regions and greater than it should be in the concave regions. There might be an interesting reason that two wrongs are making a right.
Regardless, it is wrong to use a continuous distribution for a discrete random variable. In a continuous distribution the probability of getting exactly any of the discrete values is 0.
To go from a pdf to a pmf requires either a sampling and a normalization or an integration.
I haven't fully worked this through but it seems to me that:
Yes, and because we know that a Gaussian distribution is the limiting case of binomial as ## n \to \infty ## I would expect it to exactly equal one.
Yes, and the series in the OP is a Riemann sum that does that integration.
It is in the limit. But it was not taken to the limit.
I haven't checked the details (exercise for the interested), but I think the RHS of the equation in the OP
is equivalent to the RHS of the De Moivre-Laplace theorem:
$$ \lim_{n=0}^{\infty} {n \choose k}\,p^{k}q^{n-k} = {\frac {1}{\sqrt {2\pi npq}}}\,e^{-{\frac {(k-np)^{2}}{2npq}}} $$
so yes, I think we are taking it to the limit.
Yes, but that series is not the normal distribution. A discrete variable cannot be "distributed according to the formula used for the normal distribution". It is a rather minor and excessively pedantic point, I know.
Yes, the question in the OP - particularly the summary - was poorly phrased: we should not be talking about a PDF of a discrete variable. Perhaps if we had focused on the CDF it would have been less of a surprise that the CDF of the discrete variable is equal to the CDF of the normal distribution at each integer step and therefore less of a surprise that the CDF is 1 at ## \infty ##.
An asymptotic formula is obtained in Chapter 9 of the book of Concrete Mathematics, by Graham, Knuth and Patashnik by using the Euler-Maclaurin formula applied to the Gaussian (I have written their end formula in terms of our variables for the purposes of the thread):
\sum_{k = -\infty}^\infty \dfrac{e^{-k^2 / 2 \tau^2}}{\sqrt{2} \tau \sqrt{\pi}} = \int_{-\infty}^\infty \dfrac{e^{-x^2 / 2 \tau^2}}{\sqrt{2} \tau \sqrt{\pi}} + \mathcal{O} (\tau^{-(N+2)/2}) \quad \text{as } \tau \rightarrow \infty
here ##2 \tau^2 =## integer.
The book says, the sum ##\sum_k e^{-k^2/n}## is already close to ##\sqrt{n \pi}## even for ##n = 2##: the sum is ##2.506628288## and ##\sqrt{2 \pi} \approx 2.506628275##. They say that for ##n = 100## that the sum agrees with ##10 \sqrt{\pi}## to 427 decimal places! (Note ##n=2## corresponds to ##\tau = 1## and ##n=100## corresponds to ##\tau \approx 7##)
In chapter 9 of the book they say using "advanced methods" you can obtain a rapidly converging series:
\sum_{k = -\infty}^\infty \dfrac{e^{-k^2 / 2 \tau^2}}{\sqrt{2} \tau \sqrt{\pi}} = \int_{-\infty}^\infty \dfrac{e^{-x^2 /2 \tau^2}}{\sqrt{2} \tau \sqrt{\pi}} + 2 e^{- 2 \tau^2 \pi^2} + \mathcal{O} (e^{- 2 \cdot 4 \tau^2 \pi^2})
for positive ##\tau## large enough, but where there is no requirement that ##2 \tau^2## is an integer. Let's put ##\tau = 25.0## to find what the leading order correction would be,
2 e^{- 2 \times 25^2 \pi^2} = 2.5563 \times 10^{- 5358} .
So that, @Ad VanderVen, would be why you are getting out ##1.0## for your particular example of ##\nu = 0## and ##\tau = 25.0##.
The "advanced methods" is just the Poisson's summation formula:
As ##\sum_{k=-\infty}^\infty F (k + t)## is a periodic function in ##t## with period 1 we can write it as a Fourier series,
\begin{align*}
\sum_{k=-\infty}^\infty F (k + t) &= \sum_{m=-\infty}^\infty e^{2 \pi imt} \int_0^1 e^{-2 \pi ims} \sum_{k=-\infty}^\infty F (k + s) ds
\nonumber \\
&= \sum_{m=-\infty}^\infty e^{2 \pi imt} \sum_{k=-\infty}^\infty \int_0^1 e^{-2 \pi ims} F (k + s) ds
\nonumber \\
&= \sum_{m=-\infty}^\infty e^{2 \pi imt} \sum_{k=-\infty}^\infty \int_k^{k+1} F (s) e^{-2 \pi ims} ds
\nonumber \\
&= \sum_{m=-\infty}^\infty e^{2 \pi imt} \int_{-\infty}^\infty F (s) e^{-2 \pi ims} ds
\nonumber \\
&= \sum_{m=-\infty}^\infty \tilde{F} (2 \pi m) e^{2 \pi imt}
\end{align*}
where
\tilde{F} (y) = \int_{-\infty}^\infty F (s) e^{-iys} ds
Put ##F(s) = e^{-s^2/n}##, then
\begin{align*}
\tilde{F} (y) &= \int_{-\infty}^\infty e^{-s^2/n} e^{-iys} ds
\nonumber \\
&= \int_{-\infty}^\infty e^{-(s^2 - inys)/n} ds
\nonumber \\
&= \int_{-\infty}^\infty e^{-(s - iny/2)^2/n - ny^2/4} ds
\nonumber \\
&= e^{ - ny^2/4} \int_{-\infty}^\infty e^{-s^2/n} ds
\nonumber \\
&= \sqrt{n \pi} e^{ - ny^2/4} .
\end{align*}
So that
\begin{align*}
\sum_{k=-\infty}^\infty e^{-(k + t)^2/n} &= \sqrt{n \pi} \sum_{m=-\infty}^\infty e^{ - n (2 \pi m)^2/4} e^{2 \pi imt}
\nonumber \\
&= \sqrt{n \pi} \left( 1 + 2 \sum_{m=1}^\infty e^{ - m^2 \pi^2 n} \cos 2 \pi mt
\right)
\nonumber \\
&= \sqrt{n \pi} \left( 1 + 2 e^{ - \pi^2 n} \cos 2 \pi t + 2 e^{ - 4 \pi^2 n} \cos 4 \pi t + 2 e^{ - 9 \pi^2 n} \cos 6 \pi t + \cdots
\right)
\end{align*}
Note there is no requirement that ##n## be an integer, just that is be positive.
As they note in the book, "This formula gives a rapidly convergent series for the sum" for ##t = 0##:
\sum_{k=-\infty}^\infty e^{-k^2/n} = \sqrt{n \pi} \left( 1 + 2 e^{ - \pi^2 n} + 2 e^{ - 4 \pi^2 n} + 2 e^{ - 9 \pi^2 n} + \cdots
\right)
I think you can use the Poisson's summation formula to obtain formula for the general case and for moments of the distribution as well, and obtain that the sum approximates the integrals very well for ##\tau## large enough. I'm tired today, I think I've got all the typos.
From the Poisson's summation formula derived in the previous post,
\sum_{k=-\infty}^\infty e^{-(k + t)^2/n} = \sqrt{n \pi} \left( 1 + 2 \sum_{m=1}^\infty e^{ - m^2 \pi^2 n} \cos 2 \pi m t
\right)
we have by putting ##t = - \nu##,
\sum_{k=-\infty}^\infty \dfrac{e^{-(k - \nu)^2/2 \tau^2}}{\sqrt{2} \tau \sqrt{\pi}} = \int_{-\infty}^\infty \dfrac{e^{-(x - \nu)^2/2 \tau^2}}{\sqrt{2} \tau \sqrt{\pi}} dx + 2 \sum_{m=1}^\infty e^{ - m^2 \pi^2 2 \tau^2} \cos 2 \pi m \nu .
We can use the Poisson's summation formula to obtain formula for the moments.
Put ##F_q(s) = s^q e^{-s^2/n}##, then
\begin{align*}
\tilde{F}_q (y) &= \int_{-\infty}^\infty s^q e^{-s^2/n} e^{-iys} ds
\nonumber \\
&= i^q \dfrac{\partial^q}{\partial y^q} \int_{-\infty}^\infty e^{-s^2/n} e^{-iys} ds
\nonumber \\
&= i^q \dfrac{\partial^q}{\partial y^q} \sqrt{n \pi} e^{ - ny^2/4}
\end{align*}
So that for ##q=1##, ##\tilde{F}_1 (y) = i (-ny/2) \sqrt{n \pi} e^{ - ny^2/4}## and,
\begin{align*}
\sum_{k=-\infty}^\infty (k + t) e^{- (k + t)^2 / n} &= \sum_{k=-\infty}^\infty F_1 (k + t)
\nonumber \\
&= \sum_{m=-\infty}^\infty \tilde{F}_1 (2 \pi m) e^{2 \pi imt}
\nonumber \\
&= -i n \pi \sqrt{n \pi} \sum_{m=-\infty}^\infty m e^{- m^2 \pi^2 n} e^{2 \pi imt}
\nonumber \\
&= 0 + 2 n \pi \sqrt{n \pi} \sum_{m = 1}^\infty m e^{- m^2 \pi^2 n} \sin 2 \pi mt .
\end{align*}
From which we obtain,
\sum_{k=-\infty}^\infty \dfrac{(k - \nu)}{\sqrt{2} \tau \sqrt{\pi}} e^{- (k - \nu)^2 / 2 \tau^2} = \int_{-\infty}^\infty \dfrac{(x - \nu)}{\sqrt{2} \tau \sqrt{\pi}} e^{- (x - \nu)^2 / 2 \tau^2} dx - 4 \tau^2 \pi \sum_{m = 1}^\infty m e^{- m^2 \pi^2 2 \tau^2} \sin 2 \pi m \nu
or if you like,
\begin{align*}
\sum_{k=-\infty}^\infty \dfrac{k}{\sqrt{2} \tau \sqrt{\pi}} e^{- (k - \nu)^2 / 2 \tau^2} &= \int_{-\infty}^\infty \dfrac{x}{\sqrt{2} \tau \sqrt{\pi}} e^{- (x - \nu)^2 / 2 \tau^2} dx - \nu + \nu \sum_{k=-\infty}^\infty \dfrac{1}{\sqrt{2} \tau \sqrt{\pi}} e^{- (k - \nu)^2 / 2 \tau^2}
\nonumber \\
& - 4 \tau^2 \pi \sum_{m = 1}^\infty m e^{- m^2 \pi^2 2 \tau^2} \sin 2 \pi m \nu
\nonumber \\
&= \int_{-\infty}^\infty \dfrac{x}{\sqrt{2} \tau \sqrt{\pi}} e^{- (x - \nu)^2 / 2 \tau^2} dx +
2 \nu \sum_{m=1}^\infty e^{ - m^2 \pi^2 2 \tau^2} \cos 2 \pi m \nu
\nonumber \\
& - 4 \tau^2 \pi \sum_{m = 1}^\infty m e^{- m^2 \pi^2 2 \tau^2} \sin 2 \pi m \nu .
\end{align*}So that for ##q=2##, ##\tilde{F}_2 (y) = (n/2) \sqrt{n \pi} e^{ - ny^2/4} - (ny/2)^2 \sqrt{n \pi} e^{ - ny^2/4}##
\begin{align*}
\sum_{k=-\infty}^\infty (k + t)^2 e^{- (k + t)^2 / n} &= \sum_{k=-\infty}^\infty F_2 (k + t)
\nonumber \\
&= \sum_{m=-\infty}^\infty \tilde{F}_2 (2 \pi m) e^{2 \pi imt}
\nonumber \\
&= \frac{n}{2} \sqrt{n \pi} \sum_{m=-\infty}^\infty e^{- m^2 \pi^2 n} e^{2 \pi imt} - \left( \frac{n}{2} \right)^2 (2 \pi)^2 \sqrt{n \pi} \sum_{m=-\infty}^\infty m^2 e^{- m^2 \pi^2 n} e^{2 \pi imt}
\nonumber \\
&= \frac{1}{2} \sqrt{\pi} n^{3/2} + \sqrt{\pi} n^{3/2} \sum_{m = 1}^\infty e^{- m^2 \pi^2 n} \cos 2 \pi mt
\nonumber \\
& \; - 2 (n \pi)^{3/2} \sum_{m = 1}^\infty m^2 e^{- m^2 \pi^2 n} \cos 2 \pi mt
\end{align*}
\begin{align*}
\sum_{k=-\infty}^\infty \dfrac{(k - \nu)^2}{\sqrt{2} \tau \sqrt{\pi}} e^{- (k - \nu)^2 / 2 \tau^2} &= \int_{-\infty}^\infty \dfrac{(x - \nu)^2}{\sqrt{2} \tau \sqrt{\pi}} e^{- (x - \nu)^2 / 2 \tau^2} dx
\nonumber \\
& \quad - \; 2 \tau^2 \sum_{m = 1}^\infty (2 \pi m^2 - 1) e^{- m^2 \pi^2 2 \tau^2} \cos 2 \pi m \nu
\end{align*}
By choosing a large sigma (25) you ensure the step sizes in the summation are small relative to the majority of the distribution (+- 2 standard deviations would divide amidst all the distribution into 100 increments). I doubt this would work well for a normalized sigma
The derivation of the Poisson's summation formula here for the Gaussian is straightforward. It involves the Fourier transform of a Gaussian which gives back a Gaussian but moving the ##2 \tau^2## from the denominator in the exponent to the numerator (it introduces a factor of ##1/4## in the exponent as well), but then ##y^2## in the exponent gets replaced by ##(2 \pi m)^2## so you end up with ##e^{- m^2 2 \tau^2 \pi^2}## as your corrections where ##\pi^2 \approx 10##:
\sum_{k = -\infty}^\infty \dfrac{e^{-k^2 / 2 \tau^2}}{\sqrt{2} \tau \sqrt{\pi}} = \int_{-\infty}^\infty \dfrac{e^{-x^2 /2 \tau^2}}{\sqrt{2} \tau \sqrt{\pi}} + 2 e^{- 2 \tau^2 \pi^2} + 2 e^{- 2 \cdot 4 \tau^2 \pi^2}+ \mathcal{O} (e^{- 2 \cdot 9 \tau^2 \pi^2}) ,
from that it is not so surprising that the approximation is so good even for ##\tau = 1##:
\begin{align*}
2 e^{- 2 \times 1^2 \pi^2} &= 5.35057 \times 10^{-9}
\nonumber \\
2 e^{- 2 \cdot 4 \times 1^2 \pi^2} &= 1.02450 \times 10^{-34} .
\end{align*}
It is some kind of coincidence that the sum approximates the integration very well here even for low values of ##\tau##. Your argument may help explain why the accuracy gets even better as ##\tau## increases.
\sum_{k = -\infty}^\infty \dfrac{e^{-k^2 / 2 \tau^2}}{\sqrt{2} \tau \sqrt{\pi}} = \int_{-\infty}^\infty \dfrac{e^{-x^2 /2 \tau^2}}{\sqrt{2} \tau \sqrt{\pi}} + 2 e^{- 2 \tau^2 \pi^2} + 2 e^{- 4 \tau^2 \pi^2}+ \mathcal{O} (e^{- 9 \tau^2 \pi^2}) ,
\begin{align*}
\nonumber \\
2 e^{- 4 \times 1^2 \pi^2} &= 1.43143 \times 10^{-17} .
\end{align*}
I ran a quick test in MATLAB for a 1 sigma 2-tailed area, which is
0.68268949 with sigma/tau =1, here are the results with different step sizes (alternatively can read as values for tau / sigma):
1: 0.882883729439719
10: 0.706483145523855
100: 0.685105166523426
1000: 0.682931422533150
10000: 0.682713688806255
But I just put the sum ##\sum_{k=-N}^N \dfrac{e^{-k^2/2}}{\sqrt{2 \pi}}## into Wolfram for say ##N=40## and get:
\sum_{k=-40}^{40} \dfrac{e^{-k^2/2}}{\sqrt{2 \pi}} = 1.000000005350575982148479362482248080537...
which seems good to many, many decimal places in that I can increase ##N## past ##40## but it only changes the answer by miniscule amounts.
For larks did n=10^9 in MATLAB and got
1.0000000053505762043215554513153620064258575439453125
You can do a crude estimation of the error you would expect to get from only summing from ##-40## to ##40##:
\begin{align*}
\sum_{k=-\infty}^\infty \dfrac{e^{-k^2/2}}{\sqrt{2 \pi}} - \sum_{k=-40}^{40} \dfrac{e^{-k^2/2}}{\sqrt{2 \pi}} &= 2 \sum_{k=41}^\infty \dfrac{e^{-k^2/2}}{\sqrt{2 \pi}}
\nonumber \\
&= 2 \sum_{k=0}^\infty \dfrac{e^{-(k + 41)^2/2}}{\sqrt{2 \pi}}
\nonumber \\
&= 2 e^{-41^2/2} \sum_{k=0}^\infty \dfrac{e^{-(k^2/2 + 41 k)}}{\sqrt{2 \pi}}
\nonumber \\
&< 2 e^{-41^2/2} \sum_{k=0}^\infty \dfrac{e^{- 41 k}}{\sqrt{2 \pi}}
\nonumber \\
&= \sqrt{\frac{2}{\pi}} \dfrac{e^{-41^2/2}}{1 - e^{-41}}
\nonumber \\
& \approx 7.540984 \times 10^{-366}
\end{align*}
What limitation is there on the accuracy of Wolfram's outputted answer? What does MATLAB give for ##\sum_{k=-40}^{40} \dfrac{e^{-k^2/2}}{\sqrt{2 \pi}}##?
pbuk said:
Given the origin of the sum values > 1 are distracting. Probably better with the standard continuity correction when approximating a discrete distribution with a continuous one:
$$ \sum_{k=-40}^{40} \dfrac{e^{-(k - 0.5)^2/2}}{\sqrt{2 \pi}} $$
https://www.wolframalpha.com/input?i=\sum_{k=-40}^{40}+\dfrac{e^{-(k-0.5)^2/2}}{\sqrt{2+\pi}}
The Poisson summation formula works when the function is in the Schwartz space ##f \in \mathcal{S}(\mathbb{R})## which the Gaussian function times a polynomial is, which means that the calculations I did in post #15 and #16 are correct (mod any typos). So it is most definitely correct that:
\sum_{k=-\infty}^\infty \dfrac{e^{-k^2/2}}{\sqrt{2 \pi}} > 1
As for ##\nu \not= 0## we had that:
So we have for ##\tau = 1## and ##\nu = 0.5## that:
\sum_{k=-\infty}^\infty \dfrac{e^{-(k - 0.5)^2/2}}{\sqrt{2 \pi}} = \int_{-\infty}^\infty \dfrac{e^{-(x - 0.5)^2/2}}{\sqrt{2 \pi}} dx + 2 \sum_{m=1}^\infty (-1)^m e^{ - 2 m^2 \pi^2} .
So we have including first order correction term:
\begin{align*}
\sum_{k = -\infty}^\infty \dfrac{e^{-(k - 0.5)^2 / 2}}{\sqrt{2 \pi}} & \approx \int_{-\infty}^\infty \dfrac{e^{-(x - 0.5)^2 /2}}{\sqrt{2 \pi}} dx - 2 e^{- 2 \pi^2}
\nonumber \\
& \approx 1 - 5.350576 \times 10^{-9}
\nonumber \\
& \approx 0.999999994649424
\end{align*}
We can do a crude approximation of the error:
\begin{align*}
2 \sum_{m=2}^\infty (-1)^m e^{- 2 m^2 \pi^2} &< 2 \sum_{m=2}^\infty e^{- 2 m^2 \pi^2}
\nonumber \\
& = 2 \sum_{m=0}^\infty e^{- 2 (m + 2)^2 \pi^2}
\nonumber \\
& = 2 e^{-8 \pi^2} \sum_{m=0}^\infty e^{- 2 (m^2 + 4m) \pi^2}
\nonumber \\
& < 2 e^{-8 \pi^2} \sum_{m=0}^\infty e^{- 8 m \pi^2}
\nonumber \\
& = 2 \frac{e^{-8 \pi^2} }{1 - e^{-8 \pi^2}}
\nonumber \\
& \approx 1.0245001 \times 10^{-34}
\end{align*}
Meaning that we most definitely have:
\sum_{k = -\infty}^\infty \dfrac{e^{-(k - 0.5)^2 / 2}}{\sqrt{2 \pi}} < 1 .
EDIT I did make a typo in post #18 and this one. Not important typos though. I think I've corrected them now.
vs
so same number to 100 decimal places
vs
So wolfram is just not as accurate as matlab!
