The Physics of dragon flight possible
  • Thread starter Thread starter Silvershade
    Flight Physics
This discussion centers on the physics of dragon flight, specifically focusing on a dragon weighing approximately 150 lbs with a wingspan of 16 feet. Key challenges include the lift-to-mass ratio, where lift increases with the square of the radius while mass increases with the cube, making powered flight difficult. The conversation suggests using the aerodynamic principles of birds, particularly eagles, and references extinct pterosaurs like Quetzalcoatlus, which had wingspans exceeding 10 meters. The discussion concludes that realistic dragon flight requires significant adaptations in wing structure and design.
  • Understanding of lift and mass dynamics in aerodynamics
  • Knowledge of bird flight mechanics, particularly eagle flight
  • Familiarity with pterosaur biology and flight capabilities
  • Basic principles of scaling in biological structures
  • Research the aerodynamic properties of bird wings, focusing on eagle flight
  • Study the biology and flight mechanics of pterosaurs, especially Quetzalcoatlus
  • Explore the implications of scaling in biological organisms and its effects on flight
  • Investigate modern engineering solutions for creating lightweight, strong materials for wing design
Aerospace engineers, biologists studying flight mechanics, fantasy writers, and anyone interested in the scientific principles behind mythical creature flight.
Silvershade
So let's take a dragon, not a godzilla sized one because I'm trying to be realistic.. but say horse sized, roughly 1 ton in weight,
or something about wolf sized so about 150 lbs
They have 2 wings, 1 tail, 2 legs, 2 arms, and a head... because headless dragons are no fun.
how large would the wings have to be for powered flight and what tail shape would give the dragon the most energy efficient flight if the dragon wanted to behave like an eagle (swooping and coming up again)
no these dragons do not breathe fire/ are magical.. I want a pure realistic answer
A 150 pound flying dragon fly - and you're trying to be realistic. I think you have failed.
Insects, especially flying insects, don't scale up that far.
But let's say we go for a 16 foot wingspan. You'll run into two problems right away. The first is that insects don't move their wings as birds do, but if you scale them up, they better. But even with bird-like flapping, there is a problem with the strength on the wing material. You're going to need to beef up the wings - they won't look exactly like a dragon fly.
It might be better to start with an eagle, scale it to 150 pounds, and then make it look cosmetically, like a dragon fly.
Or adapt a 150 pound remote control craft to look like a dragon fly.
The problem is this. It's lift vs. mass.
Take one dimension of your beast. Let's call it the radius of your beast. The lift of the wings depends on surface area, so lift increases as the square of the radius increases. But mass increases as the cube of the radius. So as the radius increases, mass increases faster than lift. Soon the beast can't get off of the ground. Proportionally more and more has to go into the wings to get enough lift. Then you have further problems. Big wings can't beat when the beast is standing on the ground: there isn't enough room. The biggest birds have real difficulty launching themselves.
As for the most efficient shape, birds and pterodactyls and bats should be pretty much there already.
The largest known flying creatures are a group of pterosaurs named azhdarchids, extinct flying reptiles that existed during the age of the dinosaurs and died out at the end of the Cretaceous. Estimations of the wingspan of the largest species likeQuetzalcoatlus and Hatzegopteryx exceed 10 m (33 ft), with less conservative estimates being 12 m (39 ft) or more. Mass estimates for these azhdarchids are on the order of 200–250 kg (440–550 lb).[6] Golly! So those dragons could exist. There have also been 150 lb flying birds.
https://en.wikipedia.org/wiki/Argentavis
a dragon... not a dragon fly..
a reptilian dragon
Silvershade said:
a dragon... not a dragon fly.. a reptilian dragon
Sorry. I guess I was trying to be too realistic.
Dragons are pretty fat. Maybe you should start with a dragon-shaped helium balloon.
Other than that, the only difference in the discussion between dragon and dragon fly is that dragons have never flown.
Perhaps you'll settle for a pterodactyl: http://calteches.library.caltech.edu/3471/1/MacCready.pdf
Look up Pterosaurs.
They were flying reptiles that lived about 228 to 66 million years ago. They had a wingspan up to 10 meters (34 feet) and weighed in 145 kg (320 lbs).
These creatures were estimated to fly over 100 kph.
Perhaps they would make a good starting point.
Is there any particular chapter you'd like me to read to you?
http://www.amazon.com/dp/0060110740/?tag=pfamazon01-20
Insects are limited mostly in size by the concentration of oxygen in the atmosphere, not physics of flight, there have been gigantic insects in the past.
These dragons, do they have to exist on earth? Earth has a pretty thin atmosphere and pretty high gravity.
The only reason that I mentioned insects was because I misread the OP. Insects also don't scale up in terms of their body structures. In general, wing loading does not scale. For constant wing loading, you need wing area proportional to mass.
I guess the reason why dragons in fairy stories frequently are guarding treasure is so the hero has a reason to try to tackle the beast.
If there was no treasure to be had, I reckon most sane people would prefer to get the hell out of the way instead risking incineration and dismemberment.
9K
