Force I: Newton's Second Law in Inertial & Accel. Frames
  • Thread starter Thread starter Steven Wang
    Force Property
In Newton's second law, the equation F=m*a applies consistently in inertial frames, while pseudo-forces arise only in non-inertial frames. Real forces remain unchanged across different frames, similar to how temperature is consistent regardless of the observer's position. When observing a ping pong game from a NASA centrifuge, the perception of the game differs depending on whether one is in an inertial or non-inertial frame. The dynamics of the game will appear altered due to the effects of the centrifuge's acceleration. Understanding the distinction between real forces and pseudo-forces is crucial in analyzing motion across various frames.
Steven Wang
I have a problem, in Newton's second law F=m*a in inertial frame. In the accelerated frame a mass should be affected by a inertial force, but the force in the original inertial frame don't change, so real force is just like the temperature and will be the same in different frames?
Yes, the real forces are the same in any frame. But inertial pseudo-forces only appear when viewing motion from a non-inertial frame.
Thank you !
If I were in a NASA centrifuge and viewing a ping pong game in the Earth's inertial frame (neglecting coreolis forces), would the game look the same if I were in an inertial frame, and the game were being played in the centrifuge?
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 35 ·
