The range of (psi) squared is ?
  • Thread starter Thread starter peeyush_ali
    Psi Range
The range of the wave function (psi) squared, denoted as |\psi|^2, represents the probability density of finding a particle in a given volume of space. It is established that 0 <= |\psi|^2 <= 1, with the integral of |\psi|^2 over all space equal to 1, ensuring normalization. The units of |\psi|^2 are (length)^(-3), indicating that the wave function itself has units of (length)^(-3/2). The wave function can take complex values, but the probability density derived from it is always a nonnegative real number, achieved by multiplying the wave function by its complex conjugate.
  • Understanding of Schrödinger's wave equation
  • Familiarity with complex numbers and their polar form
  • Knowledge of probability density functions
  • Basic concepts of normalization in quantum mechanics
  • Study the normalization condition in quantum mechanics
  • Learn about the implications of complex wave functions in quantum theory
  • Explore the relationship between wave functions and probability densities
  • Investigate the physical interpretation of wave function phase
Students and professionals in quantum mechanics, physicists working with wave functions, and anyone interested in the probabilistic interpretation of quantum states.
peeyush_ali
the range of (psi) squared is ??
(psi) of the Schrödinger's wave equation is displacement? ( or, what are it's SI units??)
(psi) squared gives the "probability" of finding a particle in space..does this mean that,
0<= ((psi) sqaured) <=1 ??
|\psi|^2 is usually interpreted as a probability density. That is to say, not the probability of finding your particle at a point but the probability per volume of finding it in a small box at the point (small enough that psi is roughly constant for the whole box).
The probability of finding the particle in a finite (or infinite!) region R would be
\int_R \mathrm{d}^3 x |\psi(x)|^2
In particular, this must be 1 is R is all of space. This is the condition that psi is normalised.
This must mean that |\psi|^2 has units (length)^(-3), so the wavefunction itself has units (length)^(-3/2). Psi can take any complex value at all, and |\psi|^2 can take any nonnegative value, subject to the normalisation constraint.
The units of psi are funny in that they change depending on the dimension you are working in. Charge density, for example, has a surface density, or line density, and similarly for the wave-function...but they are all called psi.
hmm...(probability/volume) i wonder how this quantity can take a "non real" value..! how do u think we need to interpret and understand this?? anyone?? please! much appreciated!
umm..dimension?? the one that Schrödinger's wave equation has to tell is about charge density?! what i feel is that, it is a quantity which we use to describe discrete yet continuous therefore "probabilistic" experience of nature to define THE POSITION (charge density! :?)
of a particular free particle..
It can't; the probability density is the modulus squared of the wavefunction, a nonnegative real number, exactly as we need for any kind of probabalistic interpretation. The other bit of data in the wavefunction is the phase. The way the phase changes through space encodes data about the momentum of the particle.
If the ideas of modulus and phase aren't familiar, check out http://en.wikipedia.org/wiki/Complex_number#Polar_form" on wikipedia, particularly the bit on 'polar form'.
It doesn't. \psi is complex, in general, but |\psi^2| = \psi^*\psi[/itex] is always real. (A complex number times its conjugate is always real.)
Actually, the unit for |psi^2| is real, and represents a probability. The units for psi is complex, and you have to multiply psi by its complex conjugate to get the real value.
This might not be exactly right, but:
psi = e^(i omega t)
= cos(omega t) + i sin(omega t)
This has a wavelike real and an imaginary part, but the magnitude of the wave, you can get by taking it times its complex conjugate
psi* = cos(omega t) - i sin(omega t)
When you multiply (psi)(psi*) you get cos^2(omega t) + sin^2(omega t) which is 1.
As far as a density, though, you can have something like
kg/m for a linear density
kg/m^2 for an area density or
kg/m^3 for a volume density.
When you're just talking about one particle though, you can't exactly talk about "particles per meter^3)" You're not talking about a bunch of particles. You're just talking about one particle. So you discuss in terms of probability per meter, per square meter, or per cubic meter.
  • · Replies 59 ·
  • · Replies 32 ·
  • · Replies 0 ·
  • · Replies 21 ·
  • · Replies 21 ·
