The set of the real numbers is closed
The set of real numbers, denoted as R, is established as a closed set in topology due to its complement being the empty set, which is open. This conclusion is supported by multiple definitions: a set is closed if it contains all its limit points, and R is constructed as the completion of the rational numbers through Cauchy sequences. The discussion clarifies that R is both open and closed, or "clopen," in its topology, emphasizing that the definitions provided are equivalent and foundational. Misunderstandings regarding the nature of closed sets and their boundaries are addressed, reinforcing the triviality of R's closed status.
  • Understanding of basic topology concepts, including open and closed sets.
  • Familiarity with metric spaces and the concept of limit points.
  • Knowledge of Cauchy sequences and their role in real number construction.
  • Awareness of the definitions of clopen sets in topology.
  • Study the properties of clopen sets in various topological spaces.
  • Explore the construction of real numbers through Cauchy sequences in detail.
  • Learn about different topologies on R and their implications for closed sets.
  • Investigate the implications of the completeness of metric spaces in topology.
Mathematicians, students of topology, and anyone interested in the foundational aspects of real analysis and metric spaces.
tom.stoer
The set of the real numbers is closed.
For me this is nearly trivial (*) but perhaps I miss something; a colleagues insists that there are some deeper considerations why this is far from trivial - but I don't get his point
A) A set is closed if its complement is open; the complement of R is ø which is open, therefore R is closed
B) In a topological space, a set is closed if it contains all its limit points; this applies directly to R (see also D)
C) In a complete metric space, a set is closed if it's constructed as the closure w.r.t. to its limit operation; the set of real numbers can be constructed as completion of the rational numbers in the sense of equivalence classes of Cauchy sequences; then Q is dense in R by construction and R is closed by construction
Do I miss something? Are there more fundamental definitions of closed sets? Is it problematic that closed sets are defined via limiting points of convergend sequences whereas this does not apply to R as a whole b/c it misses the "boundary" of R which could be defined by divergent sequences (xn) → ∞?
I do not see such problems, but perhaps I am missing something.
There are no problems. Most of the definitions you have given are derived equivalent definitions of 'closed' from the topological standpoint wherein the most fundamental definition of being closed is simply that of a set whose complement is open. In topology we take by definition that both the overarching space and the empty set belong to the topology so the overarching space is always both open and closed. There's nothing deep about this, it is trivial like you said.
Every element of the reals is the limit of a sequence of rationals as per the Cauchy construction so there's no problem there either if you want to look at things from the less fundamental perspective of metric spaces. ##\partial \mathbb{R} = \varnothing ## which is exactly what characterizes the fact that ##\mathbb{R}## is both open and closed in its topology.
thx!
Maybe the point of such an "almost trivial" question was to show that a naive idea like "a closed set is something like a closed interval that includes its end points, and an open set is something like an open interval that doesn't include its end points" is wrong.
As mentioned above, as a metric space R is closed. But, perhaps your colleague is alluding to the development of R as the closure of the rationals, which is far from trivial if you do it rigorously.
In other words, it's not that easy to justify rigorously a continuous number line.
thx for your ideas; unfortunately nothing like that does apply; my conclusion is that he got it wrong ;-)
This is nitpicking: That statement should probably read something like "[...] alluding to the development of R as a completion of the rationals [...]" since there are multiple completions of the rationals.
The empty set is clopen, not open, and R is similarly clopen rather than closed. Both sets have no boundary points, and thus they simultaneously contain all and none of their boundary points.
Well, if we're going to nitpick: the statement should read "##\mathbb{R}## with the Euclidean metric is a completion of the rationals" Since there are multiple topologies on ##\mathbb{R}##
How is the empty set not open?
How is the empty set not closed?
It's both open and closed, or clopen.
Yes, it is closed and it is open. Therefore I found it a bit weird that you said that the empty set is not open.
nitpicking again, but the statement "the empty SRT is clopen, not open" is logically wrong
a set is clopen iff it is open and closed; R is clopen; therefore R is closed and open; therefore R is closed
a number is preven iff it is prime and even; 2 is preven; therefore 2 is prime and even; therefore 2 is prime
The statement "2 is preven, not prime" is more than weird.
Every topological space is both closed and open in its topology.
:confused:
Saying that R is "clopen rather than closed" seems to imply some sort of dichotomy between the two. Closed doesn't mean "closed but not open," it means closed. It is never wrong to call a clopen set closed. This is like saying that 3 is an integer "rather than" a real.
  • · Replies 20 ·
