The space between a unit 'sphere' in n dimensions within an n-dimensional cube
The discussion revolves around the properties of the space between a unit sphere in n dimensions and an n-dimensional cube. Participants explore the mathematical implications of this relationship, including the gaps between the sphere and the cube as dimensions increase, and the challenges of proving these properties in higher dimensions.
  • Some participants note that the gap between a unit sphere and an n-dimensional cube is expressed as √n - 1, which raises questions about its implications as n increases.
  • There is a suggestion that Pythagorean principles can be applied to prove the relationship in lower dimensions, but uncertainty exists regarding the proof for n dimensions.
  • Induction is proposed as a potential method for proving the properties of the n-dimensional cube and sphere, but some participants question its applicability.
  • One participant discusses the surprising properties of higher-dimensional spheres, including the behavior of their volume and surface area as dimensions increase.
  • Concerns are raised about the continuity of the pattern observed in lower dimensions for n greater than 3, with calls for proof or clarification on the definitions involved.
  • Discussion includes the concept of infinite-dimensional spaces, with participants noting that the volume of the gap between a unit sphere and a unit cube tends to infinity in such cases.
  • Some participants argue that volume in infinite-dimensional spaces is not well-defined, and there are multiple types of infinite-dimensional spaces.
  • An example of an infinite-dimensional space is provided, highlighting its deficiencies and the challenges in defining completeness.
Participants express a range of views on the proofs and properties discussed, with no consensus on the applicability of induction or the definitions of volume in infinite-dimensional spaces. The discussion remains unresolved regarding the continuity of the pattern for n greater than 3 and the nature of infinite-dimensional spaces.
Participants highlight limitations in definitions and the existence of gaps in mathematical concepts, particularly in the context of infinite-dimensional spaces. There is an acknowledgment that the concepts of volume and area may not have a universally accepted existence beyond basic definitions.
prane
If we have a unit circle within a square s.t. the square touches the circle in 4 places then the biggest gap we can find is just √2 - 1.
Doing a similar thing with a sphere in a cube we get √3 - 1
I've heard the n-dimensional analogue is √n - 1. Which is crazy as it means the gap is bigger than the radius of the sphere! (When n is greater than 4).
Anyway, how is such a thing proven?
pythagoras?
Yeh the result can be proven by Pythagorus in 2 and 3 dimensions but what about n?
induction?
Higher-dimensional spheres have some surprising properties. The (hyper-) volume and (hyper-) surface area of a unit sphere increase for a while as the dimension goes up, but they reach their maximum values pretty soon, then decrease forever after that.
Consider an n-dimensional "cube" that just contains the n-dimensional sphere of radius 1: the midpoints of the sides of the cube are at distance 1 from the origin, but as you noted, the corners are farther away. For n=2 we have a square, whose corners are at distance \sqrt2 from the origin, and when n=3, we have an ordinary cube whose corners are at distance \sqrt3. This pattern continues; when n=4, the distance is 2, when n=9 the distance is 3, when n=100 the distance is 10, and so on. Obviously there's no limit to how far away those corners get as the dimension becomes very large. But since every point on the sphere, of any dimension, is at distance 1 exactly, you can see why the sphere takes up less and less of the cube as the dimension increases.
My question though is, how do we know that this pattern continues for n greater than 3? If it's just defined to be that then I can kind of see why but is there any 'proof'? This result surely cannot be proven by induction?
the face of an n cube is an n-1 cube. The diagonal of an n cube thus is the hypotenuse of a right triangle whose other two legs are: 1) an edge of the n cube, 2) a diagonal of a face, i.e. a diagonal of an n-1 cube.
thus usual pythagoras supplies the inductive step to prove the diagonal of an n cube of edge length one, has length sqrt(n) = sqrt{1^2 + sqrt(n-1)^2}.
what about the ∞-dimensional case...?
In such a case the volume of the gap between the ∞-dimensional unit sphere and the ∞-dimensional unit cube is +∞.
Moreover the ratio of the volumes of the unit sphere and unit cube is given by \lim_{n\to +\infty} \frac{\pi^{n/2}}{2^n \Gamma(1+n/2)}
and in this case the above quantity tends to 0.
Shall we conclude that in a ∞-dimensional space the unit-sphere behaves likes a point ?
No, you should conclude that volume in an infinite-dimensional space is not a well-defined concept. Furthermore, there are multiple kinds of infinite-dimensional spaces.
micromass;4027511} said:
[...] Furthermore, there are multiple kinds of infinite-dimensional spaces.
Could you just make an example on how to make an ∞-dimensional space out of ℝn that would not be the trivial method of "increasing the number of dimensions" up to infinity?
I'm not sure what you mean with with "make an infinite-dimensional space out of \mathbb{R}^n".
But anyway, the easiest infinite-dimensional space to work with is probably the set of all sequence (x_n)_n which are eventually 0. So an example of an element in that set is (2,5,2,3,0,0,0,0,0,...).
But this is not a very interesting infinite-dimensional space because it has quite some deficiencies. One such deficiency is that it is not "complete". This means that it has gaps (just like \mathbb{Q} has gaps compared to \mathbb{R}).
There are various ways to make this space complete, and all these ways are useful in some way.
Proof of what? You seem to think that these concepts of "volume" and "area" have some kind of existence beyond the basic definitions. That's not true (not even for two and three dimensions).
  • · Replies 16 ·
  • · Replies 35 ·
