The speed of light in a vacuum?
The discussion centers on the concept of the speed of light in a vacuum, with the premise that light's speed (c) is defined in a perfect vacuum, which is deemed practically impossible. Participants debate the validity of this conclusion, arguing that while perfect vacuums may not exist, there are areas in space that can be considered vacuums for practical purposes. The conversation touches on the implications of light's speed in various mediums and the relevance of energy fields in defining vacuums. Some assert that the theoretical nature of the vacuum does not negate the practical applications of light speed in technology. Ultimately, the dialogue highlights the tension between philosophical interpretations and scientific definitions in understanding the speed of light.
Sauwelios
Premise A: The constant c is the speed of light in a perfect or absolute vacuum.
Premise B: A perfect or absolute vacuum is a practical impossibility.
Conclusion (C): The speed of light in a vacuum is a purely theoretical concept.
Note that I am, or consider myself, a philosopher. If I am a physicist, I am at best a classical physicist. I am not asking for highly advanced equations as a response to my argument. I just want to know whether it is valid (i.e., whether the conclusion follows from the premises) and whether it is "true", i.e., whether it is probable that my premises are correct. Thank you.
vacuums are not impossible. Yes, a reasonably sized vacuum is impossible, there will always be radiation inside of it. However if you go sub-microscopic there are vacuums all over.
How do you know? Have you run any experiment that proves your statement?
If I remember correctly there is about 1 hydrogen atom per cubic mile in deep space. Pretty good vacuum between hydrogen atoms isn't there?
I presume that your "A perfect or absolute vacuum is a practical impossibility" was referring to "in the lab" which is irrelevant to the question of "speed of light in the vacuum".
First of all, you need to understand WHY light appears to have a different speed in a medium. Once you understand that, THEN you can figure out why, for example, it is so difficult to detect any variation of the speed of light in air, for example, when compared to a "vacuum". Thus, even in air, we already have, for all practical purposes, the vacuum speed of light.
Furthermore, your "logic" failed to consider the fact that if such an assumption isn't valid, we would have detected a slew of problems already. Satellite transmissions, GPS, etc.. etc... ALL make the assumption on light speeds. Considering that you directly depend on such things, I would point to you and what you use as evidence for its validity.
Zz.
Why does light appear 2 hav a different speed in a medium? Tiny spacetime warps caused by the matter (just 2 throw a guess at it)?
Read our FAQ in the General Physics forum.
Zz.
I see now:
"A vacuum is a volume of space that is substansively empty of matter"
http://en.wikipedia.org/wiki/Vacuum
"In physics, matter is commonly defined as the substance of which physical objects are composed, not counting the contribution of various energy or force-fields"
http://en.wikipedia.org/wiki/Matter
I do count that contribution.
Then, do you also count the gravitational field from Alpha Centauri in your everyday life and therefore, argue against all obervations that neglect it?
Zz.
Sauwelios said:
I see now:
like zapper said, its ridiculous to actually count this stuff. If you count force-fields then there is no such thing as a vacuum. However, I am not sure if curvatures in space-time slowdown light, which would mean that only energy could distinguish a vacuum from a non-vacuum. Like I said before, although there is a lot of radiation, if you shrink your scope enough you will be able to find many vacuums void of any energy.
But I think those vacuums are functions of the energy surrounding them. If there was no energy, there would be no vacuums.
Light is itself energy. The presence of light itself makes space not a vacuum, under your expanded definition.
In the strictest of senses, I would say yes, it is a purely theoretical construct. Of course, there are some implications of this, combined with current knowledge of the universe, which make it an eminently practical one to cling on to.
Physicists and engineers don't like to speak in the strictest of senses, because frankly, that way lies nihilism and stagnation.
And how are you able to come up with this, considering that you don't think that there is such a thing as a "vacuum"? What is the justification for that statement? [This is, after all, physics and not philosophy.]
Zz.
I think the number is more in the m^3 to cm^3 range.
Not that it matters. Even at one atom per cm^3 is a vast, vast playground for light to romp around in and not have to go play with the big atoms.
Question: why, simply because we can't make a perfect vacuum, can we not determine the speed of light? We can determine c over very short distances, short enough that we don't have to worry about atoms.
what??
yes, light is energy, along with all other radiation. However, there isn't radiation in every single point in the universe. There are still many small areas that lack any radiation.
Zz.
They are relative, not absolute, vacuums: relative to the energy around them.
michael879 said:
what??
But theoretically, light cannot pass through these, for when it does, there is radation there. I admit this is a sophistry, like the tortoise and the hare.
Supposing there are areas which, in themselves, are absolutely empty, I think these are a function of what surrounds them, by which I mean that the concept of such an area is due to our idea of particles, of substance, which still reigns supreme: even a wave, or a quantum, is such a mathematical idea which, in reality, does not exist.
Question: do you think there can be equal quanta?
Are you making this up as you go along?
What is a "relative vacuum"? How is such a term defined in physics?
Before you proceed any further, please keep two things in mind:
1. EVERY single concept and terms in physics has a clear, unambiguous underlying mathematical description. This means that things in physics simply can't be mixed and match to our heart's content, because often, this will lead to absurdity. This is what you are trying to do. You are using terminologies that have clear definitions in physics, yet in ways in which they simply makes no sense.
2. Re-read our PF Guidelines regarding speculative, personal theories. While you might think such speculative, unsupported statements are fine in philosophy, it is not tolerated here in the physics forums. Thus, unless you are able to cite for me established physics or peer-reviewed papers to support whatever it is you're trying to push, then you are involation of the Guidelines that you have explicitly agreed to. You have to submit your "ideas" to the IR forum to continue this line of discussioin.
Zz.
Sauwelios said:
...However, there isn't radiation in every single point in the universe. There are still many small areas that lack any radiation
Maybe Sauwelios intended to ask if it's possible that light, that is an EM field, could change the EM properties of vacuum itself?
Note that we have a philosophy forum. Generally speaking, philosophical questions about 'existence' will find a much better home there, than in the physics forum.
As far as whether or not your statements are correct, first tell us if you exist, and if you think you do exist, why you think you exist :-). But please, do it in the philosophy forum, not in the physics forum.
  • · Replies 93 ·
  • · Replies 51 ·
  • · Replies 21 ·
  • · Replies 26 ·
  • · Replies 42 ·
  • · Replies 34 ·
