How Does Spring Buoyancy Affect Weight Readings in Fluids?
  • Context: Undergrad
  • Thread starter Thread starter Misr
    Buoyancy Spring
This discussion focuses on the mechanics of spring scales and buoyancy in fluids, specifically addressing how buoyant forces affect weight readings. Participants explore the relationship between the buoyant force and the apparent weight of a submerged ball, concluding that the spring scale measures both the weight of the displaced water and the buoyant force acting on the ball. The conversation highlights that as the ball descends, the buoyant force increases, impacting the readings on the scale. Ultimately, the discussion clarifies that the scale's reading is influenced by the combined forces acting on the ball and the water it displaces.
  • Understanding of Archimedes' Principle
  • Familiarity with spring scale mechanics
  • Knowledge of buoyant force calculations
  • Basic principles of fluid dynamics
  • Research the mathematical formulation of Archimedes' Principle
  • Explore the mechanics of spring scales in different fluid environments
  • Study the effects of fluid density on buoyancy and weight measurements
  • Investigate the relationship between pressure and buoyant force in fluids
Students and professionals in physics, engineering, and fluid mechanics who are interested in understanding the principles of buoyancy and how they affect weight measurements in various fluids.
Misr
Hello,world
[PLAIN]http://img507.imageshack.us/img507/4446/samar.jpg
1-How does this spring scale work?
2-Where does this increase in the reading of the normal balance(scale) come from?
Does it come from the rise in water level in the tank?Okay water already has aconstant mass
Does it come from the weight of the ball?I don't think so.
3-why does the apparent weight decreases as the ball goes down into the fluid(by increasing depth)??may be because the buoyant force increases..
the buoyant force is different in case(2) and case(3) although the ball already displaced the same volume of water-so buoyancy should be the same.can you realize my problem here?
4-In case(3)
The spring reads zero
which means that Fb=Fg
so the body should suspend in water instead of sinking ...or may be the spring is exerting a certain force to maintain the ball in this position.may be this question is related to the first one which is concerned with the mechanism of the spring balance
5-can we know from this picture if the spring has a smaller-equal-bigger density than that of water?or it just doesn't indicate?
1.- When the ball is at the bottom, the weight of it is being held by the bottom scale and the top feels nothing.
2.- In the middle, the ball is being pushed up by a force equivalent to the weight of the volume of water displaced...so the water is pushing up and so the scale at the bottom feels such reaction and the scale at the top feels the help
3.- Same as 2, except that there is water displaced.
4.- ...
From the readings, I gather this ball definitely sinks in water. In other words, the long line from the top scale down to the ball could be a rope and it would still work this way.
Do you mean that the normal balance measures the upward force only,either the normal force of the water tank or the buoyant force?
When the ball is not at the very bottom, the balance reports the weight of the water plus the buoyant force.
first what do you mean by "the scale at the top feels the help"?which help?
how does the normal balance report both the weight of water plus the buoyant force??
may be due to the increase in pressure at the base f the tank due to rise in water,this indicades an increase in the total force affecting the base of the top ,thus increasing the reading of the normal balance.
Is it because water rises in the tank?does it measures the weight of water + weight of water that rises?how about the weight of this suspended ball?
but this doesn't tell me why the buoyant force is different in case(2) and case(3) although the ball already displaced the same volume of water-so buoyancy should be the same
4-In case(3)
I still don't know the answer to this question.
if the body floats,then it would suspend in case 4 instead of sinkning in the bottom (Fg=Fb) true?or I still don't understand how this ballance works ?
Let's supposed the you can reach the ceiling of the room you are in and you place a balance on the floor and you weigh yourself...how much do you weigh?
Now, raise your arms and push against the ceiling...how much does the balance reports?
It's the same when the ball is mid-water...because of Archimedes, the water exerts an upwards force on the ball, but because the ball will not float and go up, instead it stays where it is, then the balance under the water reports the weight of the water, plus the reaction force of pushing the ball up that will not move.
does this help?
Oh, and...
I meant to say:
3.- Same as 2, except that there is LESS water displaced.
It would report much force,my weight + the force that i apply on the ceiling
correct?
yeap
  • · Replies 24 ·
10K
  • · Replies 48 ·
11K
