The Strong Nuclear Force: Is my understanding correct?
The discussion revolves around the strong nuclear force, its nature, and its role in binding nucleons (protons and neutrons) within atomic nuclei. Participants explore the force's characteristics, including its range, the interactions between quarks, and the implications for understanding nuclear binding energy. The conversation touches on both introductory and technical aspects of particle physics.
  • Some participants assert that the strong nuclear force is the strongest of the four fundamental forces and has a very short range, requiring nucleons to be extremely close for its effects to be felt.
  • Others emphasize that the strong force operates between quarks, specifically noting that the interaction between quarks within a single nucleon is also a form of the strong nuclear force.
  • There is a discussion about the binding energy of nuclei, with some arguing that it is the energy due to the strong nuclear force minus the disruptive energy of the Coulomb force.
  • A participant suggests that the strong force can be approximated as the exchange of mesons when discussing nucleon interactions, while others clarify that this is an approximation of the underlying quark interactions.
  • Some participants express concern over the complexity of concepts like binding energy in introductory discussions, suggesting that simpler explanations may be more appropriate.
  • There is contention regarding the terminology used to describe the strong force, with differing views on whether the interaction within a single nucleon should be referred to as the strong nuclear force.
  • One participant notes that the strong interaction between nucleons is a residual effect that decreases rapidly with distance, contrasting with the strong interaction that binds quarks within a nucleon.
Participants do not reach a consensus on the precise nature of the strong nuclear force and its terminology. There are competing views on whether the strong force should be described in terms of quark interactions within a single nucleon or as an interaction between nucleons. The discussion remains unresolved with multiple perspectives presented.
Some statements made by participants depend on specific definitions of terms like "strong nuclear force" and "binding energy," which may not be universally agreed upon. The discussion also reflects varying levels of familiarity with particle physics concepts, leading to different interpretations of the same phenomena.
A M
TL;DR
I want to write a student article specially for those who don't have a background in nuclear physics. I've been suggested to share my basic understanding & ask if they're correct.
I would be grateful if anyone could explain where my mistakes are:
(Please note that diagrams are designed just to give a simple imagination of the article & make it more understandable; they do NOT correspond precise information.)
The strong nuclear force is the strongest of the four basic forces in nature (the others are: the electromagnetic force, gravity, and the weak nuclear force). But it also has the shortest range, meaning that nucleons (protons & neutrons) must be extremely close (~1 fm) before its effects are felt.
The nuclear force can be explicated simply by analogy with the force between two small magnets: magnets are difficult to separate when stuck together, but once pulled a short distance apart, the force between them falls [almost] to zero.
This force between nucleons is done through the exchange of particles called mesons. As long as this meson exchange can happen, the strong force is able to hold the participating nucleons together.
https://www.physicsforums.com/attachments/2-jpg.248608/
For the lightest nuclei, the energy of the strong force per nucleon generally grows rapidly; because when a nucleon is added to such a small nucleus, the strong force attracts it to all the other constituent proton/s and neutron/s. I.e. the nucleus is sufficiently small that by adding each nucleon, all the others feel stronger effect.
But this trend approaches a limit corresponding to that of larger nuclei, because the nuclear force is short-range and cannot continue to act across longer nuclear length scales. (Generally, by this force a nucleon can only affect its close neighbors.)
Except for the lightest nuclei that all the nucleons are close to each other, for heavier elements the nucleons in the interior of a nucleus have more neighboring nucleons than those on the surface. So, according to the fact 'the larger a nucleus, the smaller its ratio of surface area to volume ', the energy of strong force per nucleon generally increases with the size of nucleus. (But it grows more and more slowly depending on the changes of the ratio.)
References:
http://aether.lbl.gov/elements/stellar/strong/strong.htmlhttps://en.wikipedia.org/wiki/Nuclear_binding_energy
Yes, but more precisely it is the force between the quarks of TWO nucleons.
(The interaction between the quarks of a single nucleon isn't called the strong nuclear force.)
And as I've already included, this article is specially designed for those don't have much information about particle physics, so they do not know what exactly a quark is.
There IS a strong nuclear force between quarks of a single nucleon, of course. This is what is mostly responsible for the interactions of the quarks within a nucleon.
nrqed said:
There IS a strong nuclear force between quarks of a single nucleon, of course. This is what is mostly responsible of the quarks within a nucleon.
Omg, it's getting worse and worse. if it IS the interaction between the quarks of a single nucleon, the fact that "the binding energy of a nucleus is is the energy due to the strong nuclear force, minus the disruptive energy of Coulomb force" is meaningless.
Or if that fact is true, "the strong nuclear force" in this article can be the simplified form of 'the strong nuclear force between the quarks of two nucleons', as I said.
[And it is important to keep in mind that this is an introduction topic; if I say the strong nuclear force is the interaction between quarks, then I should explain what a quark is, what kind of quarks nucleons are made of, and also its responsibility to hold quarks together to form other hadrons]
Do you really suggest me to get that technical about it?
Well, we are not here to tell you or suggest to you how to do your presentation, that's your prerogative. We are here only to answer physics questions. The fact is that the strong force is a force between quarks (and is due to the exchange of gluons) . It holds the quarks inside nucleons together. It is also the force responsible for holding nucleons together in nuclei. In that case, one can approximate the force as the exchange of mesons, but this is an approximation of the underlying process which is still a force between quarks (in physics we often approximate fundamental forces by simpler pictures when working at different energy or distance scales).
If the statement about binding energy bothers you and you want to present something introductory, then just do not mention binding energy at all (which is a fairly difficult concept to start with).
Well, that's my prerogative! Suggesting not to mention something is a suggestion itself!
(I know, I'm a bit stubborn; but the whole my article is based on the definition of binding energy, so I'd rather use that approximation as you said. Thanks for your suggestion -or anything else you call it!)
Thanks! this part of your reply (answer to physics question!) helped me improve my article. As you said, I can approximate this force as the exchange of mesons, to avoid confusion.
(By this approximation, it would be easier to explain binding energy and the balance of forces. Anyway, thanks for your correction! :smile: )
mathman said:
Strong force is a force between quarks
It's more complicated than either of these.
In a single nucleon, the strong interaction binds the three quarks together. This interaction actually increases in strength with distance; it confines the quarks to within the size of the nucleon, roughly ##10^{-15}## meter.
However, once the three quarks are bound within a single nucleon, when viewed from outside that nucleon, almost all of the quark-quark interaction is cancelled. The strong interaction between nucleons is a residual interaction that is left over. This interaction decreases rapidly with distance, so it only is significant between nearby nucleons.
The interaction between the quarks of a single nucleon is not the same as the interaction between nucleons. They do both originate from the strong interaction, but at the level you are presenting this material, they are best viewed as different interactions with different behavior. See my post #10 just now.
Also, statements like "omg, it's getting worse and worse" are highly inappropriate. You are asking for help and people are doing their best to provide it. You have admitted that you are a beginner in this subject. Your understanding of the subject is clearly very basic and highly incomplete. That in itself is fine, because you're a beginner; but it means you should not presume to tell other people that their contributions are "getting worse and worse". Especially when you are mistaken yourself.
If you're not going to talk about quarks and how they make up nucleons, I'm not sure it's necessary to talk about meson exchange either. You can just say there is an interaction between nucleons and briefly describe the properties of the interaction that are important.
By this statement, I just meant that my understanding of this force is in contrast with what has been said, and thus it is getting 'more and more confusing to me'. I did not mean that "their contributions" are getting worse.
I'm not a native or a good English speaker. I sometimes can't express exactly what I mean, I have already admitted that I was mistaken myself, and accepted it, but if some of my words aren't expressed the way I really meant, or they are 'highly inappropriate' [like that "wanna"], or I've bothered you with any of my statements, I am very sorry. I did not really mean to do that.
Understood. We'll keep that in mind.
  • · Replies 28 ·
  • · Replies 44 ·
