The topology of rational numbers: connected sets
The discussion centers on the topology of rational numbers, specifically addressing the total disconnection of the space under the metric d(x,y)=|x-y|. It is established that the only connected subsets of the rational numbers (Q) are the empty set and individual points. The participants clarify that for a set {x} U {y} to be disconnected, one must find two non-empty disjoint open sets U and V that cover {x} U {y}, which is achieved by recognizing that {x} is open in the induced topology. The confusion arises from the definition of disconnected sets and the role of irrational numbers in separating points in Q.
  • Understanding of metric spaces and the concept of distance functions.
  • Familiarity with the definitions of connected and disconnected sets in topology.
  • Knowledge of induced topology and its implications on subsets.
  • Basic comprehension of rational and irrational numbers and their properties.
  • Study the concept of induced topology in more depth, particularly in relation to subsets of metric spaces.
  • Explore the properties of totally disconnected spaces and their implications in topology.
  • Learn about the role of irrational numbers in separating rational numbers within metric spaces.
  • Investigate examples of disconnected sets in various topological spaces to solidify understanding.
Mathematicians, students of topology, and anyone interested in the properties of rational numbers and their topological implications.
alligatorman
Consider the set of rational numbers, under the usual metric d(x,y)=|x-y|
I am pretty sure that this space is totally disconnected, but I can't convince myself that the set {x} U {y} is a disconnected set.
It seems obvious, but I can't find two non-empty disjoint open sets U,V such that U U V = {x} U {y}.
I am sure {x},{y} are not open sets, so I need something bigger.
Is the total disconnection only true if the the set Q is a relative topology of R?
Thanks
You can always map Q isometrically into R by the trivial embedding (q is mapped to q, with the standard metric in R). This is useful for the end result. Total disconnection means the only connected subsets of Q are the empty set and individual points. Suppose A is a connected subset of Q. Then there exists x,y in A s.t. x=/= y. We know there exists an irrational in between x and y. Now here's the thing... that irrational (call it z) isn't in Q, but we can still use it to our advantage as we can split A by A = {a in A | a<z in R} U {b in A | a>z in R}
and then you can show that both of those are open.
To clarify in your post though
When a subset of a space is disconnected, it means you can find two open sets in the subspace. The set {x} is open in {x}U{y} (the induced topology is B subset of A subset of X, B is open in A iff there exists V open in X s.t. B = A intersect V)
Thanks for the help. It was the definition of a disconnected set that was messing me up.
