Can universal microscopes view viruses without killing them?
Universal microscopes, as developed by Dr. Royal Rife in the 1930s, are largely considered a hoax and are not in use today. Unlike electron microscopes (EM), which operate under high vacuum and bombard samples with high-energy electrons, potentially damaging biological specimens, universal microscopes purportedly allow for the observation of viruses without killing them. The discussion highlights the destructive nature of electron microscopy, particularly its inability to image fluids and the requirement for sample fixation and metal coating, which compromises sample viability.
  • Understanding of electron microscopy principles, including high vacuum and electron bombardment.
  • Familiarity with biological sample preparation techniques for microscopy.
  • Knowledge of microscopy resolution concepts, including Rayleigh's criterion.
  • Basic understanding of fluorescence microscopy and STED technology.
  • Research the principles and applications of STED microscopy technology.
  • Learn about the differences between electron microscopy and optical microscopy.
  • Investigate the effects of high-energy electron bombardment on biological samples.
  • Explore advancements in non-destructive imaging techniques for viruses and other biological specimens.
Researchers in microbiology, microscopy specialists, and anyone interested in advanced imaging techniques for biological samples.
HorseBox
I was reading about Dr Royal Rife and his universal microscope there and the author of the article claimed that universal microscopes can be used to view viruses without killing them like electron microscopes do. Is this true? Also are these universal microscopes still in use today? Before now I'd heard of electron microscopes but never universal microscopes.
Biology news on Phys.org
According to http://en.wikipedia.org/wiki/Royal_Rife" this is now pretty much a hoax. This was a devise developed in the 1930's and never made to work as claimed.
And why would an electron microscope kill viruses?
I read that the electrons bombard the viri killing them. I don't even know how electron microscopes work I was just quoting what I read.
In an electron microscope (SEM) the sample is under high vacuum which is usually bad for most biological samples (although I guess a virus could survive), and the vacuum means that you can't image fluids so the virus would have to be "dry".
The sample is also being continuously being bombarded by high energy electrons, the electron energies are so high that imaging is often considered "destructive" even for things like small electronic circuits (although that is partly because of the charge buildup) so presumably the electrons would severely damage a virus.
It is also not possible to get good images of insulating samples (again because of the charge buildup) which is why biological samples are usually covered by a very thin gold film before being put in the SEM.
It's true that for EM you need to fix a sample and cover it with a heavy metal (not very good for the viability of your sample).
Have you people heard of the STED microscope technology? What I understand the resolution goes beyond the wavelength of the excitation beam, by using a trick with a second beam (sub-diffraction-limit fluorescence microscopy).
Do you know how the technique works?
In an electron microscope, the electrons act as waves, instead of as particles. Photons are massless, so they have a minimum wavelength. Since electrons have mass, they correspond to smaller wavelengths than photons, so an electron microscope provides better resolution than an optical microscope.
1) Electrons act as both particles as well as waves in the electron microscope.
2) It is due to the high accelerating potential that the electrons have a low wavelength but not due to the mass that they have smaller wavelengths.
If you have a smaller wavelength, according to the Rayleighs criteria, you have a better resolution, which is the ability to distinguish two closely spaced objects, and for this the wavelength of the probe should be of the order of this separation between objects
  • · Replies 43 ·
75K
  • · Replies 47 ·
  • · Replies 33 ·
High School The M paradox
