Undergrad The Universe accelerating and light
The discussion centers on the implications of the universe's accelerating expansion, quantified at 68 km/s per megaparsec. Participants clarify that recession velocities differ based on distance, and concepts like "inertial frames" are debated in the context of General Relativity (GR). It is established that receding galaxies do not share the same inertial frame as observers, thus time dilation does not apply. The conversation highlights the complexity of defining inertial frames in curved spacetime, emphasizing the need for precise terminology in physics.
  • Understanding of General Relativity (GR)
  • Familiarity with the concept of inertial frames
  • Knowledge of cosmological expansion and recession velocities
  • Basic grasp of spacetime curvature
  • Research "General Relativity and inertial frames" to deepen understanding of reference frames in curved spacetime.
  • Explore "Hubble's Law" to understand the relationship between distance and recession velocity.
  • Study "Time dilation in General Relativity" to comprehend its applicability to different frames of reference.
  • Investigate "Cosmological redshift" to learn how the expansion of the universe affects light from distant galaxies.
Astronomers, physicists, and students of cosmology seeking to understand the effects of the universe's expansion on observational phenomena and the implications of inertial frames in General Relativity.
Jaami M.
How are we, and the universe effected from its accelerating expansion? Also how will our perception of the world around us be effected, since the universe is expanding and light is constant? <-Will things appear to move slower? I know that we only experience just a small fraction since the universe expanding velocity is 68 km/sec or 42.253 mi/sec. But is there any type of effect?
Space news on Phys.org
We are not... the world around us in unaffected, though what we see of large distances is affected.
"Universe expanding velocity" is a meaingless term.
The expansion velocity is actually expressed as km/s/megaparsec. In other words, it's 68 kilometers per second per megaparsec. This means that objects 2 megaparsecs apart recede from each other at 136 km/s, double the velocity at one megaparsec. So the recession velocity is actually different for all objects based on their distance apart.
Jaami M. said:
... Will things appear to move slower?
No, things seem to move slower when they are moving relative to you in the same inertial frame of reference. Receding galaxies are not IN the same inertial frame of reference so time dilation is not applicable.
What? What does "the same inertial frame" mean?
I thought that was a well defined concept, no? If we are both on the same train and it is not accelerating then we are in the same inertial frame. If I'm on the platform and you're on the train and it's not accelerating (relative to me) then we are both in the same inertial frame. If I'm on the train OR the platform, a receding galaxy is not in an inertial frame relative to me.
I've never seen it used like that before. To me, the "same inertial frame" would be the two of us on the train or the two of us on the platform, not moving relative to each other. If you're on the train and I'm on the platform we will see things differently, so I wouldn't call it the same inertial frame. We're both in an inertial frame, but not the same one.
I'm also unsure about whether or not a receding galaxy is considered to be in an inertial frame. It's certainly not accelerating in its own frame, but I don't know how things like this are handled in GR.
I think maybe it's the way we use the words. If I'm on the platform and you're on the train (moving but not accelerating) you are moving in my inertial frame so I say we're in the same inertial frame, but I see what you mean by the way you use the term.
The same inertial frame is not a very meaningful concept in GR because space-time is generally curved. The only way to make proper sense of it is if you have two observers at the same event. Those inertial frames are local and not global.
Exactly. And if one of them is moving (but not accelerating) would you find it correct to say that they are "in the same inertial frame" as I do or do you hold with Drakkith's point of view that they are each in inertial frames but not the same one? Seems to me both points of view are right, actually.
The "frame" of an object is usually (represented by or pictured as) the coordinate system attached to the object.
Two objects share the same reference frame if they are stationary with respect to each other.
However - it is common in physics to mix up technical and non-technical uses.
If two people are in the bath, moving about, then we say they share a bath ... we can put the grid on the bath and , similarly, in a non-technical sense, talk about the two people sharing the bath coordinate system ... but, in the technical use: that is the frame of the bath, not the people. If one were stationary in the bath, then that one would share the frame of the bath as well as being in the frame of the bath.
When a physicist writes about something moving in a frame, that's usually what is meant.
There are a lot of references about reference frames ... having trouble finding any that spell out when two objects share a frame.
Thanks for that, Simon.
  • · Replies 23 ·
  • · Replies 19 ·
  • · Replies 54 ·
  • · Replies 18 ·
  • · Replies 33 ·
