The x,y,z coordinates of CM of a solid cylinder
The discussion focuses on calculating the coordinates of the center of mass (CM) for a solid cylinder and its segments. The y-coordinate is established as 120 mm, the x-coordinate as -51.9 mm, and the z-coordinate as 69.1 mm. The participants confirm that for a complete cylinder, the CM is at the midpoint, while for a quadrant, the CM lies on the plane of symmetry at 45 degrees. The centroid of a semicircle is also noted as R * 4 / 3π, providing an alternative calculation method.
  • Understanding of solid geometry and integration techniques
  • Familiarity with cylindrical coordinates and their applications
  • Knowledge of centroid and center of mass concepts
  • Basic proficiency in using mathematical tools like Wolfram Alpha
  • Research "Cylindrical Segment centroid calculations" on Wolfram Alpha
  • Study "Integration techniques for finding center of mass" in solid geometry
  • Explore "Centroid of semicircles and their applications" in engineering contexts
  • Investigate "Coordinate transformations in solid mechanics" for improved problem-solving
Students and professionals in engineering, physics, and mathematics who are involved in calculating the center of mass for various geometric shapes, particularly cylindrical structures.
HMPARTICLE
I have found via integration that the y coordinate is $$y =h/2 = 120 mm$$. The x coordinate is $$x = \frac{-4r}{3\pi} = -51.9mm$$ and the z coordinate is $$z = r - \frac{4r}{3\pi} = 69.1 mm$$. I have no answers in my textbook so can't confirm whether i am correct or not.
Google is you friend here.
If the cylinder is complete then the centre of mass is the midpoint.
If it is a quadrant of a solid cylinder as shown in your picture then it will be at C.y = h/2 as you show. The CM will lie on the plane of symmetry at 45 degrees, so the C.x and C.y offsets from the cylinder axis should have identical values. I suspect your values are correct.
Would it not be easier if you placed your origin and z axis on the cylinder axis ?
The centroid of a cylindrical segment, hoof or wedge is available on Wolfram Alpha. http://mathworld.wolfram.com/CylindricalSegment.html
Unfortunately the quarter tank problem has only one plane cut. You need two.
But one of the values will be the same as for a half cylinder which has a single plane cut.
Your values appear to be correct. Attached is a one page extract from an 8MByte .pdf
There is an even easier solution.
The centroid of a semicircle is R * 4 / 3π
  • · Replies 40 ·
  • · Replies 19 ·
