Theorectical diagonalazation question
  • Thread starter transgalactic
In summary, the conversation discusses the properties of diagonalizable matrices and how to determine if a given matrix is diagonalizable or not. It also provides examples and proofs for showing that certain matrices are diagonalizable.
transgalactic
1,395
there is
[tex]
A\epsilon M_{2x2}(Q)
[/tex]
I am given that A is diagonazable
prove that
A)
[tex]
A^{10}+12A
[/tex]
is diagonizable too
B)give an example for a matrix[tex] B\epsilon M_{2x2}(Q)[/tex]
that is not diagonizable,but b^2 is diagonisable
i know that the eigenvalues of a matrix are the same as for every matrix
like A^10 or A^3+2A+3I etc..
but i don't now how to show what they ask
What do you mean by [itex]A^{10}+ 12A[/itex]?
i mean operator of A n the power 10 plus 12 A
that matrix is diagonizable too
A) If A is diagonalizable, then [tex]D=T^{-1}AT[/tex], where D is diagonal. Now, note that sums and powers of diagonalizable matrices are also diagonal.
B) Hint: a certain rotation in the 2-D plane...
To show that a matrix is not diagonalizable over Q, it is sufficient to show that the characteristic polynomial has no rational roots.
regarding A:
i tried like this:
A=p^-1*D*P
P(A^10+12A)P^-1=P*A^10*P^-1 +12 P*A*P^-1
next..
why
P*A^10*P^-1=(P*A*P^-1)^10
regarding b:
i took matrix which polinomial is b=x^2+x+1 =[1,1,1,0]
b^2=[2,1,1,1]=x^3+x^2+x+2
which has only one eigen value of -2
how to deside ith square polinomial that i got is diagonizable??
If you only get one eigenvalue, you need to check if there are two linearly independent eigenvectors
actually -2 is not an eigen value
so it crashes the theory proposed by YYAT
transgalactic said:
regarding A:
i tried like this:
A=p^-1*D*P
next..
why
regarding b:
You can't possibly get a 3rd degree characteristic polynomial from a 2x2 matrix. Furthermore, a matrix is not equal to its characteristic polynomial, as you show above.
"yes i can"
we got 4 coordinated each one represents a member of a polinomial
so there is no much room for desitions
{1,x,x^2,x^3}
Then it is apparent that you don't know how to calculate the characteristic polynomial of a matrix. The characteristic polynomial of an n x n matrix A comes from the equation
[itex]det(A - \lambda I) = 0[/itex].
i know this thing 100%
give me a way to find a polinomial which doesn't have eigen values
but its square does have
regarding A:
i tried like this:
A=p^-1*D*P
next..
why
You mean "matrix" that doesn't have eigenvalues, not "polynomial". Every square matrix has eigenvalues over the complex numbers so I assume here you are talking about real numbers. Try
[tex]\begin{bmatrix}0 & 1 \\ -1 & 0\end{bmatrix}[/tex]
transgalactic said:
regarding A:
i tried like this:
A=p^-1*D*P
next..
why
[tex](PAP^{-1})^2=PAP^{-1}PAP^{-1}=PA^2P^{-1}[/tex]
since [tex]P^{-1}P=I[/tex]. I think you can see the general pattern.
the polinomial that comes from it is
x-x^2
it has an eigen values
x(1-x) x=0 x=1
i need a matrix which polinomial doesn't have eigen values but the square of this matrix has
x-x^2
x(1-x) x=0 x=1
The characteristic polynomial is
det(A-xI)=x^2+1
so the matrix has no real eigenvalues.
how to find the matrix of
x^2+x+3
x^2+x+3
I'm just being curious, but why is this important to find? I don't see anything in this thread that seems related to this particular polynomial.
i don't know how to think of a matrix which polynomial doesn't have eigenvalues.
on the other hand i can think of such polynomial but how to get its matrix.
Well, you're dealing with 2 x 2 matrices, with entries [a b; c d] (reading row by row). Maybe you can fiddle with these values to make (a - lambda)(d - lambda) - bc come out the way you want. The preceding quadratic in lambda is det(A - lambda*I).
regarding A:
[tex]
A^{10}+12A=pD^{10}p^{-1}+12pDp^{-1}
[/tex]
what now
how to prove that its diagoniazable??
transgalactic said:
regarding A:
[tex]
[/tex]
what now
how to show that its diagonizable?
is it a correct solution
[tex]
P(A^{10}+12A)P^{-1}=PA^{10}P^{-1}+12PAP^{-1}=(PAP^{-1})^{10}+12D=D^{10}+12D
[/tex]
is it legal to do the split like
[tex]
[/tex]
Yes, because matrix multiplication is distributive.
thanks
1. What is theoretical diagonalization?
Theoretical diagonalization is a mathematical technique used to simplify and solve complex systems or matrices. It involves transforming a matrix into a diagonal matrix, which is easier to work with and can provide valuable insights into the original system.
2. Why is theoretical diagonalization important?
Theoretical diagonalization is important because it allows us to understand and analyze complex systems and matrices. It also helps us find solutions and make predictions about the behavior and properties of these systems.
3. What are some applications of theoretical diagonalization?
Theoretical diagonalization has various applications in fields such as physics, engineering, and economics. It is used to solve differential equations, analyze circuits, and model population growth, among other things.
4. How does theoretical diagonalization work?
Theoretical diagonalization involves finding the eigenvalues and eigenvectors of a matrix. These are special values and corresponding vectors that satisfy a specific equation. By using these values and vectors, we can transform the original matrix into a diagonal matrix.
5. Are there any limitations to theoretical diagonalization?
Yes, theoretical diagonalization has some limitations. It can only be applied to square matrices, and not all matrices can be diagonalized. Additionally, the process of finding eigenvalues and eigenvectors can be computationally intensive for larger matrices.
