Theorectical diagonalazation question
  • Thread starter Thread starter transgalactic
transgalactic
there is
<br /> A\epsilon M_{2x2}(Q)<br />
I am given that A is diagonazable
prove that
A)
<br /> A^{10}+12A <br />
is diagonizable too
B)give an example for a matrixB\epsilon M_{2x2}(Q)
that is not diagonizable,but b^2 is diagonisable
i know that the eigenvalues of a matrix are the same as for every matrix
like A^10 or A^3+2A+3I etc..
but i don't now how to show what they ask
What do you mean by A^{10}+ 12A?
i mean operator of A n the power 10 plus 12 A
that matrix is diagonizable too
A) If A is diagonalizable, then D=T^{-1}AT, where D is diagonal. Now, note that sums and powers of diagonalizable matrices are also diagonal.
B) Hint: a certain rotation in the 2-D plane...
To show that a matrix is not diagonalizable over Q, it is sufficient to show that the characteristic polynomial has no rational roots.
regarding A:
i tried like this:
A=p^-1*D*P
P(A^10+12A)P^-1=P*A^10*P^-1 +12 P*A*P^-1
next..
why
P*A^10*P^-1=(P*A*P^-1)^10
regarding b:
i took matrix which polinomial is b=x^2+x+1 =[1,1,1,0]
b^2=[2,1,1,1]=x^3+x^2+x+2
which has only one eigen value of -2
how to deside ith square polinomial that i got is diagonizable??
If you only get one eigenvalue, you need to check if there are two linearly independent eigenvectors
actually -2 is not an eigen value
so it crashes the theory proposed by YYAT
transgalactic said:
regarding A:
i tried like this:
A=p^-1*D*P
next..
why
regarding b:
You can't possibly get a 3rd degree characteristic polynomial from a 2x2 matrix. Furthermore, a matrix is not equal to its characteristic polynomial, as you show above.
"yes i can"
we got 4 coordinated each one represents a member of a polinomial
so there is no much room for desitions
{1,x,x^2,x^3}
Then it is apparent that you don't know how to calculate the characteristic polynomial of a matrix. The characteristic polynomial of an n x n matrix A comes from the equation
det(A - \lambda I) = 0.
i know this thing 100%
give me a way to find a polinomial which doesn't have eigen values
but its square does have
regarding A:
i tried like this:
A=p^-1*D*P
next..
why
You mean "matrix" that doesn't have eigenvalues, not "polynomial". Every square matrix has eigenvalues over the complex numbers so I assume here you are talking about real numbers. Try
\begin{bmatrix}0 &amp; 1 \\ -1 &amp; 0\end{bmatrix}
transgalactic said:
regarding A:
i tried like this:
A=p^-1*D*P
next..
why
(PAP^{-1})^2=PAP^{-1}PAP^{-1}=PA^2P^{-1}
since P^{-1}P=I. I think you can see the general pattern.
the polinomial that comes from it is
x-x^2
it has an eigen values
x(1-x) x=0 x=1
i need a matrix which polinomial doesn't have eigen values but the square of this matrix has
x-x^2
x(1-x) x=0 x=1
The characteristic polynomial is
det(A-xI)=x^2+1
so the matrix has no real eigenvalues.
how to find the matrix of
x^2+x+3
x^2+x+3
I'm just being curious, but why is this important to find? I don't see anything in this thread that seems related to this particular polynomial.
i don't know how to think of a matrix which polynomial doesn't have eigenvalues.
on the other hand i can think of such polynomial but how to get its matrix.
Well, you're dealing with 2 x 2 matrices, with entries [a b; c d] (reading row by row). Maybe you can fiddle with these values to make (a - lambda)(d - lambda) - bc come out the way you want. The preceding quadratic in lambda is det(A - lambda*I).
regarding A:
<br /> A^{10}+12A=pD^{10}p^{-1}+12pDp^{-1}<br />
what now
how to prove that its diagoniazable??
transgalactic said:
regarding A:
what now
how to show that its diagonizable?
is it a correct solution
<br /> P(A^{10}+12A)P^{-1}=PA^{10}P^{-1}+12PAP^{-1}=(PAP^{-1})^{10}+12D=D^{10}+12D<br />
is it legal to do the split like
<br /> P(A^{10}+12A)P^{-1}=PA^{10}P^{-1}+12PAP^{-1}<br />
Yes, because matrix multiplication is distributive.
thanks
