Theorem 2.1.45: supremum property and nested intervals
Math Amateur
MHB
I am reading Houshang H. Sohrab's book: "Basic Real Analysis" (Second Edition).
I am focused on Chapter 2: Sequences and Series of Real Numbers ... ...
I need help with another issue/problem with Theorem 2.1.45 concerning the Supremum Property (AoC), the Archimedean Property, and the Nested Intervals Theorem ... ...
Theorem 2.1.45 reads as follows:View attachment 7171
View attachment 7172In the above proof by Sohrab, we read the following:
" ... ... Thus while (by definition) $$s + \frac{k_n}{2^n} = s + \frac{2 k_n}{ 2^{n + 1} }$$ is an upper bound of $$S, s + \frac{ 2 k_n - 2 }{ 2^{n + 1} } = s + \frac{k_n - 1 }{2^n}$$ is not. Therefore, either $$k_{ n+1 } = 2k_n$$ or $$k_{ n+1 } = 2k - 1$$ and $$I_{ n + 1 } \subset I_n$$ follow. ... ... "I am uncertain and somewhat confused by the logic of the above ...
I am not sure of the argument that either $$k_{ n+1 } = 2k_n$$ or $$k_{ n+1 } = 2k - 1$$ ... can someone please explain in simple terms why it is valid ... ..
I am also not sure exactly why $$I_{ n + 1 } \subset I_n$$ ... if anything it seems that $$I_{ n + 1 } = I_n$$ ... again, can someone please explain in simple terms why $$I_{ n + 1 } \subset I_n$$ ... that is that $$ I_{ n + 1 }$$ is a proper subset of $$I_n$$ ...[ ***EDIT*** Just checked and found that Sohrab is using $$\subset$$ in the sense which includes equality ... so using $$\subset$$ as meaning $$\subseteq$$ ... ]
Help will be appreciated ...
Peter
==========================================================================================The above theorem concerns the Supremum Property, the Archimedean Property and the Nested Intervals Theorem ... so to give readers the context and notation regarding the above post I am posting the basic information on these properties/theorems ...
See my comment on your http://mathhelpboards.com/analysis-50/supremum-property-aoc-archimedean-property-nested-intervals-theorem-22069.html#post99642. The way this proof works in that you divide the real line into subintervals of length $1/2^n$ and you locate the subinterval $I_n$ in which $\sup(S)$ (if it exists) must lie. You then increase $n$ to $n+1$, so that you are looking at intervals of half the previous length.
You know that the upper end of $I_n$, namely $s+ \frac{k_n}{2^n} = s + \frac{2k_n}{2^{n+1}}$, is an upper bound for $S$, but that the lower end of $I_n$, namely $s+ \frac{k_n-1}{2^n} = s + \frac{2k_n-2}{2^{n+1}}$, is not an upper bound for $S$.
Now look at the midpoint of $I_n$, namely $s+ \frac{2k_n-1}{2^{n+1}}$. Either that is an upper bound for $S$ or it is not. If it is, then we can take the lower half of $I_n$ to be $I_{n+1}$. If it is not, then we can take the upper half of $I_n$ to be $I_{n+1}$.
Thanks Opalg ... indeed, thanks to you I am beginning to really understand the proof ...
Most grateful ...
Peter
