The Final Equilibrium Temperature Reached?
The discussion centers on calculating the final equilibrium temperature when 15 grams of steam at 150 degrees Celsius is added to 300 grams of water at 10.0 degrees Celsius in a perfectly insulated calorimeter. The heat transfer equation used is Qlost = Qgain, leading to the equation (15g)(0.480 cal/g°C)(Tf - 150°C) + (15g)(540 cal/g) = (300g)(1.00 cal/g°C)(Tf - 10°C). The final equilibrium temperature (Tf) is determined to be 34°C after solving the equation.
  • Understanding of calorimetry principles
  • Knowledge of specific heat capacity
  • Familiarity with heat transfer equations
  • Basic algebra for solving equations
  • Study the concept of latent heat and its applications
  • Learn about the specific heat capacities of various substances
  • Explore advanced calorimetry techniques
  • Investigate the effects of insulation in thermal systems
Students in thermodynamics, physics educators, and anyone involved in calorimetry experiments or heat transfer calculations.
hatcheezy
A perfectly insulated calorimeter cup(it niether gains nor loses energy) contains 300 grams of water at 10.0 degrees Celsius. If 15.0 grams of steam at 150 degrees Celsius are added to the water, what final equilibrium temp is reached?
Qlost = Qgain
(msteam)(csteam)(\DeltaTsteam)+(msteam)(Lv)=(Mwater)(Cwater)(\DeltaTwater)
(15g)(.480cal/gm\circC)(Tf-150\circC)+(15g)(540cal/gm)=(300g)(1.00cal/gm\circC)(Tf-10\circC)
(7.2)(Tf-150\circC)+(8100)=(300)(Tf-10\circC)
(7.2Tf)-(1080)+(8100)=(300Tf)-(3000)
(7.2Tf)+(7020)=(300Tf)-(3000)
(10020)=(292.8Tf)
(Tf)=(34\circC)
(15g)(.480cal/gmLaTeX Code: \\circ C)(Tf-150LaTeX Code: \\circ C)+(15g)(540cal/gm)=(300g)(1.00cal/gmLaTeX Code: \\circ C)(Tf-10LaTeX Code: \\circ C)
In left hand side you have substituted 0.480 csl/g/oC for th specific heat of the water and in right hand side 1.00 cal/g/oC for the same thing. How is that?
