Thermistor relationship, linearizing (really easy)
This discussion focuses on the use of thermistors as temperature sensors, specifically addressing the resistance values at 25 degrees Celsius. A 22k thermistor should exhibit a resistance of 22k ohms at this temperature, while a 15k thermistor should show 15k ohms. However, the user reports inconsistent readings, such as a 6k ohm resistance for a 10k thermistor. To linearize the non-linear resistance-temperature relationship, it is recommended to plot the logarithm of resistance against temperature.
  • Understanding of thermistor characteristics and specifications
  • Familiarity with resistance-temperature relationships
  • Basic knowledge of data analysis and graphing techniques
  • Experience with interpreting thermistor datasheets
  • Research thermistor datasheets for specific resistance values at various temperatures
  • Learn how to plot logarithmic graphs for resistance versus temperature
  • Explore methods for minimizing self-heating effects during resistance measurements
  • Investigate linearization techniques for non-linear sensor data
Students and professionals working with temperature sensors, electronics enthusiasts, and anyone involved in data analysis of thermistor performance.
gRACK
hello,
I'm doing coursework on using a thermistor as a temperature sensor. For my preliminary readings I had to choose between 3 different thermistors.
Is it true that, for example, a 22k thermistor has a resistance of 22kohms at 25 degrees? (my tutor told me this) likewise, a 15k thermistor has a resistance of 15kohms at 25 degrees? My results don't show this at all; they're completely off. (eg. 6kohm resistance at 25 degrees for a 10 kohm resistor..)
I've looked at some thermistor datasheets but i can't make head nor tail of them. could anyone give me a range of the types of resistances I should be getting, please?
Also, anyone advice on how I should linearize my results? I understand that the resistance-temperature graph is non-linear. do I: Record the voltage at different resistances (and therefore temperatures) and plot a voltage-temp graph?
but this won't be a straight line, am i right? so/do I have to plot a tangent to my curve?
i'm just really unsure of what I'm doing, I've heard/read different things. Thanks in advance for any help, it is muchly appreciated.
What are your units of temperature? Thermistors vary quite a lot I suspect. Could you post the links to the data sheets?
A 10 kohm resistor should indeed have a resitance of 10 kohm at 25 degrees celsius.
I found some datasheets here
http://www.omega.com/temperature/Z/pdf/z256-257.pdf
You are measuring the resistance with a voltage small enough to not procuce heating in the thermistor?
You could plot the logarithm of the resistance against the temperature.
  • · Replies 22 ·
