How Does Thermoacoustic Refrigeration Compare to Conventional Compressors?
  • Thread starter Thread starter bags
    Refrigeration
The discussion revolves around thermoacoustic refrigeration, comparing it to conventional compressor systems. Participants explore the mechanisms of thermoacoustic refrigeration, its noise levels, and seek comparative analyses regarding energy consumption and pressure capabilities.
  • One participant requests information and links about thermoacoustic refrigeration, indicating a desire for foundational knowledge.
  • Another participant provides a detailed description of how thermoacoustic refrigeration works, including the role of sound waves and gas behavior.
  • Concerns are raised about the high sound pressure levels (180 dB) associated with thermoacoustic systems, with a participant noting that internal noise levels may be comparable to conventional systems.
  • A participant shares personal experience with a thermoacoustic system, discussing sound power levels and attenuation from internal to external noise.
  • Questions arise regarding the nature of the acoustic source, with speculation about its frequency characteristics and implications for system design.
  • Several participants express interest in obtaining more details about the cooling capabilities and efficiency of thermoacoustic systems compared to conventional compressors.
Participants express varying levels of knowledge and interest in thermoacoustic refrigeration, with no consensus on its comparative advantages or disadvantages over conventional compressors. Multiple viewpoints on noise levels and operational characteristics are presented without resolution.
There are unresolved questions regarding the energy consumption of thermoacoustic systems and their maximum pressure capabilities. The discussion includes references to specific technical aspects that may require further clarification.
Individuals interested in refrigeration technology, acoustic engineering, and comparative analyses of cooling systems may find this discussion relevant.
bags
hi friends,
I wanted to know about the Thermoacoustic Refrigeration.Can u please submit any links or explanation about the topic.Looking forward to your replies.
Sorry, bags, but I can't help you. I've never even heard of that before. I'm just weighing in so you don't think that you're being ignored. Others are looking for your answers. :smile:
Here is an article with a decent basic description of the process.
http://www.ehponline.org/docs/1994/102-9/innovations.html" Quote below from the article:
How does it work? First, customized loudspeakers are attached to cylindrical chambers filled with inert, pressurized gases such as xenon and helium. At the opposite end of the tubes are tightly wound "jelly rolls" made of plastic film glued to ordinary fishing line. When the loudspeakers blast sound at 180 decibels, an acoustic wave resonates in the chambers. As gas molecules begin dancing frantically in response to the sound, they are compressed and heated, with temperatures reaching a peak at the thickest point of the acoustic wave. That's where the superhot gas molecules crash into the plastic rolls. After transferring their heat to the stack, the sound wave causes the molecules to expand and cool. "Each one of these oscillating molecules acts as a member of a 'bucket brigade,' carrying heat toward the source of the sound," says Garrett. Cold temperatures can then be tapped for chilling refrigerators, bedrooms, cars, or electronic components on satellites and inside computers, according to Garrett. Someday, he says, turning up the air-conditioner could be accomplished by adjusting a volume-control knob.
I'm trying to build up a knowledge base on this here
http://www.mecheng.adelaide.edu.au/anvc/thermoacoustics/
180 dB? Wholly molley. Forget worrying about fan noise from that fridge.
That's the internal sound pressure level. You'll find that the 'noise' amplitude inside a typical thermoacoustic refrigerator is in general, similar or less than that of a typical vapour compression system, so the expectation in external noise levels should be similar.
A system I built myself that achieved an max internal SPL of 176dB operating at ~105Hz was found to emit a sound power level equivalent to 51dB(A) at 1 metre.
What's the main cause for the attenuation? From 180 to 51 dB is pretty substantial.
It is: believe it :smile:
Provided that the structure is not driven at a resonant frequency, it's due to the high structural impedance to the operating frequency, and poor re-radiation of vibration at the external surface. Also, it's 176dB to 51dB(A): the 'A' weighting is also a factor here.
So is the acoustic source is a single frequency source? I guess that would make it easier to tailor the enclosure for those purposes. Pardon the pun, but very cool.
The interior is largely featureless so the operating mode is typically of very http://en.wikipedia.org/wiki/Q_factor" (low damping). There are of course harmonics associated with the operating frequency, but are usually of insignificant level.
Can anyone supply some details abount this type of cooling. Sounds interesting.
Thanks
Pat M
Thanks
Pat M
I'm going to blatantly refer to the links I've put together here:
http://www.mecheng.adelaide.edu.au/anvc/thermoacoustics/index.php?option=com_weblinks&Itemid=23
Hey My Friend Here's A Site Containing All The Things that you Need And More info that Can Be Helpful For you
http://www.rizkbrothers.com/Arabic/products.php?tn=cHJvX3Byb2R1Y3Rz&for=MTQ%3D&main=0&sub=0&pro=14&lan=Ar
Well, can anybody give me a comparative analysis of thermoacoustic compressors and conventional compressors regarding energy consumption and how much the thermoacoustic compress can compress gas/vapor i.e. upto which pressure level (in bars).
